jim53
Create an access point on wlan1
Tue Oct 23, 2018 5:27 pm
I am newbie on networking and server but for a project, I want to create an acces point with my Raspberry Pi 3.
Today, I am using the integrated WFI (wlan0) to connect the raspberry to my box and it works.well.
Now, I would like to create an access point with an additional WIFI adpater TP LINK TL-WN823N (wlan1) plug on my raspberry Pi 3 to allow a connection with electronic modules (based on ESP8266). Moreover, I don't want the electronic module to have access to internet by sharing wlan0.
Please find below a figure of what I want to do :
I have followed many tutorials but each time, I loose my connection to my box.
Could someone help me step by step to use the good softwares and to set correctly the configuration files to acheive my goal?
Thank you for advance.
epoch1970
Re: Create an access point on wlan1
Tue Oct 23, 2018 7:50 pm
Apply this https://www.raspberrypi.org/documentati ... s-point.md
From the top of the page, down to "Start it up", replacing "wlan0" with "wlan1" and "192.168.4" with "192.168.3" when you read.
Do not add routing and masquerading, as that would open outgoing access to Internet from the module's network.
SurferTim
Tue Oct 23, 2018 8:08 pm
I had no luck setting up an AP on wlan1. However, I found a way to rename the interfaces so you can install an AP on wlan0.
Create file /etc/udev/rules.d/72-static-name.rules
Add this:
ACTION=="add", SUBSYSTEM=="net", DRIVERS=="?*",
ATTR{address}=="00:c0:ca:96:d8:8b", KERNEL=="w*",NAME="wlan0"
ATTR{address}=="b8:27:eb:1e:56:52", KERNEL=="w*",NAME="wlan1"
Change the mac addresses to suit your needs. Reboot.
epoch1970
Tue Oct 23, 2018 8:14 pm
Could it be wpa-supplicant trying to apply file wpa_supplicant.conf to wlan1, making it unavailable later on for AP configuration?
To test that, I would try renaming wpa_supplicant.conf to wpa_supplicant-wlan0.conf (and perhaps also moving it to /etc/wpa_supplicant/ if this dir. exists). Normally wpa-supplicant will only apply file wpa_supplicant-wlan0.conf to interface wlan0, and not to other interfaces.
SurferTim
Tue Oct 23, 2018 8:21 pm
I have nothing in the wpa_supplicant.conf file. I've tried everything I know to get it to work on wlan1, and the only way is to change the interface names so wlan0 is the interface for the AP.
You are correct about the wpa_supplicant.conf file renaming or you can use nohook in /etc/dhcpcd.conf.
interface wlan0
static ip_address=192.168.4.1/24
nohook wpa_supplicant
jim53
Wed Oct 24, 2018 8:30 pm
Thank you for your help.
I have follow the tutorial of epoch1970 with the replacement of wlan0 by wlan1 and 198.162.4.X by 198.162.3.X but I still have a problem because the wlan0 and wlan1 are both connected to my box as you can see on figure below:
Moreover, the name of my SSID of my access point (RASP_WIFI) doesn't appear in the available network list.
Do you have idea from where comes the problem?
I don't know if I understand right but when I read the first message of SurferTIm, I understand that it is not possible to add an access point on wlan1 (only on wlan0). Is it correct?
jim53
Wed Oct 24, 2018 9:02 pm
I don't know if it can help you to understand my problem but I have tried to rename the file wpa_supplicant.conf by wpa_supplicant-wlan0.conf but when I have reboot only wlan1 was visible and connected to my access point RASP_WIFI with the IP address 198.162.3.1/24.
SurferTim
Wed Oct 24, 2018 9:32 pm
That is correct. You must install your AP on wlan0. You can rename them as I explained above. Insure when you add the ip address in /etc/dhcpcd.conf, you use the nohook wpa_supplicant.
jim53
Thu Oct 25, 2018 12:56 pm
Thank you for your answer.
If I understand right, i need to :
    • Create file /etc/udev/rules.d/72-static-name.rules
    I have to replace "00:c0:ca:96:d8:8b" by the MAC address of my WIFI USB adapter and "00:c0:ca:96:d8:8b" by MAC address of the WIFI integrated module of my Raspberry Pi 3.
