rogermorrell1
Raspbian 4.14.71-v7+ The fbtft module warning messag
Fri Nov 09, 2018 9:56 pm
On Boot of the latest Raspbian 4.14.71-v7+ distro
The fbtft module gets a warning message .. is this a problem ?
In my case I'm interested because I have a PIscreen2 that is not working. In lookins at the latest
fbtft on github it appears to refer to Piscreen - other people have Piscreen2 working on earlier Raspbian
distributions
I have a dtoverlay=piscreen2r in boot/config.txt that is not acted upon
beginning of log
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.71-v7+ ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1145 SMP Fri Sep 21 15:38:35 BST 2018
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
[ 0.000000] Memory policy: Data cache writealloc
section of log concerning fbtft
4.805519] input: ADS7846 Touchscreen as /devices/platform/soc/3f204000.spi/spi_master/spi0/spi0.1/input/input3
[ 4.848572] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.856108] fb_ili9486: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.856902] fbtft_of_value: regwidth = 16
[ 4.856913] fbtft_of_value: buswidth = 8
[ 4.856921] fbtft_of_value: debug = 0
[ 4.856928] fbtft_of_value: rotate = 90
[ 4.856936] fbtft_of_value: fps = 30
[ 4.856942] fbtft_of_value: txbuflen = 32768
[ 4.970399] random: crng init done
DirkS
Re: Raspbian 4.14.71-v7+ The fbtft module warning messag
Sat Nov 10, 2018 10:13 am
It's exactly what it says: a warning.
You can ignore it.
BTW
The Rapbian distro you're running is probably version 9 (Stretch)
See /etc/os-release
v4.14 is the kernel version.
Return to “Raspbian”
