jusme
Is this camera connector backwards?
Sun Oct 21, 2018 5:53 pm
Just bought a new Pi-3 B+ from a reputable supplier (who shall remain nameless unless proven guilty), but I can't get any camera modules to work with it. Tested several cameras, v1.3, v2.1, standard and NOIR, all work on another Pi (also 3-B+, with the same SD card), but none on the new one.
Looking closely at the connector, it appears to be fitter the wrong way round - the contacts are on the left-hand (Ethernet) side, and there is a large plastic tab on the right-hand (HDMI) side, that seems to prevent any possibility of an electrical connection:
Working:
Faulty?:
Haven't seen any other reports of this problem, so can anyone confirm this looks wrong before I shout at [REDACTED] for making me waste a hour on this???
Sometimes you need to reinvent the wheel, not because you need wheels, but because you need inventors
gordon77
Re: Is this camera connector backwards?
Sun Oct 21, 2018 6:28 pm
It certainly looks it to me. Can you get the camera cable between the pins and the connector?
jusme
Sun Oct 21, 2018 7:05 pm
Nope, the electrical contacts are on the "wrong" (left) side, there's nothing to connect to on the "right" side - pic with the latch removed:
gordon77
Sun Oct 21, 2018 7:32 pm
I'd return it to the supplier.
Sun Oct 21, 2018 7:58 pm
Yes, return it. I believe I have seen another post where a camera connector had been fitted the wrong way round. I guess a small batch had been assembled incorrectly.
Roger_Thornton
Mon Oct 22, 2018 10:36 am
Could you post a photo of the 2D barcode on the back of the board?
jusme
Mon Oct 22, 2018 5:40 pm
HamBurger
Fri May 03, 2019 12:50 am
I just purchased a Pi 3 Model B+ with what appears to be the same problem. The camera connector is backwards.
Screen Shot 2019-05-02 at 7.47.32 PM.png (23.21 KiB) Viewed 1612 times
The attachment Screen Shot 2019-05-02 at 7.47.32 PM.png is no longer available
Matt_Claridge
Fri Jul 05, 2019 2:03 am
Just found 3 with the same issue in our batch.
HawaiianPi
Fri Jul 05, 2019 3:31 am
Any idea where and when these were made?
Should I worry about the ones I bought a year ago? I purchased a few 3B+ computers between launch and early July 2018.
EDIT:
Just checked one of mine and it seems okay. Dark colored connector like the working pic, and facing the right way (07/02 on sticker). They're all in Flirc cases, whose one drawback is you can't see the cool little computer inside.
Fri Jul 05, 2019 5:00 am
What you need is cases made from transparent aluminium :)
Unreadable squiggle
rlapihuska
Thu May 14, 2020 4:22 pm
Grr...I just tried hooking up a camera to a B+ that I bought back in August of 2019 and same issue. Comparing to a B v 1.2 both the camera and display ribbon connectors are backward. Someone loaded up the pick and place machine backward. And since the Kapton sticker was still in place I'm sure they don't test these ports. Anyway, my camera wasn't fried luckily. Still works on the B I have. Going to try for a replacement from the seller.
Return to “Camera board”
