I'm using 0.3.2 :
pi@raspberrypi:~ $ pip3 show omxplayer-wrapper
Version: 0.3.2
Using the following code:
from omxplayer.player import OMXPlayer
import time,signal,sys
def signalHandler(sig,frame):
print('Ctrl+C pressed')
player.quit()
sys.exit(0)
def playerPause():
print('pause')
def playerExit():
print('exit')
signal.signal(signal.SIGINT,signalHandler)
filename = './Simple Minds/Glittering Prize 81-92 [Canada]/01 Waterfront.mp3'
player = OMXPlayer(filename)
player.pauseEvent += lambda _: playerPause()
player.exitEvent += lambda _: playerExit()
time.sleep(3) # wait for omxplayer
player.set_position(player.duration()-5) # skip close to end
while True:
time.sleep(1)
Exception in thread Thread-1:
File "/usr/lib/python3.5/threading.py", line 914, in _bootstrap_inner
self.run()
File "/usr/lib/python3.5/threading.py", line 862, in run
self._target(*self._args, **self._kwargs)
File "/home/pi/.local/lib/python3.5/site-packages/omxplayer/player.py", line 173, in monitor
on_exit(self, process.returncode)
File "/home/pi/.local/lib/python3.5/site-packages/omxplayer/player.py", line 169, in on_exit
self.exitEvent(self, exit_status)
File "/home/pi/.local/lib/python3.5/site-packages/evento/event.py", line 48, in fire
subscriber(*args, **kargs)
TypeError: <lambda>() takes 1 positional argument but 2 were given
I assume its something to do with the exit_status parameter in the documentation below:
https://python-omxplayer-wrapper.readth ... omxplayer/
exitEvent = None
Event called on exit callback(player, exit_status)
