kiam001
Raspberry Pi TV had Does not work on Raspberry Pi 3 B (old Model)
Thu Jan 10, 2019 7:50 pm
i tried everything i found on the internet: dtoverlay=rpi-tv then i get the error message sxd2880 invaild chip ID
Just connect like this nothing happens, I already tried libreeelc, raspbian and osmc everywhere the errors are the same
wh7qq
Re: Raspberry Pi TV had Does not work on Raspberry Pi 3 B (old Model)
Fri Jan 11, 2019 11:09 pm
Note that the TV Hat does not support US ATSC broadcast.
kiam001
Sat Jan 12, 2019 11:10 am
dmesg | grep gpio
[ 0.358337] uart-pl011 3f201000.serial: could not find pctldev for node /soc/[email protected]/uart0_pins, deferring probe
[ 5.889566] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
dmesg | grep dvb
[ 6.190901] dvbdev: DVB: registering new adapter (CXD2880)
dmesg | grep cxd
[ 6.350132] cxd2880: cxd2880_attach: chip id invalid.
[ 6.350165] cxd2880_spi: cxd2880_spi_probe: cxd2880_attach failed
kiam001
Sat Jan 12, 2019 11:13 am
I have tested the module with a Raspberry Pi 2 and it works perfectly there, same image on a Raspberry Pi 3B and it is not recognized.
Sat Jan 12, 2019 12:22 pm
Works fine on my 3B
[email protected]:~ $ cat /sys/firmware/devicetree/base/model ;echo
Raspberry Pi 3 Model B Rev 1.2
[email protected]:~ $ dmesg | grep gpio
[    0.029878] uart-pl011 3f201000.serial: could not find pctldev for node /soc/[email protected]/uart0_pins, deferring probe
[    0.205010] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[email protected]:~ $ dmesg | grep dvb
[    3.843954] dvbdev: DVB: registering new adapter (CXD2880)
[email protected]:~ $ dmesg | grep cxd
[    3.876815] cxd2880: cxd2880_attach: CXD2880 driver version: Ver 1.4.1 - 1.0.5
[    3.876836] cxd2880 spi0.0: DVB: registering adapter 0 frontend 0 (Sony CXD2880)...
[    3.877611] cxd2880_spi: cxd2880_spi_probe: Sony CXD2880 has successfully attached.
[    6.933645] cxd2880 spi0.0: DVB: adapter 0 frontend 0 frequency 0 out of range (174000000..862000000)
[   12.684784] cxd2880: cxd2880_set_frontend: sys:3 freq:586000000 bw:8
[   13.710917] cxd2880: cxd2880_set_frontend: tune result 0
[email protected]:~ $ uname -a
Linux raspi7 4.14.79-v7+ #1159 SMP Sun Nov 4 17:50:20 GMT 2018 armv7l GNU/Linux
