affrodate
Create proxy tunnels and reset dongles with PHP?
Sat Dec 08, 2018 12:20 pm
Hey there, I'm trying to think of a possible way to achieve the following:
* Connecting multiple dongles to USB Hub connected to my Raspberry, and setting up a proxy tunnel for each dongle.
* Management dashboard (PHP) that will retrieve all the dongles connected including their Model, Interface, IP, Operator, Technology (3g/4g/lte) and Signal strength.
* Being able to reboot my dongles from this web-interface and reset the connection without rebooting the dongle itself.
I've found a similar service and would really like to create a similar one, just so it will be custom for my needs.
After posting a job on a freelancing platform I understood how little I know about Raspberries and that I'd better ask here for an advice because I can't even describe the job properly.
I'm cool with PHP but have no idea how to set it up on rasp's side, like should I be using something like phpseclib to be able to send SSH commands to my rasp or is there a better solution?
Thanks in advance.