    • I reboot the system
    • Follow a new time the tutorial given by epoch1970 without replacing wlan0 by wlan1
    • Change the file /etc/dhcpcd.conf as below :
    interface wlan0
    static ip_address=192.168.3.1/24
Could you confirm that is the good procedure?
Moreover, do I need to rename wpa_supplicant.conf to wpa_supplicant-wlan0.conf?
SurferTim
Thu Oct 25, 2018 1:04 pm
Yes. I tested it several times myself on different devices.
No, you do not need to rename wpa_supplicant.conf if you add the "nohook wpa_supplicant" line to /etc/dhcpcd.conf.
jim53
Thu Oct 25, 2018 1:24 pm
Thank you very much.
I will try it this evening and I will confirm you if it works or not.
jim53
Thu Oct 25, 2018 7:42 pm
Error
jim53
Thu Oct 25, 2018 7:47 pm
Unfortunately, it still doesn't work because the WIFI line are connected to my box :
Please find below my files, perhaps you will be able to find the mistake :
  • /etc/udev/rules.d/72-static-name.rules
ATTR{address}=="98:de:d0:1e:65:ba",KERNEL=="w*",NAME=="wlan0"
ATTR{address}=="b8:27:eb:31:91:3c",KERNEL=="w*",NAME=="wlan1"
  • /etc/dhcpcd.conf
# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for details.
# Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
# Most distributions have NTP support.
option ntp_servers
# Respect the network MTU.
# Some interface drivers reset when changing the MTU so disabled by default.
#option interface_mtu
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate Stable Private IPv6 Addresses instead of hardware based ones
