I received a promotional box from Dell, which when you opened it, played a commercial. Naturally, I took it apart to salvage some of the electronics out of it.
I wanted to use the display with a Raspberry Pi. But the ribbon sizes differ. The Ribbon on the display is 50 pins. I found the display at:
https://pt.aliexpress.com/item/Alta-qua ... 39978.html
Is there an adapter that can reduce the pins to the Raspberry Pi or to an HDMI?
Thanks for any help.
