I also using the GPIO13 (GPIO.setup( 13, GPIO.IN, pull_up_down = GPIO.PUD_UP )) for push-button.
For the counter, I added the limit switch between the GPIO20(20, GPIO.IN, pull_up_down = GPIO.PUD_UP) and Ground.
When limit switch triggers the circuit get close between GPIO20 and GROUND and program counter increases.
I have used the internal pull-up register for both GPIO13 and GPIO20.
Everything was working fine before adding the Limit switch and GPIO20 as a pull-up. But when I added this logic for counter then it works well for
1-2 days, after that raspberry pi getting heated and getting dead.
This script runs when my Pi boots up every time.
I'm not getting what's going wrong with the above.
#!/usr/bin/env python
import time
import math
import subprocess
import RPi.GPIO as GPIO
import sys
import sqlite3
from sqlite3 import Error
from os import system
import json
import urllib3
from urllib3.exceptions import RequestError
from urllib3.exceptions import ResponseError
from urllib3.exceptions import TimeoutError
from urllib3.exceptions import HTTPError
from urllib3.exceptions import ConnectionError
from urllib3.exceptions import ConnectTimeoutError
from urllib3.exceptions import HTTPWarning
from urllib3.exceptions import SecurityWarning
from urllib3.exceptions import PoolError
#Actual Machine ID from main Database
#Mechanical Press 60 Ton
machineID = 1
#Machine Ideal time in Seconds
idealTime = 5
http = urllib3.PoolManager()
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BCM)
#change these as desired - they're the pins connected from the
#SPI port on the ADC to the Cobbler
SPICLK = 18
SPIMISO = 23
SPIMOSI = 24
SPICS = 25
# set up the SPI interface pins
GPIO.setup(SPIMOSI, GPIO.OUT)
GPIO.setup(SPIMISO, GPIO.IN)
GPIO.setup(SPICLK, GPIO.OUT)
GPIO.setup(SPICS, GPIO.OUT)
#Setting pin 13 for button input
#Dieset Red LED
GPIO.setup( 26, GPIO.OUT)
#For GREEN LED Status
GPIO.setup( 19, GPIO.OUT )
#GPIO input signal
GPIO.setup( 20, GPIO.IN, pull_up_down = GPIO.PUD_UP )
GPIO.remove_event_detect(20)
mcStatus = 0
machineStroke = 0
lastTime = 0
currentTime = 0
isIdeal = False
isMachineStateChange = False
global mcLastOnOff
global mcLastDieset
global mcLastIdeal
global mcLastStamp
# read SPI data from MCP3008 chip, 8 possible adc's (0 thru 7)
def readadc(adcnum, clockpin, mosipin, misopin, cspin):
if ((adcnum > 7) or (adcnum < 0)):
return -1
GPIO.output(cspin, True)
GPIO.output(clockpin, False) # start clock low
GPIO.output(cspin, False) # bring CS low
commandout = adcnum
commandout |= 0x18 # start bit + single-ended bit
commandout <<= 3 # we only need to send 5 bits here
for i in range(5):
if (commandout & 0x80):
GPIO.output(mosipin, True)
else:
GPIO.output(mosipin, False)
commandout <<= 1
GPIO.output(clockpin, True)
adcout = 0
# read in one empty bit, one null bit and 10 ADC bits
for i in range(12):
adcout <<= 1
if (GPIO.input(misopin)):
adcout |= 0x1
adcout >>= 1 # first bit is 'null' so drop it
return adcout
def readCTSensor(ADC_CH):
vRMS = 70.0 # Assumed or measured old 116.0
offset = 1.65 # Half the ADC max voltage
numTurns = 2000 # 1:2000 transformer turns
rBurden = 3300 # Burden resistor value
numSamples = 50 # Number of samples before calculating RMS
# if DEBUG:
# print "\nCT Sensor number of turns:", numTurns
# print "Actual burden resistor:", rBurden, "ohm"
# print "Number of samples:", numSamples
# print "AC (RMS Voltage):", vRMS, "V"
voltage = 0.0
iPrimary = 0.0
acc = 0.0
apparentPower = 0.0
# Take a number of samples and calculate RMS current
for i in range(0, numSamples):
# Read ADC, convert to voltage, remove offset
sample = readadc(ADC_CH, SPICLK, SPIMOSI, SPIMISO, SPICS)
voltage = (sample * offset * 2) / 1024
voltage = voltage - offset
iPrimary = (voltage / rBurden) * numTurns
acc += pow(iPrimary, 2)
time.sleep(0.001)
iRMS = math.sqrt(acc / numSamples) # Calculate RMS from accumulated values
apparentPower = vRMS * iRMS # Calculate apparent power
return iRMS, apparentPower
def create_connection(db_file):
try:
conn = sqlite3.connect(db_file,20000, isolation_level = None)
#Set journal mode to WAL.
