semimemi
mount a cifs share using fstab
Fri Dec 07, 2018 12:30 pm
Hello!
I can mount a NAS folder using the command:
sudo mount -t cifs -o user=USERNAME,password=PASSWORD,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/myFolder /home/pi/myFolder
As I want to keep this folder connected I want to do the same thing using fstab. I edit the file using
sudo nano fstab
But no matter what I try - I tried many different combinations like
//192.168.0.10/myFolder /home/pi/myFolder cifs username=USERNAME,password=PASSWORD
when I run
sudo mount -a -v
I always get
/proc                    : already mounted
/boot                    : already mounted
/                        : ignored
So it seems like anything I enter in fstab is completely ignored. What am I doing wrong?
Any help is appreciated!
n67
Re: mount a cifs share using fstab
Fri Dec 07, 2018 1:31 pm
Please don't use fstab for this. It will only lead to pain & suffering.
Instead, arrange, via one of the many "How do I run something automatically on startup?" techniques, to have your mount command run automatically on startup.
It is much safer to leave fstab alone.
"L'enfer, c'est les autres"
Epmu Sn!
RaTTuS
Contact: Twitter YouTube
Fri Dec 07, 2018 1:49 pm
use systemd auto mount system - wait to after network is up
Covfefe
thagrol
Fri Dec 07, 2018 1:54 pm
Using a non fstab approach won't necessarily help. It certainly won't help when runing "sudo mount -a"
Try this in fstab:
 //192.168.0.10/myFolder /home/pi/myFolder cifs _netdev,auto,user=USERNAME,password=PASSWORD,rw,file_mode=0777,dir_mode=0777 0 0
You might want to use "uid=pi,gid=pi" in place of, or in addtions to, "file_mode=0777,dir_mode=0777"
Attempts to contact me outside of these forums will be ignored unless signed in triplicate, sent in, sent back, queried, lost, found, subjected to public enquiry, lost again, and finally buried in soft peat for three months and recycled as firelighters
semimemi
Sat Dec 08, 2018 9:59 am
All right. I am trying this using cron. I start this python script:
#!/usr/bin/python3
import ds,os,time,datetime
ds.logfile ("startup.py started")
i=0
response=1
while (response != 0):
	i+=1
	response = os.system("ping -c 1 " + "storage713")
	time.sleep (0.1)
	print ("iteration " + str(i))
ds.logfile("connected after " + str(i) + " tries")
os.system ("sudo mount -t cifs -o user=XXXX,password=XXXX,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/XXXXX")
ds.logfile("NAS connected")
My crontab entry is
@reboot sudo python /home/pi/Desktop/python/startup.py
The script works when I start it from terminal. I know it is executed also by cron because I get my log entries after booting. Still the drives do not connect when it is started by cron. How is this possible?
DirkS
Sat Dec 08, 2018 10:13 am
Please disregard @n67's comments.
There is no particular reason *not* to use fstab, although there are better methods (particularly systemd mounts)
semimemi
Sat Dec 08, 2018 10:20 am
The thing is just: I dont find good information for fstab so I'm trying a different approach. With the new apporach I feel so close to the solution so I hoped somenone might give me a hint..
DirkS
Sat Dec 08, 2018 10:36 am
See e.g. @thagrol's post above. He is one of the people I know is knowledgeable and gives good advice.
semimemi
Sat Dec 08, 2018 11:10 am
Try this in fstab:
This does not have any effect. Is there a way to debug this stuff? Because at the moment I only see that there is nothing connected after reboot.
DirkS
Sat Dec 08, 2018 11:17 am
Not sure if this works, but try
sudo systemctl status home-pi-myFolder.mount
(maybe use .automount instead of .mount)
Sat Dec 08, 2018 11:19 am
Ok, I can see some potential issues there.
#!/usr/bin/python3
My crontab entry is
Your code is set to use python3, but in the crontab you have just python, which I believe still runs python2.
The crontab has "sudo python", which will run the script as the root user, but you have another sudo command in the script. That may cause issues, I'm not sure. However, it is pointless.
How do you run it from the terminal? What command do you use?
If the script is set up as executable ("ls -l /home/pi/Desktop/python/startup.py" shows -rwxr-xr-x or something with the "x" options set), then I would use a crontab entry like
@reboot /home/pi/Desktop/python/startup.py
semimemi
Sat Dec 08, 2018 11:29 am
I can run it with just
and I can add sudo or python. Either way works in the terminal. Neither of them works with crontab.
I tried that. Same effect. I get log entries but no NAS connection:(
thagrol
Sat Dec 08, 2018 1:22 pm
After making the change to fstab I suggested above did you try "sudo mount -av" or "sudo mount /home/pi/myFolder"?
Is there anything in the share? A mount point will look the same whether or not something is mounted there if the share is empty.
Have you looked at the output from"mount" after a reboot? If the mount has succeeded it will be listed there.
Have you looked in syslog or the output of "dmesg" for errors?
Have you set your Pi/raspbian to "Wait for Network at Boot"? See the "Boot Options" section of "sudo raspi-config". It's possible that the mount is being attempted before the network is up.
Are you running your script from root's crontab? Or you user's?
