g4gql
Raspi Not firing up
Fri Nov 16, 2012 8:49 am
Hi All
After many attempts, SD cards, Wifi dongles, hubs etc, using the 32 inch TV, my Raspi would come on only sometimes.
Then it would not come on at all
I increased the power supplies to 3A for Raspi and the hub, but still no use
I then wondered if using the TV as a monitor would affect the set up
I used one of my PC monitors and BINGO!!!! now perfect, even the hub does not need powering up
So...if you have this problem, suspect the TV and use a monitor.
Incredible difference!
Alan
G4GQL
Wheel_nut
Re: Raspi Not firing up
Fri Nov 16, 2012 12:16 pm
I suspect that your TV requires the HDMI signal levels boosted. This is easily done in the ./boot/config.txt file. look for the command #config_hdmi_boost=0 and change it to read
config_hdmi_boost=4 (don't forget to delete the leading #)