conn.execute('pragma journal_mode=wal')
return conn
except Error as e:
GPIO.cleanup()
print("DB Err in MAIN",e)
return None
def main():
#GPIO Callback for breaking the Ideal Status
def stroke_callback(channel):
global lastTime
if(isIdeal == True):
lastTime = time.time()
global mcStatus
global machineStroke
dieSetNotified = 0
isTimeUpdated = False
global lastTime
global currentTime
global isIdeal
global isMachineStateChange
isStroke = False
GPIO.add_event_detect(20, GPIO.BOTH, callback = stroke_callback, bouncetime = 1000)
database_path = "/home/pi/Desktop/main_production/machine_database.db"
#create a database connection
conn = create_connection(database_path)
cur = conn.cursor()
sqlQuery = '''INSERT INTO machine_log (MachineId, MachineStatus, MachineStroke, Amp, DieSet, TimeStamp) VALUES(?,?,?,?,?,?)'''
sqlQueryState = '''UPDATE machine_state SET OnOFF = ?, Dieset = ?, Ideal = ?, TimeStamp = ? WHERE ID = ?'''
#Get Machine last status from database
cur.execute("SELECT * FROM machine_state")
rows = cur.fetchall()
for row in rows:
mcLastOnOff = row[1]
mcLastDieset = row[2]
mcLastIdeal = row[3]
mcLastStamp = row[4]
print('Last OnOff ', mcLastOnOff)
print('Last Dieset ', mcLastDieset)
print('Last Ideal ', mcLastIdeal)
print('Last TimeStamp ', mcLastStamp)
if(mcLastOnOff == 1 and mcLastDieset == 0 and mcLastIdeal == 1):
try:
#Ending machine Idle Status
machineLogs = (machineID, 7, machineStroke, 0.0, mcLastDieset, mcLastStamp + 2.0)
cur.execute(sqlQuery, machineLogs)
#Setting machine to OFF
machineLogs = (machineID, 2, machineStroke, 0.0, mcLastDieset, mcLastStamp + 3.0)
#Updating the current machine state
machineStateLogs = (0, 0, 0, mcLastStamp + 3.0, 1)
cur.execute(sqlQueryState, machineStateLogs)
conn.commit()
#Catch the exception
except Exception as e:
#Roll back any change if something goes wrong
print("Database Exception In MAIN First elif",e)
print(time.time())
conn.rollback()
elif(mcLastOnOff == 1 and mcLastDieset == 0 and mcLastIdeal == 0):
try:
machineLogs = (machineID, 2, machineStroke, 0.0, mcLastDieset, mcLastStamp + 1.0)
machineStateLogs = (0, 0, 0, mcLastStamp + 1.0, 1)
conn.commit()
print("Database Exception In MAIN Second elif",e)
print(time.time())
conn.rollback()
elif(mcLastOnOff == 1 and mcLastDieset == 1 and mcLastIdeal == 0):
try:
machineStateLogs = (0, 1, 0, mcLastStamp + 1.0, 1)
conn.commit()
print("Database Exception In MAIN Third elif",e)
print(time.time())
conn.rollback()
#Synchronizing device time to server time for correct Timestamp
while isTimeUpdated == False:
print("Current Time : ", time.asctime(time.localtime(time.time())))
try:
response = http.request('POST','http://shreeapi.fosterbin.com/match_time.php', fields={'data': int(time.time())})
newStatus = response.status
print response.data
timeStatus = json.loads(response.data.decode('utf-8'))['matchStatus']
time.sleep(2)
except (ValueError, ResponseError, TimeoutError, HTTPError, ConnectionError, ConnectTimeoutError, HTTPWarning, PoolError) as e:
print('Conn fail!',e)
newStatus = 0
time.sleep(5)
if(newStatus == 200):
if(timeStatus == 1):
isTimeUpdated = True
#Lightning Up Green LED
GPIO.output(19,True)
if(mcLastDieset == 1):
#Lightning Up Dieset LED
GPIO.output(26,True)
elif(mcLastDieset == 0):
#Lightning Off Dieset LED
GPIO.output(26,False)
else:
print("Time not Updated !!")
else:
print("No net !!")
