raphaelruet
CM3 fails to boot fsarchiver-backed system
Tue Dec 18, 2018 9:53 am
I've got an issue while trying to restore a CM3 system backup. The backup and restoration process are executed without errors but the CM3 fails at booting. As I'm using several CM3 with embedded EMMC, I used usbboot/rpiboot utility to mount EMMC partitions to my ubuntu machine. I then used fsarchiver to create a backup of my running system using the following command :
sudo fsarchiver savefs cm3_backup_20181218.fsa /dev/sdb1 /dev/sdb2
This is supposed to create a backup of both partition, FAT32 boot partition and EXT4 rootfs one.
So far the process is runs properly. Using again rpiboot on a new CM3 with EMMC, I created the two required partitions (boot/rootfs) using gparted. For the backup restoration, the command used for fsarchiver was the following one :
sudo fsarchiver restfs cm3_backup_20181218.fsa id=0,dest=/dev/sdb1 id=1,dest=/dev/sdb2
Unfortunately, the CM3 doesn't boot as expected and is stuck. Here is the boot trace :
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.87-v7+ (pi@raspberrypi) (gcc version 6.3.0 20170516 (Raspbian 6.3.0-18+rpi1+deb9u1)) #1 SMP Wed Dec 12 10:37:34 GMT 2018
[    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi Compute Module 3 Rev 1.0
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] cma: Reserved 8 MiB at 0x3ac00000
[    0.000000] percpu: Embedded 17 pages/cpu @ba349000 s38668 r8192 d22772 u69632
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 240555
[    0.000000] Kernel command line: bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:C5:85:A5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=PARTUUID=80fc31e3-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 940236K/970752K available (7168K kernel code, 576K rwdata, 2076K rodata, 1024K init, 697K bss, 22324K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
[    0.000000]     lowmem  : 0x80000000 - 0xbb400000   ( 948 MB)
[    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB)
[    0.000000]       .text : 0x80008000 - 0x80800000   (8160 kB)
[    0.000000]       .init : 0x80b00000 - 0x80c00000   (1024 kB)
[    0.000000]       .data : 0x80c00000 - 0x80c900fc   ( 577 kB)
[    0.000000]        .bss : 0x80c980cc - 0x80d468a0   ( 698 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 25203 entries in 74 pages
[    0.000000] Hierarchical RCU implementation.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000021] Switching to timer-based delay loop, resolution 52ns
[    0.000268] Console: colour dummy device 80x30
[    0.000802] console [tty1] enabled
[    0.000836] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.000876] pid_max: default: 32768 minimum: 301
[    0.001192] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001224] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002180] Disabling memory control group subsystem
[    0.002270] CPU: Testing write buffer coherency: ok
[    0.002686] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.003101] Setting up static identity map for 0x100000 - 0x10003c
[    0.003236] Hierarchical SRCU implementation.
[    0.003918] smp: Bringing up secondary CPUs ...
[    0.004653] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.005431] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.006195] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.006298] smp: Brought up 1 node, 4 CPUs
[    0.006371] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.006393] CPU: All CPU(s) started in HYP mode.
[    0.006411] CPU: Virtualization extensions available.
[    0.007349] devtmpfs: initialized
[    0.016823] random: get_random_u32 called from bucket_table_alloc+0x100/0x254 with crng_init=0
[    0.017488] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[    0.017721] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.017765] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.018356] pinctrl core: initialized pinctrl subsystem
[    0.019092] NET: Registered protocol family 16
[    0.021684] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.026241] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.026274] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.026478] Serial: AMBA PL011 UART driver
[    0.028103] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.058460] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb813000, dmachans=0x1
[    0.059872] SCSI subsystem initialized
[    0.060217] usbcore: registered new interface driver usbfs
[    0.060286] usbcore: registered new interface driver hub
[    0.060384] usbcore: registered new device driver usb
[    0.070084] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-11-04 16:31
[    0.071378] clocksource: Switched to clocksource arch_sys_counter
[    0.146972] VFS: Disk quotas dquot_6.6.0
[    0.147082] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.147282] FS-Cache: Loaded
[    0.147493] CacheFiles: Loaded
[    0.156103] NET: Registered protocol family 2
[    0.156830] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.156958] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.157160] TCP: Hash tables configured (established 8192 bind 8192)
[    0.157305] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.157366] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.157603] NET: Registered protocol family 1
[    0.158077] RPC: Registered named UNIX socket transport module.
