mcgerard
Where is the boot log?
Fri Nov 16, 2012 12:42 pm
Where will I find the boot log in Raspbian, or if there isn't one how do I set one up to log all that information that flies past during bootup? I want to see what stuff is being loaded and what hardware is recognised.
joan
Re: Where is the boot log?
Fri Nov 16, 2012 12:47 pm
Use the command
dmesg
or
dmesg >log
and then use an editor to look at log.
RaTTuS
Contact: Twitter YouTube
Fri Nov 16, 2012 12:48 pm
cat /var/log/syslog may also help
Covfefe
mcgerard
Fri Nov 16, 2012 4:37 pm
Thanks joan and RaTTus. I've got that now.
MarcGa
Fri Aug 19, 2016 8:15 pm
Is it possible to see the logs of a previous boot?
I don't know why but, some times, the raspberry hangs during the boot process. I would like to read the previous boot logs in order to find what's happened
Merci
(thanks)
Marc
Torben
Fri Jun 30, 2017 9:37 am
MarcGa wrote:Is it possible to see the logs of a previous boot?
Did you find a solution for this problem?
kingosticks
Fri Jun 30, 2017 11:33 pm
Install bootlogd:
apt-get install bootlogd
The log will be in /var/log/
BobH
Wed Dec 06, 2017 11:04 pm
I was able to install bootlogd but I can't find or read or see /var/log/
I am new to this stuff can you explain more for a new? Set by step?
Return to “Raspbian”
