I am facing issue with RPi 3, it was working fine till I decided to change the screen resolution. I changed the screen resolution, I got an onscreen pop-up asking me for a reboot so that the changes could take effect. I clicked on "ok".. That's all! from that time I have a black screen.
I see a red light and flickering green light on the Pi.
I am using raspberry os, and I know that the OS is not corrupt, I can say this because I see LEDs glowing when I connect my LAN cable.
Also I have tried to solve this issue by a hardware reset using the "RUN" pins on the chip, but this does't help me.
Is there any way to change my screen resolution without re-flashing the OS on the SD card? Perhaps changing the config on the SD card using a card reader?
Thanks in advance!