slaac private
# A hook script is provided to lookup the hostname if not set by the DHCP
# server, but it should not be run by default.
nohook lookup-hostname
interface wlan0
  • /etc/dnsmasq.conf
# Configuration file for dnsmasq.
# Format is one option per line, legal options are the same
# as the long options legal on the command line. See
# "/usr/sbin/dnsmasq --help" or "man 8 dnsmasq" for details.
# Listen on this specific port instead of the standard DNS port
# (53). Setting this to zero completely disables DNS function,
# leaving only DHCP and/or TFTP.
#port=5353
# The following two options make you a better netizen, since they
# tell dnsmasq to filter out queries which the public DNS cannot
# answer, and which load the servers (especially the root servers)
# unnecessarily. If you have a dial-on-demand link they also stop
# these requests from bringing up the link unnecessarily.
# Never forward plain names (without a dot or domain part)
#domain-needed
# Never forward addresses in the non-routed address spaces.
#bogus-priv
# Uncomment these to enable DNSSEC validation and caching:
# (Requires dnsmasq to be built with DNSSEC option.)
#conf-file=%%PREFIX%%/share/dnsmasq/trust-anchors.conf
#dnssec
# Replies which are not DNSSEC signed may be legitimate, because the domain
# is unsigned, or may be forgeries. Setting this option tells dnsmasq to
# check that an unsigned reply is OK, by finding a secure proof that a DS
# record somewhere between the root and the domain does not exist.
# The cost of setting this is that even queries in unsigned domains will need
# one or more extra DNS queries to verify.
#dnssec-check-unsigned
# Uncomment this to filter useless windows-originated DNS requests
# which can trigger dial-on-demand links needlessly.
# Note that (amongst other things) this blocks all SRV requests,
# so don't use it if you use eg Kerberos, SIP, XMMP or Google-talk.
# This option only affects forwarding, SRV records originating for
# dnsmasq (via srv-host= lines) are not suppressed by it.
#filterwin2k
# Change this line if you want dns to get its upstream servers from
# somewhere other that /etc/resolv.conf
#resolv-file=
# By  default,  dnsmasq  will  send queries to any of the upstream
# servers it knows about and tries to favour servers to are  known
# to  be  up.  Uncommenting this forces dnsmasq to try each query
# with  each  server  strictly  in  the  order  they   appear   in
# /etc/resolv.conf
#strict-order
# If you don't want dnsmasq to read /etc/resolv.conf or any other
# file, getting its servers from this file instead (see below), then
# uncomment this.
#no-resolv
# If you don't want dnsmasq to poll /etc/resolv.conf or other resolv
# files for changes and re-read them then uncomment this.
#no-poll
# Add other name servers here, with domain specs if they are for
# non-public domains.
#server=/localnet/192.168.0.1
# Example of routing PTR queries to nameservers: this will send all
# address->name queries for 192.168.3/24 to nameserver 10.1.2.3
#server=/3.168.192.in-addr.arpa/10.1.2.3
# Add local-only domains here, queries in these domains are answered
# from /etc/hosts or DHCP only.
#local=/localnet/
# Add domains which you want to force to an IP address here.
# The example below send any host in double-click.net to a local
# web-server.
#address=/double-click.net/127.0.0.1
# --address (and --server) work with IPv6 addresses too.
#address=/www.thekelleys.org.uk/fe80::20d:60ff:fe36:f83
# Add the IPs of all queries to yahoo.com, google.com, and their
# subdomains to the vpn and search ipsets:
#ipset=/yahoo.com/google.com/vpn,search
# You can control how dnsmasq talks to a server: this forces
# queries to 10.1.2.3 to be routed via eth1
# [email protected]
# and this sets the source (ie local) address used to talk to
# 10.1.2.3 to 192.168.1.1 port 55 (there must be a interface with that
# IP on the machine, obviously).
# [email protected]#55
# If you want dnsmasq to change uid and gid to something other
# than the default, edit the following lines.
#user=
#group=
# If you want dnsmasq to listen for DHCP and DNS requests only on
# specified interfaces (and the loopback) give the name of the
# interface (eg eth0) here.
# Repeat the line for more than one interface.
#interface=
# Or you can specify which interface _not_ to listen on
#except-interface=
# Or which to listen on by address (remember to include 127.0.0.1 if
# you use this.)
#listen-address=
# If you want dnsmasq to provide only DNS service on an interface,
# configure it as shown above, and then use the following line to
# disable DHCP and TFTP on it.
#no-dhcp-interface=
