dizzo
Removing Installed Packages in Bulk
Wed Nov 28, 2018 2:07 pm
I have a 3B+ that is currently running headless and being used as a Plex Server. What I'd like to do is essentially remove the vast majority of pre-installed packages. Leaving basically only Plex, Teamviewer and VNC for remote access.
I can't find a way to list only my installed packages so that I can bulk remove them. There doesn't appear to be an option to show only currently installed packages in the add/remove software area.
Is there anyway to show only the installed packages to that I can remove most of them?
n67
Re: Removing Installed Packages in Bulk
Wed Nov 28, 2018 3:27 pm
1) There is no need to do this. All you'd be doing is saving disk space, and disk space is cheap/irrelevant. These programs don't consume any resources if they are not used (yes, there may be exceptions to this rule).
2) You'll probably mess something up - remove something you shouldn't have removed - and then post about that to the forum.
3) Take a look at the output of "dpkg -l". If the first column is "ii", then that package is installed. I'm not sure what other codes are possible for the first field. On the one system where I checked, the only other code was "rc" - which shows up in about 25 lines (out of about 1500).
"L'enfer, c'est les autres"
Epmu Sn!
klricks
Mon Dec 03, 2018 2:11 pm
As mentioned removing packages is pointless unless you need the disk space for something else.
But to answer your question....
This text based Package Manager can show a list of installed packages:
sudo aptitude
Or a much better GUI PM can be installed:
sudo apt update
sudo apt install synaptic
Note: Do not randomly remove packages unless you know they are not needed.
fbe
Mon Dec 03, 2018 9:07 pm
They cause useless network traffic when they get updated. Some updates even caused errors.
HawaiianPi
Mon Dec 03, 2018 11:19 pm
The new 2018-11-13 Raspbian release now has Desktop and Full versions, the former having minimal fluff installed.
Raspbian Stretch with desktop (sort of a "Desktop Lite"): https://downloads.raspberrypi.org/raspbian_latest
Raspbian Stretch with desktop and recommended software: https://downloads.raspberrypi.org/raspbian_full_latest
