xPain
Install SpeechRecognition in Raspberry
Thu Nov 22, 2018 7:06 am
I installed the SpeechRecognition as instructed at https://github.com/Uberi/speech_recognition
'pip install SpeechRecognition'
Currently I use python 3.5 on my Raspberry Pi 3. The installation has no errors. The next part of the tutorial says that: "To quickly try it out, run 'python -m speech_recognition' after installing." But it seems that the library was not found.
(env) pi@raspberrypi:~/Desktop/new-project-2 $ pip install SpeechRecognition
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: SpeechRecognition in /home/pi/env/lib/python3.5/site-packages (3.8.1)
(env) pi@raspberrypi:~/Desktop/new-project-2 $ python -m speech_recognition
/usr/bin/python3.5: No module named speech_recognition
It looks like the system is looking for a library somewhere else or I have misplaced the library. Can anyone help me?
ghp
Re: Install SpeechRecognition in Raspberry
Thu Nov 22, 2018 1:47 pm
looks as if you hit the problem:
python uses pip (python 2)
python3 uses pip3 (python3).
Whatever is installed with pip is not available in python3.
Try to install the software with 'sudo pip3 install SpeechRecognition'.
Good luck !
Return to “Python”
