nopls
Read Temperature from Omron K3MA
Thu Nov 08, 2018 7:51 am
Hi everyone.
I need to read the temperature from the sensor in the attached image. Then set a trigger when the temperature exceeds a specified limit.
I've already set up IFTTT webhook notification on node red, so It's just getting the data from the sensor and monitoring on node red (Or any other method if it works)
I'm a newbie.
Thank you. :D
RattusRattus
Re: Read Temperature from Omron K3MA
Fri Nov 09, 2018 12:47 pm
if you turn the unit round you will find a nice clear display.
When the K3MA is turned on and connected correctly use Mk-I human eyeball to look at the display....
Seriously though...
Your question boils down to this:
"I have <device> and I want to connect it to my RPi. "
The question that you need to ask yourself:
Does <device> have an output that provides the data that you want to read from your Pi?
if it does then yes you can (you may need to convert the data provided / support the electrical interface)
if there is no output from <device> providing information that you want then no you can't just 'attach a Pi' and magically be able to extract all the information you want
In the case of the K3MA series panel meters there is an output, but it only gives alarm indication - this DOES NOT give you temperature
If you want to get a temperature reading into the Pi then there are other sensors that you can use not this panel meter.
If you want to hack This panel meter then you could
1) Use a PiCam and some OCR software to 'view' the front display
2) take the panel meter apart and 'grab' the BCD information being sent to the display using suitably buffered GPIO on your Pi.
/Andy
mahjongg
Sat Nov 10, 2018 9:30 pm
You might not like this, but IMHO Rattus is right, the device does not seem to posses any kind of digital interface, see https://assets.omron.eu/downloads/manua ... ual_en.pdf
Andyroo
Sat Nov 10, 2018 10:25 pm
Only hope you have is a bit off the wall:
1) as above - Stick a camera so it can see the display and OCR it.
2) Program the temp to trigger the relay at your warning temp and pick the relay change up.
Section 3-6 has an example of programming the unit but it also checks for a lower temperature so it will need modifying.
Note as this is a ‘C’ model, you only have one relay contact and that may be needed by the plant so you need to check with the plant engineers to see how you tap in and feed an opto-isolator and then to the Pi. Without a lot more plant details I doubt folk would want to advise you on the relay link just in case :shock:
Best bet - replace it with a more modern unit that can interface to others...
LTolledo
Sun Nov 11, 2018 8:53 am
You can still use the OMRON temperature controller "as a temperature display/controller" only.
to be able to use it and a Raspberry Pi, you need to connect the thermocouple wire to the from the OMRON temp controller to a temperature A/D converter connected to your RPi. Then use your code to read the data from the A/D converter and set the trigger points. You need to calibrate the converter so that the readings from the converter is "almost" the same as the OMRON temp controller (+ or - 0.5 degrees or better) depending on your preference.
you cannot use just any wire. There are several types of thermocouple wire. Wrong wire = erroneous data.
And no, you cannot insist on using just any wire.
Some people be like:
Andyroo
Sun Nov 11, 2018 2:35 pm
Sorry but I've seen that NOT work so many times (at -ve temps) as the original readings go to pot I would never go that way but past experience clouds my judgement here :lol:
nopls
Fri Nov 16, 2018 7:01 am
Thank you, Andy.
I could maybe just set a much lower temperature that wouldn't be reachable. I only need the trigger at like above 70degC. The plant only requires the visible temperature on the unit, so I'm free to use the output for the relay.
I'm not familiar with opto-isolator. Does it have the same function as a breakout board? I looked it up and it seems to be safer but complicated for me to use I think.
I intend to use MAX31855 with a separate K-type thermocouple probe if it didn't work out through the omron sensor. I'd like to give it a go with using a relay and optoisolator as you suggested.
Also, thank you for not being rude. I bought a Rpi a day before I posted this. I don't have any prior knowledge of electronics or programming, my work is related to organic chemistry and a bit of process engineering which doesn't help with this. I spend my home time working on it. We don't have an engineer that can sort this out right now so I'm on my own. If you feel I'm asking too much, you don't need to reply.
Thank you heaps again for the information you've provided me with already. :D
nopls
Fri Nov 16, 2018 7:11 am
I'd probably feel comfortable with using a separate probe for measuring the temperature. Using a K-type thermocouple and MAX31855 breaker board to connect to Rpi and then read temp from python, not sure how I'll read the temperature in node red but I'll figure something out on the programming side of things.
Thank you for your response. :D
