tony1812
How to link java program logic to UI in netbeans
Fri Oct 19, 2018 2:30 pm
Hello. I just started self-taught Java on netbeans. I failed to understand how a program logic is related to the gui. In the code below, I want the user be able to click on a jbutton object, then the code will send a char '1' to the HC-05 serial port. The structure on netbeans is like this attached screen shot:
code for the logic is
 * To change this license header, choose License Headers in Project Properties.
 * To change this template file, choose Tools | Templates
 * and open the template in the editor.
package test:
import arduino.*;
public class Test {
     * @param args the command line arguments
    public static void main(String[] args) {
        Arduino  a = new Arduino();
        a.setPortDescription("/dev/cu.HC-05-1-DevB"); // ("/dev/cu.usbmodem1D1330");
        a.openConnection();
        a.serialWrite('1');
        a.closeConnection();
And code for the UI:
package my.test;
 * @author dick
public class Test_UI extends javax.swing.JFrame {
     * Creates new form Test_UI
    public Test_UI() {
        initComponents();
     * This method is called from within the constructor to initialize the form.
     * WARNING: Do NOT modify this code. The content of this method is always
     * regenerated by the Form Editor.
    @SuppressWarnings("unchecked")
    // <editor-fold defaultstate="collapsed" desc="Generated Code">
    private void initComponents() {
        jPanel1 = new javax.swing.JPanel();
        jButton1 = new javax.swing.JButton();
        setDefaultCloseOperation(javax.swing.WindowConstants.EXIT_ON_CLOSE);
        jButton1.setText("jButton1");
        javax.swing.GroupLayout jPanel1Layout = new javax.swing.GroupLayout(jPanel1);
        jPanel1.setLayout(jPanel1Layout);
        jPanel1Layout.setHorizontalGroup(
            jPanel1Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
            .addGroup(javax.swing.GroupLayout.Alignment.TRAILING, jPanel1Layout.createSequentialGroup()
                .addContainerGap(155, Short.MAX_VALUE)
                .addComponent(jButton1)
                .addGap(150, 150, 150))
        jPanel1Layout.setVerticalGroup(
            .addGroup(jPanel1Layout.createSequentialGroup()
                .addGap(116, 116, 116)
                .addContainerGap(140, Short.MAX_VALUE))
        javax.swing.GroupLayout layout = new javax.swing.GroupLayout(getContentPane());
        getContentPane().setLayout(layout);
        layout.setHorizontalGroup(
            layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
            .addGroup(layout.createSequentialGroup()
                .addContainerGap()
                .addComponent(jPanel1, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
                .addContainerGap())
        layout.setVerticalGroup(
                .addContainerGap()
                .addContainerGap())
        pack();
    }// </editor-fold>
    public static void main(String args[]) {
        /* Set the Nimbus look and feel */
        //<editor-fold defaultstate="collapsed" desc=" Look and feel setting code (optional) ">
        /* If Nimbus (introduced in Java SE 6) is not available, stay with the default look and feel.
         * For details see http://download.oracle.com/javase/tutorial/uiswing/lookandfeel/plaf.html
        try {
            for (javax.swing.UIManager.LookAndFeelInfo info : javax.swing.UIManager.getInstalledLookAndFeels()) {
                if ("Nimbus".equals(info.getName())) {
                    javax.swing.UIManager.setLookAndFeel(info.getClassName());
                    break;
        } catch (ClassNotFoundException ex) {
            java.util.logging.Logger.getLogger(Test_UI.class.getName()).log(java.util.logging.Level.SEVERE, null, ex);
        } catch (InstantiationException ex) {
        } catch (IllegalAccessException ex) {
        } catch (javax.swing.UnsupportedLookAndFeelException ex) {
        //</editor-fold>
        /* Create and display the form */
        java.awt.EventQueue.invokeLater(new Runnable() {
            public void run() {
                new Test_UI().setVisible(true);
    // Variables declaration - do not modify
    private javax.swing.JButton jButton1;
    private javax.swing.JPanel jPanel1;
    // End of variables declaration
How do I link them? If someone can show my the code to link them will be very helpful. Thanks.
fbe
Re: How to link java program logic to UI in netbeans
Sat Oct 20, 2018 7:43 pm
You need an object that implements the java.awt.ActionListener interface. E.g.:
        implements java.awt.event.ActionListener {
        jButton1.setActionCommand("test command");
        jButton1.addActionListener(this);
     * java.awt.event.ActionListener implementation
     * @param e
    @Override
    public void actionPerformed(java.awt.event.ActionEvent e) {
        if ("test command".equals(e.getActionCommand())) {
            System.exit(0);
How to Use Buttons, Check Boxes, and Radio Buttons https://docs.oracle.com/javase/tutorial ... utton.html
Return to “Java”
