Fri Jan 25, 2019 7:04 pm
hi, thanks for the reply. I was already aware of the "tvservice -s" command.
But my goal is to monitor the display in real time. Let me explain: If I start the raspberry with the display connected (powered separately from the rasp) and run the command "tvservice -s" the answer is as you say "state 0x400000 [LCD], 800x480 @ 60.00Hz, progressive". But if I disconnect the power of the display alone and relaunch the control command I get the same answer.
Is there an alternative command to identify correct operation in real time without restarting the rasp? Thanks in advance.
