Will the red LED light up at all if the polyfuse is blown?
Also, how long can it take for a polyfuse to recover?
No.
I can't find a figure for that - Littelfuse only seem to give a spec. for its resistance 1 hour after tripping.Also, how long can it take for a polyfuse to recover?
Elsewhere, "24 hours" has been mentioned, along with "or more"it will automatically recover if you give it some time, (meaning turning off the power and wait) though it may take a few days.
... never have tripped my RPi's polyfuses yet.... but just in case, can the "polyfuse recovery time" be somewhat "accelerated" if the polyfuse is "cooled" to a certain temperature?Burngate wrote: it will automatically recover if you give it some time, (meaning turning off the power and wait) though it may take a few days.
Yes is its. You only need to remove the power and "cool" the PTC fuse:LTolledo wrote: ↑Thu Jan 03, 2019 10:55 am... never have tripped my RPi's polyfuses yet.... but just in case, can the "polyfuse recovery time" be somewhat "accelerated" if the polyfuse is "cooled" to a certain temperature?Burngate wrote: it will automatically recover if you give it some time, (meaning turning off the power and wait) though it may take a few days.
just asking....![]()
*https://www.littelfuse.com/about-us/edu ... -ptcs.aspxLittlefuse* wrote: The heat generated by this limited current through the higher resistance value will maintain the temperature of the PTC at a level that will cause the resistance to remain high. This thermal equilibrium condition will continue until power is removed from the circuit which allows the PTC to cool down and the resistance will decrease. The resettable feature of the PTC is based on the fact that the increase in resistance resulting from the increase in temperature is reversible. The PTC is reset or returned to the lower resistance state by removing the power from the circuit which allows the device to cool down. The unit is then ready to react to future overloads. The resistance will remain low if the cause of the overcurrent has been corrected, but if the overcurrent recurs the device will again switch to the high resistance state.
Part of the problem is that the polymer* has two states, crystalline and amorphous, and while the transition in one direction is well defined, the opposite isn't.As the device heats, the polymer will expand, changing from a crystalline into an amorphous state ...
When power is removed, the heating due to the leakage current will stop and the PPTC device will cool. As the device cools, it regains its original crystalline structure and returns to a low resistance state where it can hold the current as specified for the device.[6] This cooling usually takes a few seconds, though a tripped device will retain a slightly higher resistance for hours, unless the power in it is weaker, or has been often used, slowly approaching the initial resistance value. The resetting will often not take place even if the fault alone has been removed with the power still flowing as the operating current may be above the holding current of the PPTC. The device may not return to its original resistance value; it will most likely stabilize at a significantly higher resistance (up to 4 times initial value). It could take hours, days, weeks or even years for the device to return to a resistance value similar to its original value, if at all
