riverajl
Using ldrex instruction hangs
Thu Dec 06, 2018 10:28 am
Hi forum guys.
I am writing first my bare metal sw in a RPI 3B and trying to build a lock mechanism between cores using ldrex and strex instructions.
It's a simple thing only to begin. I have a issue that the ldrex instruction hangs. I don't know if it's necessary more configuration, but my code is here:
config.txt:
kernel_old=1
disable_commandline_tags=1
disable_overscan=1
framebuffer_swap=0
start:
.section ".text.startup"
.equ CPU_STACK_SIZE,0x4000
.equ IRQ_STACK_SIZE,0x4000
.equ CPU_STACK_CORE0,0x3f000000
.equ CPU_STACK_CORE1,0x3f000000-CPU_STACK_SIZE
.equ CPU_STACK_CORE2,0x3f000000-CPU_STACK_SIZE*2
.equ CPU_STACK_CORE3,0x3f000000-CPU_STACK_SIZE*3
.equ IRQ_STACK_CORE0,0x3f000000-CPU_STACK_SIZE*4
.equ IRQ_STACK_CORE1,0x3f000000-CPU_STACK_SIZE*4-IRQ_STACK_SIZE
.equ IRQ_STACK_CORE2,0x3f000000-CPU_STACK_SIZE*4-IRQ_STACK_SIZE*2
.equ IRQ_STACK_CORE3,0x3f000000-CPU_STACK_SIZE*4-IRQ_STACK_SIZE*3
.equ    CPSR_MODE_USER,         0x10
.equ    CPSR_MODE_FIQ,          0x11
.equ    CPSR_MODE_IRQ,          0x12
.equ    CPSR_MODE_SVR,          0x13
.equ    CPSR_MODE_ABORT,        0x17
.equ    CPSR_MODE_HYP,		    0x1A
.equ    CPSR_MODE_UNDEFINED,    0x1B
.equ    CPSR_MODE_SYSTEM,       0x1F
.equ    CPSR_IRQ_INHIBIT,       0x80
.equ    CPSR_FIQ_INHIBIT,       0x40
.equ    CPSR_THUMB,             0x20
.global _start
_start:
ldr pc, _reset_h
ldr pc, _undefined_instruction_vector_h
ldr pc, _software_interrupt_vector_h
ldr pc, _prefetch_abort_vector_h
ldr pc, _data_abort_vector_h
ldr pc, _unused_handler_h
ldr pc, _interrupt_vector_h
ldr pc, _fast_interrupt_vector_h
_reset_h:                           .word   _reset_
_undefined_instruction_vector_h:    .word   undefined_instruction_vector
_software_interrupt_vector_h:       .word   software_interrupt_vector
_prefetch_abort_vector_h:           .word   prefetch_abort_vector
_data_abort_vector_h:               .word   data_abort_vector
_unused_handler_h:                  .word   _reset_
_interrupt_vector_h:                .word   interrupt_vector
_fast_interrupt_vector_h:           .word   fast_interrupt_vector
_reset_:
mrc     p15, 0, r0, c0, c0, 5
ubfx    r0, r0, #0, #2
cmp     r0, #0					@ is it core 0?
beq     core0
cmp     r0, #1					@ is it core 1?
beq     core1
cmp     r0, #2					@ is it core 2?
beq     core2
cmp     r0, #3					@ is it core 3?
beq     core3
@ CPU ID is not 0..3 -
b hang
hang: b hang
core0:
ldr sp,=CPU_STACK_CORE0
mov r0, #(CPSR_MODE_IRQ | CPSR_IRQ_INHIBIT | CPSR_FIQ_INHIBIT )
msr cpsr_c,r0
ldr sp,=IRQ_STACK_CORE0
mov r0, #(CPSR_MODE_SVR | CPSR_IRQ_INHIBIT | CPSR_FIQ_INHIBIT )
msr cpsr_c,r0
bl _cstartup
halt:
wfe		// wait for event
b halt
core1:
ldr sp,=CPU_STACK_CORE1
msr cpsr_c,r0
ldr sp,=IRQ_STACK_CORE1
msr cpsr_c,r0
wfe
bl core1_main
b halt
core2:
ldr sp,=CPU_STACK_CORE2
msr cpsr_c,r0
ldr sp,=IRQ_STACK_CORE2
msr cpsr_c,r0
wfe
bl core2_main
b halt
core3:
ldr sp,=CPU_STACK_CORE3
msr cpsr_c,r0
ldr sp,=IRQ_STACK_CORE3
msr cpsr_c,r0
wfe
bl core1_main
b halt
locks
.global LDEX32
LDEX32:
ldrex r1,[r0]
mov r0,r1
bx lr
.global STEX32
STEX32:
strex r2,r1,[r0]
mov r0,r2
bx lr
.global BARRIER
BARRIER:
dmb sy
bx lr
.global LOCK
LOCK:
// r0 -> address
1:
ldrex r1,[r0]		// HANGS HERE !!!!
cmp r1,#0
bne 1b
mov r1,#1
2:
strex r2,r1,[r0]
cmp r2,#0
bne 2b
dmb sy
bx lr
.global UNLOCK
UNLOCK:
// r0 -> address
dmb sy
mov r1,#0
str r1,[r0]
bx lr
test
volatile uint32_t __semaf_leds;
	LOCK(&__semaf_leds);	// here it hangs at ldrex instruction
	UNLOCK(&__semaf_leds);
Can anyone tell if it's something to do to enable ldrex instruction?
Thanks a lot in advance.
José Luiz
Paeryn
Re: Using ldrex instruction hangs
Thu Dec 06, 2018 11:51 am
I think you need to have the MMU on and the address used for the lock needs to be in a section of memory marked as Normal. Without the MMU on all memory is effectively marked as Strongly Ordered.
timanu90
Wed Dec 12, 2018 3:11 pm
The previous answer plus the caches need to be enabled and the memory marked as normal, shareable and global.
Hope it helps
Tiago