# On systems which support it, dnsmasq binds the wildcard address,
# even when it is listening on only some interfaces. It then discards
# requests that it shouldn't reply to. This has the advantage of
# working even when interfaces come and go and change address. If you
# want dnsmasq to really bind only the interfaces it is listening on,
# uncomment this option. About the only time you may need this is when
# running another nameserver on the same machine.
#bind-interfaces
# If you don't want dnsmasq to read /etc/hosts, uncomment the
# following line.
#no-hosts
# or if you want it to read another file, as well as /etc/hosts, use
# this.
#addn-hosts=/etc/banner_add_hosts
# Set this (and domain: see below) if you want to have a domain
# automatically added to simple names in a hosts-file.
#expand-hosts
# Set the domain for dnsmasq. this is optional, but if it is set, it
# does the following things.
# 1) Allows DHCP hosts to have fully qualified domain names, as long
#     as the domain part matches this setting.
# 2) Sets the "domain" DHCP option thereby potentially setting the
#    domain of all systems configured by DHCP
# 3) Provides the domain part for "expand-hosts"
#domain=thekelleys.org.uk
# Set a different domain for a particular subnet
#domain=wireless.thekelleys.org.uk,192.168.2.0/24
# Same idea, but range rather then subnet
#domain=reserved.thekelleys.org.uk,192.68.3.100,192.168.3.200
# Uncomment this to enable the integrated DHCP server, you need
# to supply the range of addresses available for lease and optionally
# a lease time. If you have more than one network, you will need to
# repeat this for each network on which you want to supply DHCP
# service.
#dhcp-range=192.168.0.50,192.168.0.150,12h
# This is an example of a DHCP range where the netmask is given. This
# is needed for networks we reach the dnsmasq DHCP server via a relay
# agent. If you don't know what a DHCP relay agent is, you probably
# don't need to worry about this.
#dhcp-range=192.168.0.50,192.168.0.150,255.255.255.0,12h
# This is an example of a DHCP range which sets a tag, so that
# some DHCP options may be set only for this network.
#dhcp-range=set:red,192.168.0.50,192.168.0.150
# Use this DHCP range only when the tag "green" is set.
#dhcp-range=tag:green,192.168.0.50,192.168.0.150,12h
# Specify a subnet which can't be used for dynamic address allocation,
# is available for hosts with matching --dhcp-host lines. Note that
# dhcp-host declarations will be ignored unless there is a dhcp-range
# of some type for the subnet in question.
# In this case the netmask is implied (it comes from the network
# configuration on the machine running dnsmasq) it is possible to give
# an explicit netmask instead.
#dhcp-range=192.168.0.0,static
# Enable DHCPv6. Note that the prefix-length does not need to be specified
# and defaults to 64 if missing/
#dhcp-range=1234::2, 1234::500, 64, 12h
# Do Router Advertisements, BUT NOT DHCP for this subnet.
#dhcp-range=1234::, ra-only
# Do Router Advertisements, BUT NOT DHCP for this subnet, also try and
# add names to the DNS for the IPv6 address of SLAAC-configured dual-stack
# hosts. Use the DHCPv4 lease to derive the name, network segment and
# MAC address and assume that the host will also have an
# IPv6 address calculated using the SLAAC alogrithm.
#dhcp-range=1234::, ra-names
# Set the lifetime to 46 hours. (Note: minimum lifetime is 2 hours.)
#dhcp-range=1234::, ra-only, 48h
# Do DHCP and Router Advertisements for this subnet. Set the A bit in the RA
# so that clients can use SLAAC addresses as well as DHCP ones.
#dhcp-range=1234::2, 1234::500, slaac
# Do Router Advertisements and stateless DHCP for this subnet. Clients will
# not get addresses from DHCP, but they will get other configuration information.
# They will use SLAAC for addresses.
#dhcp-range=1234::, ra-stateless
# Do stateless DHCP, SLAAC, and generate DNS names for SLAAC addresses
# from DHCPv4 leases.
#dhcp-range=1234::, ra-stateless, ra-names
# Do router advertisements for all subnets where we're doing DHCPv6
# Unless overriden by ra-stateless, ra-names, et al, the router
# advertisements will have the M and O bits set, so that the clients
# get addresses and configuration from DHCPv6, and the A bit reset, so the
# clients don't use SLAAC addresses.
#enable-ra
# Supply parameters for specified hosts using DHCP. There are lots
# of valid alternatives, so we will give examples of each. Note that
# IP addresses DO NOT have to be in the range given above, they just
# need to be on the same network. The order of the parameters in these
# do not matter, it's permissible to give name, address and MAC in any
# order.
# Always allocate the host with Ethernet address 11:22:33:44:55:66
# The IP address 192.168.0.60
#dhcp-host=11:22:33:44:55:66,192.168.0.60
