After reading some tutorials and books, my Python skills are slowly getting better. But one thing all the learning material I used seem to lack is explanations on how to structure bigger programs.
I get that I can use multiple files and import them and all that stuff, but I don't know the "correct" way to do it in bigger programs. If someone knows about a good tutorial or book that covers... program structuring... or something like that, that would be useful.
For example, I use Pygame to build a simple game, and I thought that the code I use to read and process sprite sheets could be in a separate module that I could reuse in multiple places and/or programs. So I thought I could put it in a separate file and import it where I need it.
But I have to import Pygame in that module, because some stuff I do with the sprite sheets needs it. The thing is I also import it in the file where I use my sprite sheet stuff.
So, I have a game file, that imports Pygame and my sprite sheet stuff, and my sprite sheet file also imports Pygame.
It seems that I have to do it in every file, so I wonder if it is really necessary and if it slows down / uses more memory because the game imports it multiple times. Is there a better way to do it?
Same thing with the pygame.init() call... Do I have to do it in every module that uses Pygame? It seems like I do... (well, few things in Pygame actually need it)
I guess that my question is whether it is the right way to do it (reimport Pygame or any module I need, and initialise if needed)? A part of me doesn't like that I do something multiple times for "nothing", simply to split my program in multiple files. But maybe it is ok and python is smart enough not to reload stuff multiple times... or maybe not and it's still the way to do it. I don't know.
So, that's the kind of things I wonder about. I can make it work, but I want to make sure it's the right way. Hopefully someone can explain it to me or point me to a book or tutorial that explains it.
