superbogel
PiWebserver isn't available from android
Tue Oct 16, 2018 6:53 am
I setup the pi 3 with an access point and also with webserver running a static html site for my local house environment, I setup the bridge ap point method using the raspberry tutorial ap point and also when I disconnected the cable from the pi, I can login to the pi hotspot and went to browser when I hit raspberrypi.local, its showing the local webserver which is working great.
but when I use my android device and try to connect to the pi with ap, its just stopping on obtaining ip address and never connected, and I tried assigning static ip into it and it connected but when I open up the android browser and hit the raspberrypi.local it shows err_name_not_resolved. and when I type in the ip of the pi which is 169.254.10.247 it just redirect to the raspberrypi.local but same err_name_not_resolved error
anything I am missing here?
billybangleballs
Re: PiWebserver isn't available from android
Sun Oct 21, 2018 7:49 pm
A DHCP server by the sounds of it.
Grumpy old man.
Ex-G0KAP - I'd rather be doing it than talking about it.
"When found, make a note of." - Captain Cuttle
