ping -I tun0 8.8.8.8
ping -I tun1 8.8.8.8
ping -I tun2 8.8.8.8Using these following blogs as guides, I've set my Pi up with the specified rules and routes:
Over Engineering FTW: https://www.whizzy.org/2012/03/over-engineering-ftw/
Setup Multiple Gateways and Multiple Internet Connections One Host: https://www.virtualizationhowto.com/201 ... -one-host/
Primarily using the "Over Enginerring FTW" blog as a guide as he is doing exactly what I'm wanting, just he's using physical Interfaces instead of tunnels.
However, while it connects initially to a tun, it does not appear to EVER fail over to any of the others if that tun fails (ie: no data is returned).
I've tried both of these route/nexthop commands, but neither seems to enable failover:
ip route replace default proto static scope global nexthop dev tun0 weight 3 nexthop dev tun1 weight 2 nexthop dev tun2 weight 1Code: Select all
ip route replace default scope global nexthop via 10.8.0.5 dev tun0 weight 3 nexthop via 10.9.0.5 dev tun1 weight 2 nexthop via 10.10.0.5 dev tun2 weight 1P.S. I tried leaving a comment on the ""Over Enginerring FTW" blog asking for help, but its never appeared, so I guess that page is not being monitored anymore.
Thanks!
