Pancho88
WSD scripts a modified pigpio library
Mon Dec 17, 2018 3:27 pm
Hello everyone.
Refer to Other Programmimg Languages sub-forum, topic Yet Another Programming
Language Nov 4, 2018, for more information on WSD.
There are two programming efforts. One is to build the Dynamic Libraries.
Two is to script those libraries.
I modified the pigpio library into a "Lite" shared object version. Making it
available for WSD scripting.
Here is a conversion of a Python 7segment to a WSD 7segment script.
c$=chr(10)
import xmath
if err then print errmsg & c$ : end
import xpigpio
r$=xpigpio.init()
' *** Set all used gpios as outputs. ***
' This defines which gpios are connected to which segments
'          a   b   c   d   e   f   g  dp
'SEG2GPIO=[ 4, 17, 18, 22, 23, 10, 24,  9]
dim i1(7)
i1(0)=4 : i1(1)=17 : i1(2)=18 : i1(3)=22 : i1(4)=23 : i1(5)=10 : i1(6)=24 : i1(7)=9
for i=0 to 7
   r$=xpigpio.do(0, i1(i), 1)  'CMD_MODES, PI_OUTPUT 1
next
'This defines the gpio used to switch on a LED
'          1   2   3   4   5
'LED2GPIO=[ 5,  6,  7,  8, 11]
dim i2(4)
i2(0)=5 : i2(1)=6 : i2(2)=7 : i2(3)=8 : i2(4)=11:
for i=0 to 4
   r$=xpigpio.do(0, i2(i), 1)  'CMD_MODES, PI_OUTPUT 1
next
'showing
dim i3(4)
dim S1(25)
S1(0)=" : 0b00000000:0"
S1(1)="0: 0b11111100:252"
S1(2)="1: 0b01100000:96"
S1(3)="2: 0b11011010:218"
S1(4)="3: 0b11110010:242"
S1(5)="4: 0b01100110:102"
S1(6)="5: 0b10110110:182"
S1(7)="6: 0b00111110:62"
S1(8)="7: 0b11100000:224"
S1(9)="8: 0b11111110:254"
S1(10)="9: 0b11100110:230"
S1(11)="A: 0b11101110:238"
S1(12)="b: 0b00111110:62"
S1(13)="C: 0b10011100:156"
S1(14)="c: 0b00011010:26"
S1(15)="d: 0b01111010:122"
S1(16)="E: 0b10011110:158"
S1(17)="F: 0b10001110:142"
S1(18)="H: 0b01101110:110"
S1(19)="h: 0b00101110:46"
S1(20)="L: 0b00011100:28"
S1(21)="l: 0b01100000:96"
S1(22)="O: 0b11111100:252"
S1(23)="o: 0b00111010:58"
S1(24)="P: 0b11001110:206"
S1(25)="S: 0b10110110:182"
char=1
wid=0
Refresh=100000
goto loop:
upd_display:
    zchar$=parse(bin$, ":", 1)
    s$=""
    for led=0 to 4
        segments = i3(led)
        on=0 : off=0
        for l=0 to 4
            ix=xmath.lshift(1, i2(l))
            if l=led then
                on=on OR ix
            else
                off=off OR ix
            endif
        next
        for b=0 to 7
            ix=xmath.lshift(1, i1(b))
            if segments and xmath.lshift(1, [7-b]) then
                on=on OR ix
            else
                off=off OR ix
            endif
        next
        s$=s$ & on & "," : s$=s$ & off & "," : s$=s$ & Refresh & ";"
    next
    print zchar$ & " " & s$ & c$ & c$
    r$=xpigpio.do(28, s$)   'CMD_WVAG gpioWaveAddGeneric
    nwid=xpigpio.do(49)     'CMD_WVCRE gpioWaveCreate
    r$=xpigpio.do(52, nwid) 'CMD_WVTXR gpioWaveTxSend
    if wid>0 then r$=xpigpio.do(50, wid)    'CMD_WVDEL delete no longer used waveform
    'print "wid" & wid & " new_wid" & new_wid
    wid = new_wid
    return
loop:
    if char>25 then goto exit:
    for i=0 to 4
        LED=i
        gosub display:
    next
    gosub upd_display:
    char=char + 1
    sleep 2000  '2 seconds
    goto loop:
exit:
    print "***" & c$
    end
display:
    bin$=S1(char)
    xchar$=parse(bin$, ":", 3)
    i3(LED)=val(xchar$)
    return
All comments are welcome.
Pancho88
Re: WSD scripts a modified pigpio library
Thu Dec 27, 2018 6:31 pm
Hello everyone
Three more commands have been added to a modified pigpio library.
xpigpio.do(CMD_SAF, gpio) 'CMD_SAF=117 gpioSetAlertFunc
xpigpio.do(CMD_ISR, gpio, ...) 'CMD_ISR=118 gpioSetISRFunc
xpigpio.do(CMD_STF, gpio, xid, xmillis) 'CMD_STF=119 gpioSetTimerFunc
Unable to test the first 2 functions, have a Rpi zerow with no devices.
Tested the Timer function with no problem.
All these functions are callbacks, and work very similar.
