krobiana
Clean MySQL install with errors
Wed Nov 14, 2012 11:21 am
Help needed here.
I have installed a mysql-server but it cannot run. Initially I was setting password during install and I got a configuration error so I run apt-get purge mysql-server* etc. and did a new install with no password.
When I complete however I still get the same error (attached) and there are no records in the logs to find that the issue might be. For mysql --version I get {mysql Ver 14.14 Distrib 5.5.24, for debian-linux-gnu (armv7l) using readline 6.2}
What can be the problem.
Mysql start Error
elatllat
Re: Clean MySQL install with errors
Thu Nov 22, 2012 1:23 am
dmesg?
/var/log/?
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
PowerMercers
Fri Dec 07, 2012 8:10 am
I was having the same problem too.
After the error (with password), I tried an install without that also failed.
I then tried a remove, which did not work.
I then tried a purge, and in the process, the server started successfully and was then able to query INFORMATION_SCHEMA.
It does not make sense, and I don't know how it worked.
Return to “Python”