# Always set the name of the host with hardware address
# 11:22:33:44:55:66 to be "fred"
#dhcp-host=11:22:33:44:55:66,fred
# Always give the host with Ethernet address 11:22:33:44:55:66
# the name fred and IP address 192.168.0.60 and lease time 45 minutes
#dhcp-host=11:22:33:44:55:66,fred,192.168.0.60,45m
# Give a host with Ethernet address 11:22:33:44:55:66 or
# 12:34:56:78:90:12 the IP address 192.168.0.60. Dnsmasq will assume
# that these two Ethernet interfaces will never be in use at the same
# time, and give the IP address to the second, even if it is already
# in use by the first. Useful for laptops with wired and wireless
# addresses.
#dhcp-host=11:22:33:44:55:66,12:34:56:78:90:12,192.168.0.60
# Give the machine which says its name is "bert" IP address
# 192.168.0.70 and an infinite lease
#dhcp-host=bert,192.168.0.70,infinite
# Always give the host with client identifier 01:02:02:04
# the IP address 192.168.0.60
#dhcp-host=id:01:02:02:04,192.168.0.60
# Always give the host with client identifier "marjorie"
#dhcp-host=id:marjorie,192.168.0.60
# Enable the address given for "judge" in /etc/hosts
# to be given to a machine presenting the name "judge" when
# it asks for a DHCP lease.
#dhcp-host=judge
# Never offer DHCP service to a machine whose Ethernet
# address is 11:22:33:44:55:66
#dhcp-host=11:22:33:44:55:66,ignore
# Ignore any client-id presented by the machine with Ethernet
# address 11:22:33:44:55:66. This is useful to prevent a machine
# being treated differently when running under different OS's or
# between PXE boot and OS boot.
#dhcp-host=11:22:33:44:55:66,id:*
# Send extra options which are tagged as "red" to
# the machine with Ethernet address 11:22:33:44:55:66
#dhcp-host=11:22:33:44:55:66,set:red
# any machine with Ethernet address starting 11:22:33:
#dhcp-host=11:22:33:*:*:*,set:red
# Give a fixed IPv6 address and name to client with
# DUID 00:01:00:01:16:d2:83:fc:92:d4:19:e2:d8:b2
# Note the MAC addresses CANNOT be used to identify DHCPv6 clients.
# Note also the they [] around the IPv6 address are obilgatory.
#dhcp-host=id:00:01:00:01:16:d2:83:fc:92:d4:19:e2:d8:b2, fred, [1234::5]
# Ignore any clients which are not specified in dhcp-host lines
# or /etc/ethers. Equivalent to ISC "deny unknown-clients".
# This relies on the special "known" tag which is set when
# a host is matched.
#dhcp-ignore=tag:!known
# Send extra options which are tagged as "red" to any machine whose
# DHCP vendorclass string includes the substring "Linux"
#dhcp-vendorclass=set:red,Linux
# Send extra options which are tagged as "red" to any machine one
# of whose DHCP userclass strings includes the substring "accounts"
#dhcp-userclass=set:red,accounts
# MAC address matches the pattern.
#dhcp-mac=set:red,00:60:8C:*:*:*
# If this line is uncommented, dnsmasq will read /etc/ethers and act
# on the ethernet-address/IP pairs found there just as if they had
# been given as --dhcp-host options. Useful if you keep
# MAC-address/host mappings there for other purposes.
#read-ethers
# Send options to hosts which ask for a DHCP lease.
# See RFC 2132 for details of available options.
# Common options can be given to dnsmasq by name:
# run "dnsmasq --help dhcp" to get a list.
# Note that all the common settings, such as netmask and
# broadcast address, DNS server and default route, are given
# sane defaults by dnsmasq. You very likely will not need
# any dhcp-options. If you use Windows clients and Samba, there
# are some options which are recommended, they are detailed at the
# end of this section.
# Override the default route supplied by dnsmasq, which assumes the
# router is the same machine as the one running dnsmasq.
#dhcp-option=3,1.2.3.4
# Do the same thing, but using the option name
#dhcp-option=option:router,1.2.3.4
# Override the default route supplied by dnsmasq and send no default
# route at all. Note that this only works for the options sent by
# default (1, 3, 6, 12, 28) the same line will send a zero-length option
# for all other option numbers.
#dhcp-option=3
# Set the NTP time server addresses to 192.168.0.4 and 10.10.0.5
#dhcp-option=option:ntp-server,192.168.0.4,10.10.0.5
# Send DHCPv6 option. Note [] around IPv6 addresses.
#dhcp-option=option6:dns-server,[1234::77],[1234::88]
# Send DHCPv6 option for namservers as the machine running
# dnsmasq and another.
#dhcp-option=option6:dns-server,[::],[1234::88]
