isan98
How to connecting GSM module to the internet and sending sms at same time with raspberry pi
Sat Nov 10, 2018 5:34 pm
I installed sakis3g packet and use it for connect pi3 to the internet on /dev/serial0 with sim800l GSM module
And I use this code to send sms :
import serial
import RPi.GPIO as GPIO
import os, time
GPIO.setmode(GPIO.BOARD)
# Enable Serial Communication
port = serial.Serial("/dev/serial0", baudrate=9600, timeout=1)
# Transmitting AT Commands to the Modem
# '\r\n' indicates the Enter key
port.write('AT'+'\r\n')
rcv = port.read(10)
print rcv
time.sleep(5)
port.write('ATE0'+'\r\n')      # Disable the Echo
rcv = port.read(10)
print rcv
time.sleep(5)
port.write('AT+CMGF=1'+'\r\n')  # Select Message format as Text mode
rcv = port.read(10)
print rcv
time.sleep(5)
port.write('AT+CNMI=2,1,0,0,0'+'\r\n')   # New SMS Message Indications
rcv = port.read(10)
print rcv
time.sleep(5)
port.write('AT+CSCS="GSM"'+'\r\n')   # New SMS Message Indications
rcv = port.read(10)
print rcv
time.sleep(5)
# Sending a message to a particular Number
port.write('AT+CMGS="+5432567899"'+'\r\n')
rcv = port.read(10)
print rcv
time.sleep(5)
port.write('Hello User'+'\r\n')  # Message
rcv = port.read(10)
print rcv
port.write("\x1A") # Enable to send SMS
for i in range(10):
    rcv = port.read(10)
    print rcv
IT'S OK when the module is not connected to the Internet,
But I want to send SMS when the module is connected to the Internet, actually sending SMS and connecting to the Internet at the same time.
Serial port is busy because of Internet connection, so how can I to do this?
Andyroo
Re: How to connecting GSM module to the internet and sending sms at same time with raspberry pi
Sat Nov 10, 2018 6:07 pm
That would make sense as the SMS message uses GSM and does not use an internet connection (GPRS) and the chipset either delivers SMS or Internet as the data stream over the serial port.
The simplest way of sending SMS messages while connected is to use a third party to convert emails to text messages.
You may be able to configure a second serial port through the USB if provided but as a guess you are looking to multiplex the data streams over one serial line and I see this chip does support multiplexing. Unfortunately this is not a module I have used so I’m a bit stuck there.
Need Pi spray - these things are breeding in my house...
Andyroo
Sat Nov 10, 2018 6:16 pm
Ignore what I said about the USB port - looks like it’s for debug use only as per https://drive.google.com/file/d/0B7t_g4 ... hXRDg/view
Also I hate the use of two wire serial as this supports full handshaking but it’s disabled by default :o
You may want to have a look at the ring line details if you want to receive texts as well as send them - it’s a neat way of telling voice from texts!
isan98
Sat Nov 10, 2018 6:41 pm
what is the ring line details?
Andyroo
Sat Nov 10, 2018 6:48 pm
Page 35 and 36 of the above linked document show you how the RI lines tells you if it’s voice or SMS comming in.
It will not help you sending SMS while connected to the internet.
isan98
Sat Nov 10, 2018 7:07 pm
yes I need to send sms while module connected to the internet.
Andyroo
Sat Nov 10, 2018 10:33 pm
Then have a look at Text Anywhere or ITTT style services else:
1) I think you are going to have to dig up the manual on multiplexing and write a pig of a routine
2) Drop the internet connection for a short while, send the text and re-connect
3) Look at modules that could do both at once
