ducarpit
Poweroff the raspberry after a specific time period!
Sun Oct 28, 2018 5:06 pm
i want to poweroff my raspberry after a time period.
Example: after 6 hours since the poweron.
I know i can do this with the cron (crontab -e --> insert the right line) but in this way i need to set a specific time (in my case i cant' do this).
How can i do this?
Thanks a lot
Christian
DirkS
Re: Poweroff the raspberry after a specific time period!
Sun Oct 28, 2018 5:39 pm
See 'man shutdown'
This should work
@reboot sudo /sbin/shutdown -p +3600
If you use the root crontab then you can leave out 'sudo'
Sun Oct 28, 2018 5:56 pm
This is a hippy & doctor free zone.
ducarpit
Sun Oct 28, 2018 9:41 pm
See 'man shutdown'
This should work
Hi, thanks a lot.
In the shutdown manual, there isn'it a -p (lower) parameter but only a -P that stands for "poweroff". Maybe you refer to -P (upper)....am i right?
The "+3600" stands for 3600 minutes as i can read in the manual...am i right?
Thanks a lot
DirkS
Sun Oct 28, 2018 10:13 pm
Thanks a lot
Correct on both counts. You can actually leave out the -P as it is the default.
ducarpit
Mon Oct 29, 2018 10:56 am
Hi my dear,
thanks a lot.
I have tried your solution and it works!
But there is a problem: after the shutdown with the cron, i re-poweron my raspberry and i try to connect to him with SSH, but i got this:
[email protected]:~$ ssh [email protected]
[email protected]'s password:
System is going down.
Connection closed by 192.168.1.53 port 22
Maybe i can't connect with SSH while the "shutdown +10" is running.
What do you think?
Christian
Mon Oct 29, 2018 11:05 am
You can connect as the root user. Regular users are blocked.
ducarpit
Mon Oct 29, 2018 12:10 pm
Perfect my friend....
Now, i have only to remove the broadcast message that say:
Broadcast message from [email protected] (Mon 2018-10-29 13:07:36 CET):
The system is going down for poweroff at Mon 2018-10-29 13:14:36 CET!
But i think i just need to put the --no-wall parameter to the command.
Am i right?
Thank a lot
ducarpit
Mon Oct 29, 2018 12:12 pm
Am i right?
Thank a lot
epoch1970
Mon Oct 29, 2018 3:33 pm
You can try it yourself.
[email protected]:~ $ date; sudo shutdown -k +1; sleep 65; date
Mon Oct 29 16:28:29 CET 2018
Shutdown scheduled for Mon 2018-10-29 16:29:29 CET, use 'shutdown -c' to cancel.
Broadcast message from [email protected] (Mon 2018-10-29 16:28:29 CET):
The system is going down for power-off at Mon 2018-10-29 16:29:29 CET!
Mon Oct 29 16:29:34 CET 2018
[email protected]:~ $ date; sudo shutdown -k --no-wall +1; sleep 65; date
Mon Oct 29 16:30:01 CET 2018
Shutdown scheduled for Mon 2018-10-29 16:31:01 CET, use 'shutdown -c' to cancel.
Mon Oct 29 16:31:06 CET 2018
shutdown option "-k" is used by admins to scare people off servers... It does not really execute shutdown.
ducarpit
Mon Oct 29, 2018 4:18 pm
Perfect, many thankts to all my dear friends.....
ducarpit
Re: [Solved] Poweroff the raspberry after a specific time period!
Fri Nov 09, 2018 5:45 pm
Hi, i have a little problem: i inserted this line in the crontab file:
@reboot /sbin/shutdown +420 --no-wall
and it works fine, after 420 minutes the Raspberry shutdowns without problems.
Unfortunatly, when i re-poweron it, it starts but after some seconds it poweroffs automatically.
I have to cut off the power and then re-poweron the Raspberry to start it.
Why?
Can someone help me?
Christian
Return to “Raspbian”
