joaoabreu23
Raspberry pi3 access point !!
Tue Dec 25, 2018 11:10 am
Hi guys, I’m trying to set my raspberry into an access point but at the end, when I try to connect my phone or any device into the raspberry, I can’t.
I have signal,l of the wireless that i create, I put the password, but after then it can’t have a connections with the raspberry
O really need help, because it’s a school project and I am worried
Please someone help, thank you
Re: Raspberry pi3 access point !!
Tue Dec 25, 2018 7:35 pm
These instructions ??
https://www.raspberrypi.org/documentati ... s-point.md
Retired disgracefully.....
This at present is my daily "computer" https://www.asus.com/us/Chrome-Devices/Chromebit-CS10/
adigitaldj1
Wed Dec 26, 2018 2:12 am
This is exactly the info I was looking for! What is the Wifi distance of the PI3? I want to use the PI on water to measure weather reading and be able to use my phone to access a web page on it for the readings.
Thanks,
Kevin
tazz4843
Wed Dec 26, 2018 5:54 pm
The antenna is very small (about 2mm by 9mm), so expect to get about 50ft range (~15.25m). A better way around this is to buy a USB WiFi adapter, which can give you upwards of ~500ft range (152.4m). Make sure it supports Linux.
Check me out on Reddit: reddit.com/u/tazz4843
timsan
Mon Dec 31, 2018 8:13 pm
It has not been easy to find such a device. I looked on Amazon and I could not find a usb wifi adapter with an antenna, with the right Linux and hostapd support.
Would anyone here have any recommendations? It's tricky, since not only does it need Linux support but it also needs hostapd support to make it usable as an access point.
SurferTim
Tue Jan 01, 2019 1:03 am
I use the Alfa brand, and they work well with RPis. Plug-N-Play.
https://www.amazon.com/Alfa-Network-Wir ... op?ie=UTF8
timsan
Tue Jan 01, 2019 8:45 pm
That Alfa Network device looks really good.
Do you need to use a mini-usb to usb cable to connect it with the Raspberry Pi?
ta, t.
SurferTim
Wed Jan 02, 2019 11:36 am
ta, t.
It comes with a standard usb cable.
CarlSmithz
Sat Jan 05, 2019 11:01 am
you don't need to know the uuid, you have to set the uuid you want to use on both client and server
