DjoeC
Multiple static IP addresses on eth0 Raspian Stretch using dhcpcd
Thu Nov 29, 2018 9:59 am
I am looking for a solution to use multiple static IP addresses on the eth0 interface under Raspbian Stretch by using dhcpcd as that appears to be the Raspbian networking solution going forward.
I haven't found anything other than using the /etc/network/interfaces settings:
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet static
        address 10.1.1.51
        gateway 10.1.1.1
        netmask 255.255.255.0
auto eth0:1
iface eth0:1 inet static
        address 10.1.1.52
        gateway 10.1.1.1
auto eth0:2
        iface eth0:2 inet static
        address 10.1.1.53
        gateway 10.1.1.1
allow-hotplug wlan0
iface wlan0 inet static
        address 10.1.1.50
        gateway 10.1.1.1
   wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
which is working well, wired and wireless after
sudo update-rc.d dhcpcd disable
This does not seem futureproof but as said: I cannot find a dhcpcd equivalent other than "it is not possible" which would mean that Stretch has decreased functionality. Hard to believe.
Does anyone have a (working) solution? Thanks!
<disclaimer: I am not a networking specialist - just want this to work without reverting to "the old ways">
DirkS
Re: Multiple static IP addresses on eth0 Raspian Stretch using dhcpcd
Thu Nov 29, 2018 11:19 am
Not future proof indeed...
You should start using 'systemctl'
https://www.digitalocean.com/community/ ... -and-units
DjoeC
Thu Nov 29, 2018 11:45 am
replaced in my script with the systemd version:
sudo systemctl stop dhcpcd.service
sudo systemctl disable dhcpcd.service
Thanks & you are correct about systemctl for managing services, I will dive into that as well. However I am still looking for an answer to the multiple IP addresses issue, not sure systemctl will help me with that.
epoch1970
Thu Nov 29, 2018 12:13 pm
With iproute2 the notion of "interface alias" found in ifconfig is gone.
You can "ip address add 192.168.1.1/24 dev eth0" and "ip address add 192.168.1.2/24 dev eth0" and then "ip address show" will list both addresses under eth0.
Perhaps you can try adding multiple "static ip_address=..." declarations under "interface eth0" in dhcpcd.conf?
I don't have a machine to test with, sorry.
DjoeC
Thu Nov 29, 2018 9:13 pm
command line
sudo ip address add 10.1.1.54/24 dev eth0
works and becomes active immediately so thanks for that! I have tried several ways in the dhcpcd.conf but sofar no luck. So still looking for the "perfect" solution in the "right" file.
squirrelz
Mon Mar 25, 2019 11:26 am
I found this post while trying to do the same thing. Not sure if it's useful but how I've ended up doing it was from something I found here:https://wiki.archlinux.org/index.php/dhcpcd
I created /etc/dhcpcd.exit-hook and put in it:
ip address add 192.168.0.99/24 dev eth0
After a reboot it's come back up with it's normal static, as well as this second IP