# Ask client to poll for option changes every six hours. (RFC4242)
#dhcp-option=option6:information-refresh-time,6h
# Set the NTP time server address to be the same machine as
# is running dnsmasq
#dhcp-option=42,0.0.0.0
# Set the NIS domain name to "welly"
#dhcp-option=40,welly
# Set the default time-to-live to 50
#dhcp-option=23,50
# Set the "all subnets are local" flag
#dhcp-option=27,1
# Send the etherboot magic flag and then etherboot options (a string).
#dhcp-option=128,e4:45:74:68:00:00
#dhcp-option=129,NIC=eepro100
# Specify an option which will only be sent to the "red" network
# (see dhcp-range for the declaration of the "red" network)
# Note that the tag: part must precede the option: part.
#dhcp-option = tag:red, option:ntp-server, 192.168.1.1
# The following DHCP options set up dnsmasq in the same way as is specified
# for the ISC dhcpcd in
# http://www.samba.org/samba/ftp/docs/textdocs/DHCP-Server-Configuration.txt
# adapted for a typical dnsmasq installation where the host running
# dnsmasq is also the host running samba.
# you may want to uncomment some or all of them if you use
# Windows clients and Samba.
#dhcp-option=19,0           # option ip-forwarding off
#dhcp-option=44,0.0.0.0     # set netbios-over-TCP/IP nameserver(s) aka WINS server(s)
#dhcp-option=45,0.0.0.0     # netbios datagram distribution server
#dhcp-option=46,8           # netbios node type
# Send an empty WPAD option. This may be REQUIRED to get windows 7 to behave.
#dhcp-option=252,"\n"
# Send RFC-3397 DNS domain search DHCP option. WARNING: Your DHCP client
# probably doesn't support this......
#dhcp-option=option:domain-search,eng.apple.com,marketing.apple.com
# Send RFC-3442 classless static routes (note the netmask encoding)
#dhcp-option=121,192.168.1.0/24,1.2.3.4,10.0.0.0/8,5.6.7.8
# Send vendor-class specific options encapsulated in DHCP option 43.
# The meaning of the options is defined by the vendor-class so
# options are sent only when the client supplied vendor class
# matches the class given here. (A substring match is OK, so "MSFT"
# matches "MSFT" and "MSFT 5.0"). This example sets the
# mtftp address to 0.0.0.0 for PXEClients.
#dhcp-option=vendor:PXEClient,1,0.0.0.0
# Send microsoft-specific option to tell windows to release the DHCP lease
# when it shuts down. Note the "i" flag, to tell dnsmasq to send the
# value as a four-byte integer - that's what microsoft wants. See
# http://technet2.microsoft.com/WindowsServer/en/library/a70f1bb7-d2d4-49f0-96d6-4b7414ecfaae1033.mspx?mfr=true
#dhcp-option=vendor:MSFT,2,1i
# Send the Encapsulated-vendor-class ID needed by some configurations of
# Etherboot to allow is to recognise the DHCP server.
#dhcp-option=vendor:Etherboot,60,"Etherboot"
# Send options to PXELinux. Note that we need to send the options even
# though they don't appear in the parameter request list, so we need
# to use dhcp-option-force here.
# See http://syslinux.zytor.com/pxe.php#special for details.
# Magic number - needed before anything else is recognised
#dhcp-option-force=208,f1:00:74:7e
# Configuration file name
#dhcp-option-force=209,configs/common
# Path prefix
#dhcp-option-force=210,/tftpboot/pxelinux/files/
# Reboot time. (Note 'i' to send 32-bit value)
#dhcp-option-force=211,30i
# Set the boot filename for netboot/PXE. You will only need
# this is you want to boot machines over the network and you will need
# a TFTP server; either dnsmasq's built in TFTP server or an
# external one. (See below for how to enable the TFTP server.)
#dhcp-boot=pxelinux.0
# The same as above, but use custom tftp-server instead machine running dnsmasq
#dhcp-boot=pxelinux,server.name,192.168.1.100
# Boot for Etherboot gPXE. The idea is to send two different
# filenames, the first loads gPXE, and the second tells gPXE what to
# load. The dhcp-match sets the gpxe tag for requests from gPXE.
#dhcp-match=set:gpxe,175 # gPXE sends a 175 option.
#dhcp-boot=tag:!gpxe,undionly.kpxe
#dhcp-boot=mybootimage
# Encapsulated options for Etherboot gPXE. All the options are
# encapsulated within option 175
#dhcp-option=encap:175, 1, 5b         # priority code
#dhcp-option=encap:175, 176, 1b       # no-proxydhcp
#dhcp-option=encap:175, 177, string   # bus-id
#dhcp-option=encap:175, 189, 1b       # BIOS drive code
#dhcp-option=encap:175, 190, user     # iSCSI username
#dhcp-option=encap:175, 191, pass     # iSCSI password
# Test for the architecture of a netboot client. PXE clients are
# supposed to send their architecture as option 93. (See RFC 4578)
#dhcp-match=peecees, option:client-arch, 0 #x86-32
#dhcp-match=itanics, option:client-arch, 2 #IA64
#dhcp-match=hammers, option:client-arch, 6 #x86-64
#dhcp-match=mactels, option:client-arch, 7 #EFI x86-64
# Do real PXE, rather than just booting a single file, this is an
# alternative to dhcp-boot.
#pxe-prompt="What system shall I netboot?"
