tcat
RPI-1(B) WiFi nl80211
Mon Nov 05, 2018 2:43 pm
I got nl80211 USB wireless module for my older RPI-1 model B, and I cannot get it working. RPI runs Stretch lite version of 2018-10-09.
lsusb reports device as `0bda:f179' Realtek Semiconductor.
I tried this config with with either `ra0' or `wlan0' interface names
# /etc/network/interfaces.d/wlan0
auto lo wlan0
iface lo inet loopback
iface eth0 inet dhcp
iface wlan0 inet dhcp
   wpa-ssid "MySSID"
   wpa-psk "MyPassword"
I am getting `error device not found, wpa_supplicant does not support...', frequetly asked here.
I read through the list here and tried some of the suggetsions, but did not work so far for me.
What do I miss in the config?
Many thanks in advance.
Tomas
drgeoff
Re: RPI-1(B) WiFi nl80211
Mon Nov 05, 2018 3:06 pm
Have you set the country?
tcat
Mon Nov 05, 2018 3:17 pm
Yes, I copied over my wpa config from RPI3.
update_config=1
country=CZ
network={
	ssid="TP-LINK_DFB400"
	psk="topsecret"
	key_mgmt=WPA-PSK
And adjusted interfaces.d
auto lo wlan0
Now reading
STICKY: WiFi Dongle Issues ? Start here !
tcat
Mon Nov 05, 2018 6:19 pm
Having read the sticky note anbout WiFi Dongle, still no luck.
lsmod, only reports cfg80211, rfkill loaded, no `rlt8..' on the list of loaded modules.
`firmware-realtek' installed, no relatek module `rlt8...' loaded hence no `wlan0' created, probably.
lsusb onkly gives this info
0bda:f179 Realtek Semiconductor.
Any ideas?
Many thanks
Tomas
Mon Nov 05, 2018 6:52 pm
Any ideas?
Many thanks
Tomas
https://wikidevi.com/wiki/0bda
I believe Raspbian Stretch does not include either firmware or driver.
MrEngman has written an easy install script, see:
viewtopic.php?f=28&t=62371
Retired disgracefully.....
tcat
Tue Nov 06, 2018 8:54 am
I have installed `8188eu.ko', from `8188eu-4.14.71-1145.tar.gz'. Module is not loaded on boot.
Running modprobe 8188eu loads the module, but still no `wlan0' device created.
Also it seems a module of similar name is part of Stretch install...
/lib/firmware/rtlwifi/rtl8188efw.bin
/lib/firmware/rtlwifi/rtl8188eufw.bin
But yet, the dongle n802.11 is not recognised so far.
Tomas
wolf.z
Tue Nov 06, 2018 11:42 am
As fruitoftheloom stated, use Mr. Engman's script, works like charm for Realtek RTL88xx chips.
viewtopic.php?f=63&t=178405 second post.
The following will be all you have to do.
sudo wget http://www.fars-robotics.net/install-wifi -O /usr/bin/install-wifi
sudo chmod +x /usr/bin/install-wifi
sudo install-wifi
tcat
Tue Nov 06, 2018 3:46 pm
Thank you. I tried downloading manually first as that is the last update. I have also looked in the script suggested around option -c, standing for check. The script is nicely written.
-c option performs this check, it pipes the output of lsusb to grep -i checking for particular drive no:id. Mine is `0bda:f179' which is unfortunattely not on the list.
Tomas