Pancho88
Mon Jan 07, 2019 10:22 pm
Hello everyone
Here is a conversion of a C program freq_count_1.c to a WSD script freqcnt1.sd
c$=chr(10)
import xmath
import xpigpio
OPT_P_MIN=1
OPT_P_MAX=1000
OPT_P_DEF=20
OPT_R_MIN=1
OPT_R_MAX=300
OPT_R_DEF=10
OPT_S_MIN=1
OPT_S_MAX=10
OPT_S_DEF=5
g_opt_p = OPT_P_DEF
g_opt_r = OPT_R_DEF
g_opt_s = OPT_S_DEF
g_opt_t = 0
DIM i1(32)          'g_gpio[MAX_GPIOS]
DIM i2(32)          'g_reset_counts
DIM s1(32)          'g_gpio_data
    'l_gpio_data
dim i3(32)  'first tick
dim i4(32)  'last tick
dim i5(32)  'pulse_count
        'command line parameters
        'wsdvm0 freqcnt1 4 7 8 9 r10 s1 p2
    ngpios = 0 : g_mask=0
    for i=0 to 9
        n=val(arg(i))
        if err then
            i=9
        else
            if n=0 then
                par$=mid(arg(i), 1, 1)
                r=val(mid(arg(i), 2))
                opt=0
                if par$="p" then
                    if r >= OPT_P_MIN and  r <= OPT_P_MAX then
                        g_opt_p = r
                    else
                        print "invalid -p option (" & r & ")" & c$ : end
                    endif
                    g_opt_t = 1
                    opt=1
                endif
                if par$="r" then
                    if r >= OPT_R_MIN and r <= OPT_R_MAX then
                        g_opt_r = r
                    else
                        print "invalid -r option (" & r & ")" & c$ : end
                    endif
                    opt=1
                endif
                if par$="s" then
                    if r >= OPT_S_MIN and r <= OPT_S_MAX then
                        g_opt_s = r
                    else
                        print "invalid -s option (" & r & ")" & c$ : end
                    endif
                    opt=1
                endif
                if opt=0 then print par$ & " not a valid option" & c$ : end
            else
                if n>32 then print n & " not a valid g_gpio number" & c$ : end
                i1(ngpios) = n      'g_gpio
                ngpios=ngpios + 1
                ix=xmath.lshift(1, n)
                g_mask= g_mask or ix
            endif
        endif
    next
    if ngpios=0 then print "At least one gpio must be specified" & c$ : end
    print "Monitoring gpios"
    for i=0 to ngpios-1
        print " " & i1(i)       'g_gpio
    next
    print c$ & "Sample rate " & g_opt_s & " micros, refresh rate " & g_opt_r & " deciseconds" & c$
    'gpioCfgClock(g_opt_s, 1, 1)
    if g_opt_s = OPT_S_DEF then
        r$=xpigpio.init()
    else
        x$="s" & g_opt_s
        r$=xpigpio.init(x$)
    endif
    r$=xpigpio.do(27)                          'CMD_WVCLR=27 gpioWaveClear()
    s$=g_mask & "," & "0" & "," & g_opt_p & ";"
    s$=s$ & "0" & "," & g_mask & "," & g_opt_p & ";"
    r$=xpigpio.do(28, s$)                   'CMD_WVAG=28 gpioWaveAddGeneric
    wave_wid=xpigpio.do(49)                 'CMD_WVCRE=49 gpioWaveCreate
            'monitor g_gpio level changes
    for i=0 to ngpios-1
        r$=xpigpio.do(117, i1(i))       'CMD_SAF=117 gpioSetAlertFunc i1=g_gpio
    next
    mode = 0    'PI_INPUT
    if g_opt_t>0 then
        r$=xpigpio.do(52, nwid)     'CMD_WVTXR gpioWaveTxSend PI_WAVE_MODE_REPEAT
        mode = 1    'PI_OUTPUT
    endif
    for i=0 to ngpios-1
        r$=xpigpio.do(0, i1(i), mode)   'CMD_MODES gpioSetMode i1=g_gpio
    next
loop:
    if x>=5 then end                    'Set a Limit for Testing
        'gpioDelay(g_opt_r * 100000);
    r$=xpigpio.do(46, g_opt_r * 100000)    'CMD_MICS=46 myGpioDelay
    for i=0 to ngpios-1
        g = i1(i)          'i1=g_gpio
        s1(g)=i3(g) & "," i4(g) & "," i5(g)
            /*diff = g_gpio_data[g].last_tick - g_gpio_data[g].first_tick;*/
        diff=i4(g) - i3(g)
            'tally = g_gpio_data[g].pulse_count;
        tally=i5(g)
        if diff=0 then diff = 1
        i2(g) = 1
        r=1000000.0 * tally / diff
        print "g=" & g & " " & r & " " & tally & " " & diff & c$
    next
    x=x+1
    goto loop:
cback:
        'edges
    p0=val(arg(0))  'gpio
    p1=val(arg(1))  'level
    p2=val(arg(2))  'tick
    i4(p0)=p2       'last tick
    if p1=1 then i5(p0)=i5(p0)+1    'level=1 then pulse count up by 1
    if i2(p0)>0 then
        i3(p0)=p2   'first tick
        i5(p0)=0    'pulse count
    endif
Bye