# or with timeout before first available action is taken:
#pxe-prompt="Press F8 for menu.", 60
# Available boot services. for PXE.
#pxe-service=x86PC, "Boot from local disk"
# Loads <tftp-root>/pxelinux.0 from dnsmasq TFTP server.
#pxe-service=x86PC, "Install Linux", pxelinux
# Loads <tftp-root>/pxelinux.0 from TFTP server at 1.2.3.4.
# Beware this fails on old PXE ROMS.
#pxe-service=x86PC, "Install Linux", pxelinux, 1.2.3.4
# Use bootserver on network, found my multicast or broadcast.
#pxe-service=x86PC, "Install windows from RIS server", 1
# Use bootserver at a known IP address.
#pxe-service=x86PC, "Install windows from RIS server", 1, 1.2.3.4
# If you have multicast-FTP available,
# information for that can be passed in a similar way using options 1
# to 5. See page 19 of
# http://download.intel.com/design/archives/wfm/downloads/pxespec.pdf
# Enable dnsmasq's built-in TFTP server
#enable-tftp
# Set the root directory for files available via FTP.
#tftp-root=/var/ftpd
# Make the TFTP server more secure: with this set, only files owned by
# the user dnsmasq is running as will be send over the net.
#tftp-secure
# This option stops dnsmasq from negotiating a larger blocksize for TFTP
# transfers. It will slow things down, but may rescue some broken TFTP
# clients.
#tftp-no-blocksize
# Set the boot file name only when the "red" tag is set.
#dhcp-boot=tag:red,pxelinux.red-net
# An example of dhcp-boot with an external TFTP server: the name and IP
# address of the server are given after the filename.
# Can fail with old PXE ROMS. Overridden by --pxe-service.
#dhcp-boot=/var/ftpd/pxelinux.0,boothost,192.168.0.3
# If there are multiple external tftp servers having a same name
# (using /etc/hosts) then that name can be specified as the
# tftp_servername (the third option to dhcp-boot) and in that
# case dnsmasq resolves this name and returns the resultant IP
# addresses in round robin fasion. This facility can be used to
# load balance the tftp load among a set of servers.
#dhcp-boot=/var/ftpd/pxelinux.0,boothost,tftp_server_name
# Set the limit on DHCP leases, the default is 150
#dhcp-lease-max=150
# The DHCP server needs somewhere on disk to keep its lease database.
# This defaults to a sane location, but if you want to change it, use
# the line below.
#dhcp-leasefile=/var/lib/misc/dnsmasq.leases
# Set the DHCP server to authoritative mode. In this mode it will barge in
# and take over the lease for any client which broadcasts on the network,
# whether it has a record of the lease or not. This avoids long timeouts
# when a machine wakes up on a new network. DO NOT enable this if there's
# the slightest chance that you might end up accidentally configuring a DHCP
# server for your campus/company accidentally. The ISC server uses
# the same option, and this URL provides more information:
# http://www.isc.org/files/auth.html
#dhcp-authoritative
# Run an executable when a DHCP lease is created or destroyed.
# The arguments sent to the script are "add" or "del",
# then the MAC address, the IP address and finally the hostname
# if there is one.
#dhcp-script=/bin/echo
# Set the cachesize here.
#cache-size=150
# If you want to disable negative caching, uncomment this.
#no-negcache
# Normally responses which come from /etc/hosts and the DHCP lease
# file have Time-To-Live set as zero, which conventionally means
# do not cache further. If you are happy to trade lower load on the
# server for potentially stale date, you can set a time-to-live (in
# seconds) here.
#local-ttl=
# If you want dnsmasq to detect attempts by Verisign to send queries
# to unregistered .com and .net hosts to its sitefinder service and
# have dnsmasq instead return the correct NXDOMAIN response, uncomment
# this line. You can add similar lines to do the same for other
# registries which have implemented wildcard A records.
#bogus-nxdomain=64.94.110.11
# If you want to fix up DNS results from upstream servers, use the
# alias option. This only works for IPv4.
# This alias makes a result of 1.2.3.4 appear as 5.6.7.8
#alias=1.2.3.4,5.6.7.8