Are you capturing output and errors from your python script? Jobs started via cron have all their output discarded so you have to explictly send it somewhere. Try adding "> /tmp/my_mount.log 2>&1" to the end of your crontab entry (before any trailing & if you have one). You can then examine /tmp/my_mount.log for errors. Your crontab entry will looke something like this:
@reboot /path/to/my_script.py > /tmp/my_mount.log 2>&1
Given that your script works from the terminal, my money is on the network not being ready when it's run from crontab.
thagrol
Sat Dec 08, 2018 1:29 pm
Thanks. I try to.
semimemi
Sat Dec 08, 2018 1:33 pm
You won. I added a 30seconds delay to my python script and it worked.
Now I will find a workaround checking in the script if the connection was successful and repeating it if not. This won't be too difficult. Thank you so much for your kind help!
thagrol
Sun Dec 09, 2018 5:10 am
Glad you got it working but there are some issues with your approach that you should be aware of:
  1. By using a non-standard approach (i.e. by not using fstab) you're making it hard for a third party to understand what's happening should you need someone else to administrate your Pi. Or when you come back to it in a year and have forgotten what you did.
  2. You can't use "mount -a" to mount the share.
  3. You also can't use "mount /home/pi/myFolder" or "mount //192.168.0.10/myFolder"
  4. Should you need to manually mount the share, you either have to locate and run your script or type the full mount command. Mount cannot look up the missing options in fstab.
  5. As for your script, having looked at it in more detail:
    • It shouldn't work as you've not specified a mount point in your mount command.
    • You don't need to use python, you could do it in a bash script with less overhead.
    • When started from cron, output from your print statements will be discarded.
    • If the mount fails your log will show "NAS connected"
    • You've made no provision for the case where the network never comes up or the machine that goes ping doesn't respond. In both of those cases, it will sit pinging away 10 times a second forever.
    • Adding a 30 second start delay should have made no difference. Well, except for reducing the reported number of tries.
Sorry if the above seems harsh and/or picky, I used to test software for a living and old habits die hard....
If you set "Wait for Network on Boot" in raspi-config to "Yes" and add a suitable fstab entry as I suggested above including "_netdev" it should work, it does on several of my linux boxes (yeah, yeah, I know). "_netdev" tells systemd to schedule the mount after network is up.
If you really don't want to use fstab, do as RaTTuS suggests and use a systemd mount unit.
Other options are to use fstab but backstop it with a simple entry like this is root's crontab:
@reboot	sleep 30 && mount /home/pi/myFolder
Or use the "noauto" option in fstab with the above crontab entry, your script modified to the shorter mount command, or a systemd service.
semimemi
Sun Dec 09, 2018 4:01 pm
1..4:
I am aware of these disadvantages. For me as a non expert it is nearly impossible to make this work. I spent several hours in trying to find my error but without any debugging possibility I am just bruteforcing: Combining different parameters and hoping one combination will work. I am sure if you were sitting in front of my screen you would find the error within a minute but I cannot. And I am not willing to spend another weekend in finding the solution .
5:
You are right: My script has several weaknesses. But unlike the fstab thing here I know what I am doing and I can adjust everything. Of course I will modify it in a way that makes more sense. I am already saving the log to a temp file. I write "NAS connected" only if it was successful. And I will do some more modifications like stopping after a certain number of tries etc.
And you are right, the way I posted my code it wouldn't work. Seems like I deleted an argument by accident.
The code I am using at the moment is this one:
#!/usr/bin/python3
import os,time,datetime
i=0
response=1
while response != 0:
	i+=1
	response = os.system("ping -c 1 " + "192.168.0.10")
	time.sleep (1)
success = 1
while success != 0:
	success = os.system ("sudo mount -t cifs -o user=XXXX,password=XXXX,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/XXXX /home/pi/Desktop/XXXXX")
	if success == True:
		break;
	time.sleep(1)
print("NAS connected")
thagrol
Sun Dec 09, 2018 6:06 pm
If you're happy working with those limitiations, carry on. I'd suggest a simpler python script though:
#!/usr/bin/env python3
import os, sys, time
start_delay = 0
max_retries = 5
retry_delay = 5
mount_command = 'sudo mount -t cifs -o user=XXXX,password=XXXX,rw,file_mode=0777,dir_mode=0777 //192.168.0.10/XXXX /home/pi/Desktop/XXXXX'
time.sleep(start_delay)
attempts = 0
while attempts <= max_retries and os.system(mount_command) != 0:
    attempts += 1
    time.sleep(retry_delay)
if attempts > max_retries:
    sys.exit('NAS mount failed after %s attempts.' % max_retries)
else:
    print('NAS mount succeded.')
The above is untested as my setup doesn't match yours but assuming I've not made any typos should be ok. And I dare say there are probably things I've not catered for in it too. No exception handling and should really use the subprocess module instead of os.system for two. Oh and it won't exit until retry_delay seconds after the last attempt has failed.
I've left out the ping as the mount will fail with a non-zero exit code if the network is down. sys.exit is used to both return a non-zero exit code from the script and to write an error message to stderr. That's the bit redirected by "2>" in a shell command or crontab entry.
It's the exit code of the spawned process (your mount command) that gets returned by os.system. The convention is 0 for success, non-zero for a failure, though different commands may use different values to return information about the failure.
