FatalXception
I’m interested in the physical characteristics of PI controlled lights
Sun Nov 18, 2018 11:42 am
I am planing on using the Pi as a controller- probably to control a relay unit that will work as a smart home style setup. I’m interested in the physical characteristics of the lights that will impact usability and durability for this application. Thanks though!
pcmanbob
Re: I’m interested in the physical characteristics of PI controlled lights
Sun Nov 18, 2018 9:09 pm
To little information for a meaning full answer...
You could answer the sun is a light if you get your project to close to it, things will start melting .........
DarkPlatinum
Contact: Website YouTube
Sun Nov 18, 2018 9:12 pm
Were you stating this as a fact, or did you forget to post your question? The basic over view of controlling lights with the Raspberry Pi is using the GPIO pins. You can control the state of various GPIO pins using a programming language such as python, or scripts.
1 * Raspberry Pi Zero W, 1 * Raspberry Pi 2, 1 * Raspberry Pi 3 1 * Raspberry Pi 3B + :mrgreen:
Check Out My Raspberry Site (Run on a Raspberry Pi 3B :) ): https://html.dynu.net
Return to “Off topic discussion”
