CrazyCreator
Python Serial Port Problem
Fri Nov 16, 2012 12:56 am
I have my computer connected to my Pi's serial port through a serial bluetooth module. I have a python script running that says when it receives a certain character, to turn on an LED. Not only is the LED not turning on, but if I send it "H", for example, it sends back and infinitely long string of "H"s. What could be wrong? Code is below.
import serial
import time
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(24, GPIO.OUT)
ser = serial.Serial("/dev/ttyAMA0", 9600, timeout=1)
while 1:
      x = ser.read()
              if x == "H":
                      GPIO.output(24, GPIO.HIGH)
              if x == "L":
                      GPIO.output(24, GPIO.LOW)
SiriusHardware
Re: Python Serial Port Problem
Mon Nov 19, 2012 7:37 pm
CrazyCreator wrote:I have my computer connected to my Pi's serial port through a serial bluetooth module. I have a python script running that says when it receives a certain character, to turn on an LED. Not only is the LED not turning on, but if I send it "H", for example, it sends back and infinitely long string of "H"s. What could be wrong? Code is below.
import serial
import time
while 1:
      x = ser.read()
              if x == "H":
              if x == "L":
CC: By default, the Pi's system uses the onboard serial port as an alternative console - have you taken the steps to disable that, in order to gain sole control over the serial port? It may be that Pyserial on the Pi automatically does that for you, but if not, that would be one likely cause of seemingly irrational behaviour.
Return to “Python”
