I'm storing some vertex data in:
boost::circular_buffer<int> bufferData(200);
My class has a function to return a pointer to the address of bufferData.front():
int *getBufferData() {return &bufferData.front();}
Then i send this pointer to glBufferData:
glBufferData(GL_ARRAY_BUFFER, 200*sizeof(int), MyClass.getBufferData(), GL_STATIC_DRAW);
The screen renders, however i don't get the right coordinates to show up..it almost looks as if openGL is plotting the addresses instead of the actual data in my circular buffer.
Can anyone confirm if this is the right way to send the data?
