sudo apt-get -y install ntpCode: Select all
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
libopts25
Suggested packages:
ntp-doc
The following NEW packages will be installed:
libopts25 ntp
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 609 kB of archives.
After this operation, 1,826 kB of additional disk space will be used.
0% [Connecting to raspbian.raspberrypi.org (192.168.255.1)]My network connections is working without any problems on my Raspberry I can ping without problems:
PING mirrordirector.raspbian.org (93.93.128.193) 56(84) bytes of data.
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=1 ttl=53 time=51.2 ms