[    0.158101] RPC: Registered udp transport module.
[    0.158120] RPC: Registered tcp transport module.
[    0.158139] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.159613] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    0.162307] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    0.169862] FS-Cache: Netfs 'nfs' registered for caching
[    0.170466] NFS: Registering the id_resolver key type
[    0.170510] Key type id_resolver registered
[    0.170530] Key type id_legacy registered
[    0.170559] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.172520] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.172677] io scheduler noop registered
[    0.172699] io scheduler deadline registered (default)
[    0.172880] io scheduler cfq registered
[    0.172901] io scheduler mq-deadline registered
[    0.172921] io scheduler kyber registered
[    0.175557] BCM2708FB: allocated DMA memory fad10000
[    0.175602] BCM2708FB: allocated DMA channel 0 @ bb813000
[    0.183375] Console: switching to colour frame buffer device 82x26
[    0.190592] bcm2835-rng 3f104000.rng: hwrng registered
[    0.192704] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[    0.197121] vc-sm: Videocore shared memory driver
[    0.199349] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    0.212543] brd: module loaded
[    0.222965] loop: module loaded
[    0.224908] Loading iSCSI transport class v2.0-870.
[    0.227486] libphy: Fixed MDIO Bus: probed
[    0.229509] usbcore: registered new interface driver lan78xx
[    0.231525] usbcore: registered new interface driver smsc95xx
[    0.233358] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.263065] dwc_otg 3f980000.usb: base=0xf0980000
[    0.465118] Core Release: 2.80a
[    0.466964] Setting default values for core params
[    0.468878] Finished setting default values for core params
[    0.671061] Using Buffer DMA mode
[    0.673001] Periodic Transfer Interrupt Enhancement - disabled
[    0.675025] Multiprocessor Interrupt Enhancement - disabled
[    0.677035] OTG VER PARAM: 0, OTG VER FLAG: 0
[    0.679007] Dedicated Tx FIFOs mode
[    0.681267] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xbad04000 dma = 0xfad04000 len=9024
[    0.685162] FIQ FSM acceleration enabled for :
[    0.685162] Non-periodic Split Transactions
[    0.685162] Periodic Split Transactions
[    0.685162] High-Speed Isochronous Endpoints
[    0.685162] Interrupt/Control Split Transaction hack enabled
[    0.694428] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x805eece4
[    0.696344] WARN::hcd_init_fiq:460: FIQ ASM at 0x805ef03c length 36
[    0.698229] WARN::hcd_init_fiq:486: MPHI regs_base at 0xf0006000
[    0.700188] dwc_otg 3f980000.usb: DWC OTG Controller
[    0.702139] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    0.704119] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[    0.706086] Init: Port Power? op_state=1
[    0.707989] Init: Power Port (0)
[    0.710025] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.711994] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.713939] usb usb1: Product: DWC OTG Controller
[    0.715839] usb usb1: Manufacturer: Linux 4.14.87-v7+ dwc_otg_hcd
[    0.717760] usb usb1: SerialNumber: 3f980000.usb
[    0.720244] hub 1-0:1.0: USB hub found
[    0.722146] hub 1-0:1.0: 1 port detected
[    0.724635] usbcore: registered new interface driver usb-storage
[    0.726589] mousedev: PS/2 mouse device common for all mice
[    0.728470] IR NEC protocol handler initialized
[    0.730301] IR RC5(x/sz) protocol handler initialized
[    0.732183] IR RC6 protocol handler initialized
