taylorkh
No sound on Pi3b+
Fri Jan 11, 2019 10:05 pm
My first Pi 3B with Ubuntu Mate 16.04 played sound out of the audio jack with no issues that I can remember. I have a 3B+ also with Ubuntu Mate both 16.04 and 18.04 installs (different SD cards) and neither one of them will play sound. I have seen a lot of posts re. playing sound via HDMI but I am simply needing to use the audio port.
Sound preferences shows:
- Hardware tab
- - bcm2835 ALSA
- - choices of mono or stereo on 16.04, mono only on 18.04
- Output tab
- - Analog output
alsa-utils are installed and up to date
pulseaudio is also installed and up to date
Any suggestions? I can look at the 3B again but that is a bit problematic as it is my production gateway, route, firewall, dhcp and vpn sharing box.
TIA,
Ken
taylorkh
Re: No sound on Pi3b+
Sat Jan 12, 2019 12:32 am
I just tried a fresh install of Raspbian Stretch - same thing. I installed audacious and played an mp3 file. No sound output.
taylorkh
Sat Jan 12, 2019 12:58 am
It has been a long day... I did a search on configuring sound on the Pi and found the instructions https://www.raspberrypi.org/documentati ... -config.md which reminded me I needed to run raspi-config. I did that an am now listening to Metal Queen by Lee Aaron :mrgreen:
This issue is SOLVED.
bluenote
Tue Jul 23, 2019 4:48 pm
Can you confirm proper audio in ubuntu mate 18? Because I only get crackly, delayed, unreliable mono on my 2B on ubuntu 18 and over in their forums no one seems to care even though multiple people have reported this.
taylorkh
Tue Jul 23, 2019 7:13 pm
Sound works fine on the 3B+ with Ubuntu Mate 18.04. I just listened to "Locomotive Breath" by Jethro Tull :D I do not have a Pi 2. I do have a Zero and a Zero W but they run only Razpbian.
Ken
bluenote
Wed Jul 24, 2019 12:53 am
Ken
Including actual stereo?!
taylorkh
Wed Jul 24, 2019 12:10 pm
The audio hardware on the Pi 3B+ is shown as "Analog mono output" so no, there is not stereo. I do have a Bluetooth headphone receiver gizmo which does produce stereo sound from the Pi.
Ken
