Gavinmc42
OpenGL tests
Tue Dec 18, 2018 11:58 am
I have been using Gentoo64 on Pi3B+'s which is using Eric's OpenGL driver.
Most of the Mesa3D demos seem to run.
ftp://ftp.freedesktop.org/pub/mesa/demos/
Comparing Browsers running WebGL was interesting.
Gentoo64 is now good enough to run Firefox and Chromium at the same time.
viewtopic.php?f=63&t=208314&start=250
Benchmarking Browsers does not benchmark OpenGL.
The Mesa demos come with an objviewer :D
Once the missing alpine skybox images are googled and found you end up with a rotating bunny image floating in mountains.
Celeron core duo 60fps, Gentoo64 25fps.
Swapping the GreatLakesBiplaneHP for the bunny starts to chug the PC - 37fps.
But it does horrible things to Gentoo64, fell over the bleeding edge of current Pi capability ;)
So too many vertices 142305, triangles 283266... is the limit 65K?
Testing utilities :D
https://www.mesa3d.org/utilities.html
llvmpipe - uses LLVM for x86 JIT code generation and is multi-threaded
https://www.mesa3d.org/systems.html
I think I saw something about LLVM JIT compiling in the WebGL stuff for Chromium, is that one of the tricks used for WebGL speed on x86?
I'm dancing on Rainbows.
Gavinmc42
Re: OpenGL tests
Sat Dec 29, 2018 8:50 am
Trying to test OpenGL on Raspbian.
Got latest 4.14 lite desktop version of Raspbian and glxgears was very jittery.
Thought I would try 4.19 kernel, did sudo BRANCH=next raspi-update
Enabled OpenGL via raspi-config after it booted, rebooted and got black screen on boot.
Is there a new trick for OpenGL driver enabling or does raspi-config break it?
Return to “Graphics programming”
