jacobthefox
How to reduce the price of this?
Tue Dec 18, 2018 9:00 pm
Hi, so I'm looking into doing my first raspberry pi project, making a laptop. I've put together all the parts I should need, but it's come up to £140 which is quite hefty. That isn't even including the case which'll probably add another £20.
Is there anyway to reduce the price of this? The arduino is for a trackpad modification. Here's the amazon list link:
http://amzn.eu/41m6tMj
Thanks.
Imperf3kt
Re: How to reduce the price of this?
Tue Dec 18, 2018 10:56 pm
We're sorry. The Web address you entered is not a functioning page on our site.
Whatever your list contains, it sounds about right price wise. Not much you can do, the Pi is cheap, accessories are not.
55:55:44:44:4C
52:4C:52:42:41
Rose tinted glasses are difficult to see through.
jacobthefox
Wed Dec 19, 2018 8:42 am
Okay, thanks.
Wed Dec 19, 2018 9:01 am
Thanks.
To put into perspective see:
https://cpc.farnell.com/pi-top/pt01-gy- ... dp/SC14385
https://www.argos.co.uk/product/8086923
Thinking outside the box is better than burying your head in the sand...
bensimmo
Wed Dec 19, 2018 9:19 am
The Amazon link doesn't work for me, but look at the China sites, AliExpress, Banggood etc.
Or find scrap parts from other things.
Imperf3kt
Wed Dec 19, 2018 6:41 pm
Thanks.
The pi-top mentions not including a Pi.
It also states it contains hazardous material!?
I assume this just means the battery, but...
55:55:44:44:4C
52:4C:52:42:41
mooblie
Wed Dec 19, 2018 6:54 pm
This is an interesting alternative project:
https://makezine.com/projects/build-ras ... ur-pocket/
It makes a Pi-powered computer in a clam-shell case the size of a pack of playing cards when shut.
I wouldn't underestimate the wide range of different skills needed though. It will, of course, void any warranty on any parts you use too, including the Pi. More a novel idea, than a realistic practical computer. But it might give you some ideas.
Fun nevertheless!
Imperf3kt
Wed Dec 19, 2018 7:24 pm
Fun nevertheless!
Note the choice of a Pi2b.
This kind of project will not work for any Pi 3 model, so if the processing power of a Pi3B, 3B+ or even 3A+ is desirable, this project cannot be done.
That may change with the Pi4, but we will just have to wait for it to exist first.
55:55:44:44:4C
52:4C:52:42:41
DarkPlatinum
Contact: YouTube
Wed Dec 19, 2018 7:30 pm
1. Raspberry Pi 3B+ £35
2. Screen £50-60? (not sure as what size you want)
3. Cheap keyboard plus trackpad £8 max https://www.ebay.co.uk/itm/UK-Wireless- ... :rk:2:pf:0
4. Case £20
5. Anything else?
Total around £130 or so
1 * Raspberry Pi Zero W, 1 * Raspberry Pi 2, 1 * Raspberry Pi 3, 1 * Raspberry Pi 3B+, 1 * Raspberry Pi 4B :mrgreen:
Imperf3kt
Wed Dec 19, 2018 8:33 pm
4. Case £20
5. Anything else?
Do you install the operating system on recycled cardboard?
How do you power it?
Does the screen work via WiFi?
Add to list:
Power supply
Micro SD card
HDMI cable
55:55:44:44:4C
52:4C:52:42:41
jacobthefox
Thu Dec 20, 2018 10:44 am
Whoa, didn't see all of these replies. Here's the part list:
Raspberry pi 3 B+
5 inch screen (£30)
Folding keyboard (Keeping form factor down)
2500mah Adafruit lipo
Adafruit charger
I've already got a microsd card and HDMI cable. I'm thinking of getting the case custom 3d printed, which will be expensive, I'm aware.
DarkPlatinum
Contact: YouTube
Thu Dec 20, 2018 7:31 pm
Funny you should say that, because I doo on't
£8 for micro sd
£4 for hdmi
10000mah battery (not sure as I don't think you can buy one of this capacity)
DarkPlatinum
Contact: YouTube
Thu Dec 20, 2018 7:37 pm
Adafruit charger
Are you powering the screen with the lipo as well? If so, your not going to have a good amount of time to use your Pi.
Based on this site: https://spellfoundry.com/raspberry-pi-b ... alculator/
I am guessing your Pi should get around 4 and a half hours time without the screen being powered from the battery. It might just be best for you to get a seperate 10000mAh powerbank to power your screen
HawaiianPi
Thu Dec 20, 2018 8:13 pm
If your goal is to learn something and get DIY experience, then go for it.
If your goal is to have an inexpensive portable computer, get a cheap Chromebook. It will cost less and be a much more functional device.
bensimmo
Thu Dec 20, 2018 8:37 pm
For ease, go for a 10 or 20Ah all in one battery. Take the case of and you'll have a double cell LiPo layout, a power on/off button a charger and two USB power out's (something similar to that). One output for the Pi at 2/2.5A and one for the screen if needed.
be about £15/£20 from Amazon depending on deal.
It'll save you from the charger, the 5V booster and you'll get a lot longer run time (for more weight and size though)
Imperf3kt
Thu Dec 20, 2018 8:45 pm
At the expense of being unable to use it while charging and being unsure if the regulator actually supplies the current it states.
Hint: most don't. They're usually constructed from the cheapest possible equipment that gets the job done satisfactorily. Since that job is supposed to be charging a mobile phone battery, maintaining a stable 5 volts is very low on the priority list. As long as it doesn't dip below 4.35v, it's fine... For phone charging, but not powering a Pi which does not like going below 4.65v
55:55:44:44:4C
52:4C:52:42:41
bensimmo
Fri Dec 21, 2018 10:07 am
My Amazon and Aukey all work fine, I can only go off my experience.
These aren't Poundland bargains.
Most the lipo convertor will only get to 1A, which is not really the best for this project.