# and this maps 1.2.3.x to 5.6.7.x
#alias=1.2.3.0,5.6.7.0,255.255.255.0
# and this maps 192.168.0.10->192.168.0.40 to 10.0.0.10->10.0.0.40
#alias=192.168.0.10-192.168.0.40,10.0.0.0,255.255.255.0
# Change these lines if you want dnsmasq to serve MX records.
# Return an MX record named "maildomain.com" with target
# servermachine.com and preference 50
#mx-host=maildomain.com,servermachine.com,50
# Set the default target for MX records created using the localmx option.
#mx-target=servermachine.com
# Return an MX record pointing to the mx-target for all local
# machines.
#localmx
# Return an MX record pointing to itself for all local machines.
#selfmx
# Change the following lines if you want dnsmasq to serve SRV
# records.  These are useful if you want to serve ldap requests for
# Active Directory and other windows-originated DNS requests.
# See RFC 2782.
# You may add multiple srv-host lines.
# The fields are <name>,<target>,<port>,<priority>,<weight>
# If the domain part if missing from the name (so that is just has the
# service and protocol sections) then the domain given by the domain=
# config option is used. (Note that expand-hosts does not need to be
# set for this to work.)
# A SRV record sending LDAP for the example.com domain to
# ldapserver.example.com port 389
#srv-host=_ldap._tcp.example.com,ldapserver.example.com,389
# ldapserver.example.com port 389 (using domain=)
#domain=example.com
#srv-host=_ldap._tcp,ldapserver.example.com,389
# Two SRV records for LDAP, each with different priorities
#srv-host=_ldap._tcp.example.com,ldapserver.example.com,389,1
#srv-host=_ldap._tcp.example.com,ldapserver.example.com,389,2
# A SRV record indicating that there is no LDAP server for the domain
# example.com
# The following line shows how to make dnsmasq serve an arbitrary PTR
# record. This is useful for DNS-SD. (Note that the
# domain-name expansion done for SRV records _does_not
# occur for PTR records.)
#ptr-record=_http._tcp.dns-sd-services,"New Employee Page._http._tcp.dns-sd-services"
# Change the following lines to enable dnsmasq to serve TXT records.
# These are used for things like SPF and zeroconf. (Note that the
# occur for TXT records.)
#Example SPF.
#txt-record=example.com,"v=spf1 a -all"
#Example zeroconf
#txt-record=_http._tcp.example.com,name=value,paper=A4
# Provide an alias for a "local" DNS name. Note that this _only_ works
# for targets which are names from DHCP or /etc/hosts. Give host
# "bert" another name, bertrand
#cname=bertand,bert
# For debugging purposes, log each DNS query as it passes through
# dnsmasq.
#log-queries
# Log lots of extra information about DHCP transactions.
#log-dhcp
# Include another lot of configuration options.
#conf-file=/etc/dnsmasq.more.conf
#conf-dir=/etc/dnsmasq.d
# Include all the files in a directory except those ending in .bak
#conf-dir=/etc/dnsmasq.d,.bak
# Include all files in a directory which end in .conf
#conf-dir=/etc/dnsmasq.d/*.conf
interface=wlan0			#use the require wireless interface
#usually wlan0
	dhcp-range=192.168.3.2,192.168.3.20,255.255.255.0,24h
  • /etc/hostapd/hostapd.conf
interface=wlan0
driver=nl80211
ssid= RASP-WIFI
country_code=FR
# le n utilise la bande de frequence de g, voir  80211n=1
hw_mode=g
channel=7
wmm_enabled=0
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
# juste wpa2, si wpa et wpa2, alors 3
wpa=2
wpa_passphrase=Mot_De_Passe
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
  • /etc/default/hostapd
# Location of hostapd configuration file
DAEMON_CONF="/etc/hostapd/hostapd.conf"
# Additional daemon options to be appended to hostapd command:-
#   -d   show more debug messages (-dd for even more)
#   -K   include key data in debug messages
#   -t   include timestamps in some debug messages
# Note that -B (daemon mode) and -P (pidfile) options are automatically
# configured by the init.d script and must not be added to DAEMON_OPTS.
#DAEMON_OPTS=""
jim53
Fri Oct 26, 2018 4:57 pm
Does anyone have any idea why I can not create an access point with my WIFI USB adapter?
jim53
Sun Oct 28, 2018 10:17 am
Do you think it will be better to re install raspbian and retry?
