gwaines
How to disable auto-configuration of link local address on raspberry pi when no DHCP response
Fri Oct 19, 2018 11:47 am
I am running Kubernetes on raspberry pi.
The raspberry pi is a kube worker.
I was previously using a wired connection and had DHCP disabled.
But now switching things to wifi.
I am using wifi, configured with rasp-config to use DHCP.
My wireless connection comes up fine.
However when I do my 'kubeadm join ...' which fires up kube-proxy and flannel containers, the flannel container creates a flannel.1 interface and configures an IP Address on that interface ...
HOWEVER dhcpcd on the raspberry tries to DHCP out that interface ... gets no response ... and then a link local address gets configured on that interface as a second IP Address .... and this appears to be causing problems with flannel ... (i.e. saw the same issue when I was using wired connection and disabled DHCP and used static IP Address to get around this issue)
So QUESTIONS:
a) is there a way to disable auto-configuration of link local address on PI when no dhcp response occurs ?
or
b) is it possible to configure static IP address for wireless connection on PI ? (i tried quickly and couldn't get it to work)
Gre.g
Andyroo
Re: How to disable auto-configuration of link local address on raspberry pi when no DHCP response
Fri Oct 19, 2018 12:43 pm
Static IPs for WiFi on the Pi is possible.
One of the best threads for this is https://raspberrypi.stackexchange.com/q ... ip-address as it covers multiple operating system versions :lol:
Basically, to set a static IP address up you add something along the lines of
       interface wlan0
       static ip_address=10.1.1.31/24
       static routers=10.1.1.1
       static domain_name_servers=10.1.1.1
to /etc/dhcpcd.conf
Note the article also shows you how to disable interface configuration and another way to set statics - neither of which I have tried :twisted: :roll:
epoch1970
Fri Oct 19, 2018 2:26 pm
See "man dhcpcd": options denyinterface, noipv4ll, nodhcp...
Return to “Advanced users”