[    0.734025] IR JVC protocol handler initialized
[    0.735784] IR Sony protocol handler initialized
[    0.737548] IR SANYO protocol handler initialized
[    0.739313] IR Sharp protocol handler initialized
[    0.740996] IR MCE Keyboard/mouse protocol handler initialized
[    0.742725] IR XMP protocol handler initialized
[    0.745071] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[    0.747088] bcm2835-cpufreq: min=600000 max=1200000
[    0.749216] sdhci: Secure Digital Host Controller Interface driver
[    0.751014] sdhci: Copyright(c) Pierre Ossman
[    0.753139] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[    0.755064] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.757306] ledtrig-cpu: registered to indicate activity on CPUs
[    0.759246] hidraw: raw HID events driver (C) Jiri Kosina
[    0.761230] usbcore: registered new interface driver usbhid
[    0.763177] usbhid: USB HID core driver
[    0.765651] vchiq: vchiq_init_state: slot_zero = bad80000, is_master = 0
[    0.769020] [vc_sm_connected_init]: start
[    0.777868] [vc_sm_connected_init]: end - returning 0
[    0.780337] Initializing XFRM netlink socket
[    0.782282] NET: Registered protocol family 17
[    0.784318] Key type dns_resolver registered
[    0.786679] Registering SWP/SWPB emulation handler
[    0.789221] registered taskstats version 1
[    0.796961] uart-pl011 3f201000.serial: cts_event_workaround enabled
[    0.799100] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[    1.803015] console [ttyAMA0] enabled
[    1.810642] sdhost: log_buf @ bad07000 (fad07000)
[    1.891403] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    1.899887] of_cfs_init
[    1.904431] of_cfs_init: OK
[    1.909552] Waiting for root device PARTUUID=80fc31e3-02...
[    1.977858] mmc0: new high speed MMC card at address 0001
[    1.985642] mmcblk0: mmc0:0001 4FPD3R 3.64 GiB
[    1.992193] mmcblk0boot0: mmc0:0001 4FPD3R partition 1 4.00 MiB
[    2.000247] mmcblk0boot1: mmc0:0001 4FPD3R partition 2 4.00 MiB
[    2.008221] mmcblk0rpmb: mmc0:0001 4FPD3R partition 3 512 KiB
[    2.017292]  mmcblk0: p1 p2
Thanks for your answers, have a good day !
Raphael
PhilE
Re: CM3 fails to boot fsarchiver-backed system
Tue Dec 18, 2018 10:21 am
I would guess the answer lies in this line:
Raspbian is now using partition UUIDs to select the root filesystem volume, rather than devices IDs like /dev/sdb1. As I understand it these partition UUIDs are initialised at first boot, and are essentially globally unique.
Partition UUIDs are stored in the partition table (a small area at the start of the disk/SD card), not in the partitions themselves. This means that when you copy the partition contents to another CM it gets the partition ID of the target CM, not the source. If one of the copied partitions includes the kernel command line (cmdline.txt) with a reference to the source partition UUID then it will become invalid on the target CM. When you boot the target CM the kernel will wait until it sees the relevant partition, for example on an inserted USB memory stick.
You have a few options as to how to solve the problem:
1) Change cmdline.txt to refer to the device rather than the PARTUUID, e.g. "root=/dev/mmcblk0p2".
2) Modify cmdline.txt to refer to the correct PARTUUID for the target, which can be read using the "blkid" command (and several others).
3) Change the partition UUID on the target to match the source data, which you can do using the "tune2fs" command:
# tune2fs /dev/sdb1 -U <uuid>
4) [A superset of 3] Copy and restore the whole partition table.
raphaelruet
Wed Dec 19, 2018 1:16 pm
Thanks PhilE, your analysis is correct !
Return to “Compute Module”
