sim_tcr
How to Mount a NTFS External USB Hard drive in rapbian wheez
Thu Nov 15, 2012 11:53 am
Can someone please help me to mount a NTFS External USB Hard drive in rapbian wheezy. It is WD My book essentials with its own power source.
Thanks in advance.
http://raspisimon.no-ip.org
Raspberry Pi Model B x 2, Raspberry Pi 2 x 2, Transcend 32GB Class 10, Transcend 16GB Class 10, Transcend 8GB Class 4, Custom 12V 1.5A (stepped down to 5.5V)
Joe Schmoe
Re: How to Mount a NTFS External USB Hard drive in rapbian w
Thu Nov 15, 2012 11:59 am
What have you tried so far?
(I'm going to guess that the magic bullet you are looking for is: apt-get install ntfs-3g)
RaTTuS
Contact: Twitter YouTube
Thu Nov 15, 2012 12:02 pm
sudo fdisk -l
^ should show you what drives are there
sudo mount /dev/sda1 /mnt
should mount the 1st drive's 1st partition to /mnt the output from fdisk should show you the partition names
Covfefe
sim_tcr
Thu Nov 15, 2012 2:23 pm
RaTTuS wrote:sudo fdisk -l
Thanks it worked. I tried a FAT32 and NTFS pen drives. Both worked well.
Can i assume that by running umount /mnt/usb-king I can safely remove the connected drives?
Joe Schmoe,
is ntfs-3g works different than what RaTTuS explained above? Which one is better?
RaTTuS
Thu Nov 15, 2012 2:25 pm
sudo umount /mnt
will unmount it - as long as nothing is locked on it i.e. you have a terminal session sat in a directory there
ntfs-3g
is a better driver that will do read write on ntfs
Covfefe
sim_tcr
Thu Nov 15, 2012 2:30 pm
RaTTuS wrote:sudo umount /mnt
ntfs-3g
I have ntfs-3g installed now. Can you explain how to use it?
My need is, I have a WD Mybook Essential 1TB external drive with its own power source formatted as NTFS . I would like to read and write to it. Also whenever raspberry get rebooted the drive should automatically get mounted.
lewmur
Thu Nov 15, 2012 4:37 pm
ntfs-3g
If you want the drive to mount at boot, you are going to have to edit the /etc/fstab file. First you'll need to create a folder for the mount. Typically something like this:
$mkdir /home/pi/data
Test it by trying to mount the drive
$sudo mount /dev/sda1 /home/pi/data
You should then be able to access the drive via /home/pi/data. If so, then edit the /etc/fstab file and add a line
/dev/sda1 	/home/pi/data	ntfs-3g	rw,default	0	0
You need to do the editing as root. This should work so long as the drive is the only external drive you have. If you swap drives in and out, you may need to replace "/dev/sda1" with the UUID of the drive.
sim_tcr
Fri Nov 16, 2012 3:08 am
Thank you. All Set.
Berrytade
Tue Feb 26, 2013 2:48 am
Just tried this on new 3TB with ntfs, GPT, and get:
wrong fs type, wrong option, bad superblock on /dev/sda2/, missing codepage or helper program or other error
RaTTuS
Tue Feb 26, 2013 9:40 am
Berrytade wrote:Just tried this on new 3TB with ntfs, GPT, and get:
new problems
sudo fdisk -l
how did you create sda2 ? how is it formatted , where was it formatted
Covfefe
Berrytade
Tue Feb 26, 2013 3:20 pm
new problems
sudo fdisk -l
Drive was formatted on server 2012 with a quick format and given GPT boot record.
It was automatically labelled dev/sda2 when the external drive was inserted via usb.
Stormspace9
Wed Dec 11, 2013 2:16 pm
Joe,
Looked everywhere trying to find out why ntfs-3g wasn't working in fstab. <ugggh!> Thanks man!
Boomer
Tue Dec 17, 2013 9:51 pm
RaTTuS,
Just wanted to let you know that I just followed your instructions and they worked perfectly!! Thanks for being such a great resource.
Jack
DafyddWynn
Tue Feb 24, 2015 11:52 am
Please accept apologies for rookie ignorance. I'm trying to mount a USB drive (toshiba 1TB) located on a netgear D6200 router to my RPI B+ as a remote file. It works well with Windows and the Netgear Genie App, so there's no fundamental problem with the setup
I'm using:
sudo mount.cifs //192.168.0.1/USB_Storage /media/ReadyShare guest
This returns
Mount error (13): permission denied
The RPI can see the drive, using nmblookup returns information on the drive.
I've tried various permutations of this command, substituting readySHARE for the IP address, and various passwords, using the pi password and the router login password.
I'm aware that this is an old forum, but it seems relevant to my problem. I'm well and truly stuck, would appreciate any help
dpcons
Wed Feb 25, 2015 9:50 pm
Hi, I don't have a solution but rather the same problem. I too am trying to access my USB_Storade thru a Netgear router and have all the same issues. Did you ever resolve your situation?
Just wondering
Dan
DafyddWynn
Wed Feb 25, 2015 10:18 pm
No joy with the Netgear issue. Got postings on other forums, and a query to Netgear. Not holding my breath, but if I resolve issue I'll post it. May have to get another RPI to act as server because my application is remote and access to the pi is difficult
dpcons
Wed Feb 25, 2015 10:29 pm
Just wondering
Dan
I've been successful with this, but still fail with fstab
sudo mount -t cifs -o user=pi,password=yourpassword,sec=ntlmv2 //192.168.1.1/USB_Storage /home/pi/media
DafyddWynn
Wed Feb 25, 2015 10:40 pm
Dan
Thanks for that. Worked first time. I'll have a play with fstab, but my plan b is to put it in a script to run at start up
Dafydd
petemnz
Sat Apr 25, 2015 2:24 am
Thanks for info took me hours to get fstab to work I used:
Mount using etc/fstab add following line (user and password are for netgear router, no password for drive access)
//192.168.1.3/USB_Storage/recordedtv /home/osmc/recordedtv cifs user=<yourusername>,password=<yourpassword>,sec=ntlmv2 0 0
Would not auto mount on boot as it does not wait for network so used sleep20 in rc.local.(tried _netdev in fstab but didn't work for me)
Add 2 lines below to etc/rc.local this waits for network then mounts all on boot.
sleep20
sudo mount -a
DirkS
Sat Apr 25, 2015 10:09 am
petemnz wrote:Add 2 lines below to etc/rc.local this waits for network then mounts all on boot.
sleep20
sudo mount -a
If this is on a Pi2B then try adding 'rootdelay=5' to the first (and only) line in /boot/cmdline.txt
petemnz
Tue Apr 28, 2015 10:03 am
sleep20
sudo mount -a
Yes it is Pi2B , ok thanks will try.
The YaccK
Tue Sep 15, 2015 2:54 pm
Not being original here, but thanks for your information RaTTuS !
The pi is great, and it isn't just a board to hack : I use it as my desktop computer.
Obsidian Babble
Sat Mar 18, 2017 3:13 am
Thank y'all very much.
I'm new to Pi & CLI on linux, and was able to find the answer to my question fairly quickly here.
Looking forward to learning and helping if I can.
Obsidian Babble
:D
Joe Schmoe wrote: Quote Joe Schmoe
Post by Joe Schmoe » Thu Nov 15, 2012 5:59 am
