Buster has some issues with the game, making it to loss focus and to pause if ran in a window on RPI3/4. Stretch on RPI3 works fine.
In order to run in Buster you need to run the game in a window, no fullscreen is possible for now.
This is the classic Freespace 2 game from 1999, getting it to work is petty much stright forward, i had to compile a launcher and a fs2open binary.
I had to use a rather old version of the source code since the up to date version needs OpenGL 3.1 minimum. So i tested it working with 3.6.18, 3.7.0 and 3.7.2 versions, anything newer than that needs OpenGL 3.1.
So lets start with this guide.
Part 1 : Compiling & installing Wxlauncher
Open a terminal and run these commands
sudo apt-get install build-essential libopenal-dev libwxgtk3.0-dev git python-markdown cmake libsdl2-dev
git clone https://github.com/scp-fs2open/wxLauncher
cd wx*
cmake ./
sudo make install
Part 2 : Compiling Fs2 Open bin
Now that you have the launcher up and running you need to compile FS2_Open.
sudo apt-get install libopenal-dev libjansson-dev libjpeg-dev liblua5.1-dev libogg-dev libpng-dev libsdl-dev libtheora-dev libvorbis-dev automake libswscale-dev libavcodec-dev libavformat-dev
wget http://scp.indiegames.us/builds/fs2_open_3_7_2_src.tgz
tar zxvf fs2_open_3_7_2_src.tgz
cd fs2_open_3_7_2
./autogen.sh
sed -i -e 's/-mtune=generic -mfpmath=sse -msse -msse2/-mtune=cortex-a53/' ./mongoose/Makefile
sed -i -e 's/-mtune=generic -mfpmath=sse -msse -msse2/-mtune=cortex-a53/' ./code/Makefile
sed -i -e 's/-mtune=generic -mfpmath=sse -msse -msse2/-mtune=cortex-a53/' Makefile
make -j4
What you need to change is the same on every file, use a text editor and the search, seach for "-mtune" when you find -mtune, delete from that line "-mtune=generic -mfpmath=sse -msee -msse2". Those are x86 specific compiler flags that dont work on arm. These appear 2 times on each of the 3 files.
UPDATE: If you have a raspberry pi 4 you should use these sed lines instad, so it compiles for a72. This is not needed.
sed -i -e 's/-mtune=generic -mfpmath=sse -msse -msse2/-mtune=cortex-a72/' ./mongoose/Makefile
sed -i -e 's/-mtune=generic -mfpmath=sse -msse -msse2/-mtune=cortex-a72/' ./code/Makefile
sed -i -e 's/-mtune=generic -mfpmath=sse -msse -msse2/-mtune=cortex-a72/' Makefile
It will take a while (about 30 minutes) to compile on the RPI.
Part 3 : Making the fs2 root folder & configuring wxlauncher
1) Create a folder called "fs2_open" on the user folder (/home/pi/).
2) Copy the "fs2_open_3_7_2" executable file from the "fs2_open_3_7_2/code" folder on the source code you just compiled on this root folder.
3) You are ready to drop mods folder or the retail files in here. The retail files you are gona need are:
root_fs2.vp
smarty_fs2.vp
sparky_fs2.vp
sparky_hi_fs2.vp
stu_fs2.vp
tango1_fs2.vp
tango2_fs2.vp
tango3_fs2.vp
warble_fs2.vp
4) launch wxlauncher from accessories menu.
5) Basic Settings-> Browse for Game Root folder -> select the "fs2_open" folder you just created.
6) Select "fs2_open_3_7_2" as"fs2 open executable".
7) Video Resolution: 1280x720 MAX, Depth: 16 or 32 bits, Texture Filter: Bilineal, Anisotropic: off, anti-aliasing:off
8) Playback device: Select vc4_hdmi if you are running off HDMI audio, dont enable EFX.
9) Go back to Welcome and save the profile.
-ONLY FOR RASPBIAN/DEBIAN BUSTER"
10) Go to "Advance Settings"
11) Scroll down to "Dev Tool"
12) Select and Enable "Run in a Window" and "Dont grab mouse/keyboard in a Window"
13) (optional) use "-res 1920x1010" in "Custom flags" to adjust the window size to screen size, this will fit a 1920x1080 screen, to me performance was not good enoght but you can use this to change window resolution.
14) Go back to Welcome and save the profile.
-Note: Changing window resolution dosent work with the Freespace 2 demo files, it will always run in 800x600 in a window no matter what you set, this however works for the retail game files.
Here is a video guide and gameplay.
https://www.youtube.com/watch?v=TA6ew4aXpl4
Notes: As i was unable to get S3TC texture compression working on the RPI, getting mods to work is a problem, FS2 Retail game files and the fs2demo works. That for sure.