try:
while True:
#Getting Dieset status
isDieSetRunning = GPIO.input(13)
#Non-invasive current sensor connected to ADC #0
iRMS, apparentPower = readCTSensor(0)
#print(apparentPower)
#Machine Start >> 1
#Machine Stop >> 2
#Machine DieSet Start >> 3
#Machine DieSet Stop >> 4
#Machine Data >> 5
#Machine Ideal Start >> 6
#Machine Ideal Stop >> 7
#Getting Stroke Status
isValidStroke = GPIO.input(20)
#Machine On
if( apparentPower >= 3 and mcStatus == 0 ): #and isDieSetRunning == False ):
isMachineStateChange = True
#Changing machine status to ON
mcStatus = 1
#When Machine ON then it should not be idle
#print(lastTime)
try:
machineLogs = (machineID, 1, machineStroke, apparentPower, isDieSetRunning, time.time())
conn.commit()
conn.rollback()
print ("M On : ", machineStroke)
#Machine Valid stroke
elif( isValidStroke == False and isStroke == False and mcStatus == 1 and isDieSetRunning == False ):
machineStroke += 1
isStroke = True
try:
machineLogs = (machineID, 5, machineStroke, apparentPower, isDieSetRunning, time.time())
machineStateLogs = (mcStatus, isDieSetRunning, isIdeal, time.time(), 1)
conn.commit()
print("Database Exception In MAIN : VS",e)
print(time.time())
conn.rollback()
#When Machine producing production then it's by default not idle
#print(lastTime)
print ("VS : ", machineStroke)
elif(isValidStroke == True and isStroke == True):
isStroke = False
#Machine Off
elif( apparentPower <= 1 and mcStatus == 1 ): #and isDieSetRunning == False ):
#Changing machine status to OFF
mcStatus = 0
try:
machineLogs = (machineID, 2, machineStroke, apparentPower, isDieSetRunning, time.time())
conn.commit()
print("Database Exception In MAIN : M Off",e)
print(time.time())
conn.rollback()
print ("M Off : ", machineStroke)
if(isDieSetRunning == True and mcLastDieset == 0):
mcLastDieset = 1
machineStroke = 0
try:
machineLogs = (machineID, 3, machineStroke, apparentPower, isDieSetRunning, time.time())
conn.commit()
print("Database Exception In MAIN Second : DS Start",e)
print(time.time())
conn.rollback()
GPIO.output(26,GPIO.HIGH)
print('DS : ', isDieSetRunning)
elif(isDieSetRunning == False and mcLastDieset == 1):
mcLastDieset = 0
try:
machineLogs = (machineID, 4, machineStroke, apparentPower, isDieSetRunning, time.time())
conn.commit()
print("Database Exception In MAIN Second : DS Stop",e)
print(time.time())
conn.rollback()
GPIO.output(26,GPIO.LOW)
#When Diset off then machine should not be idle
#Get the Idle time
currentTime = time.time() - lastTime
#print(currentTime)
#print(isIdeal)
#print(mcStatus)
#print(isDieSetRunning)
if(currentTime > idealTime and isIdeal == False and mcStatus == 1 and isDieSetRunning == False):
isIdeal = True
try:
#Changing machine status to Idle
machineLogs = (machineID, 6, machineStroke, apparentPower, isDieSetRunning, lastTime + 0.1)
conn.commit()
print("Database Exception In MAIN Second : Ideal Start",e)
print(time.time())
conn.rollback()
print("M Ideal")
elif(currentTime < idealTime and isIdeal == True and mcStatus == 1 and isDieSetRunning == False ):
isIdeal = False
try:
#Changing machine status to Not Idle
machineLogs = (machineID, 7, machineStroke, apparentPower, isDieSetRunning, time.time() + 0.1)
conn.commit()
print("Database Exception In MAIN Second : Ideal Stop",e)
print(time.time())
conn.rollback()
print("M not Ideal")
elif(isIdeal == True and (isDieSetRunning == True or mcStatus == 0)):
isIdeal = False
try:
conn.commit()
print(time.time())
conn.rollback()
if(isMachineStateChange == True):
print("M Status changed !!")
print("OnOff : ",mcStatus)
print("Dieset : ",isDieSetRunning)
print("Ideal : ",isIdeal)
try:
conn.commit()
print("Database Exception In MAIN Second : M Status Change",e)
print(time.time())
conn.rollback()
system('python /home/pi/Desktop/main_production/post_with_urllib.py')
#system('python /home/pi/Desktop/main_project/post_with_requests.py')
if(isIdeal == True or isDieSetRunning == True):
print("Ideal : ",time.time())
try:
conn.commit()
print(time.time())
conn.rollback()
time.sleep(5)
except KeyboardInterrupt:
GPIO.cleanup()
print ("Interrupt at Main program")
if __name__ == '__main__':
main()
