drgeoff wrote:
dakure wrote: ↑Fri Dec 28, 2018 9:58 pm
I need to confess that I am completely lost on resistors transistors and circuits in general. I have problems catching the diagrams also. It s just not my field.
In that case I strongly advise that you make no attempts yourself but instead engage the services of someone who is qualified to design, install and commission 220 volt AC systems..
dakure wrote: ↑Sat Dec 29, 2018 10:56 am
Thank you, I am very used to plan electric installations as architect and very aware of dangers of high voltage. I am just trying to learn something.
Okay. However I think it is importend that you know how a schematic "works" and how you can read it and build it. So, get some raspberry pi kit with a breadboard, leds, resistor, transistors, ect. Then you can learn safely how it is all working, before you connect it to a device that is direcly connected to the mains voltage. And also, when you connect your rpi to the fan. You need to remember that it could be possible that your Rpi is directly connected to the mains. If it is fan is faulty, or someone connect is wrong. And then your "save" ground of your pi is connected to the live or neutral wire. And that is deadly for you and the attached hardware. So, it is best that you can not touch the pi if it connected to the fan. And also no monitors connected to it ect.
Brandon, from the last diagram attached of Bortek can you just tell me what represents Pin1, Pin2 and Pin3? Is this pin3 really doing something?
I assume the GPIO is the pwm output.
Like I said before, I think the best way is to build this schematic and use a led as a load. In stead of the ac fan. So, you get some experience with this. And I don't know if there is something that is ready to use. By the way, you will learn the most if it is not working directly
To come back to your question. Could you compare the datasheet of Bortek his fan to the one you have. And lets see if you can find the answer. This will probably also answer about pin 3.
