approxdec
windows 10 network mapping
Sat Oct 13, 2018 12:36 am
hello everyone.
in a windows 10 to RPi network connection [ethernet, B+, raspian stretch]
is it usual to expose the /pi directory in the "Map Network Drive' / "Browse for Folder" dialogue ?
i can't remember my first view before network fiddlin' .
have i exposed this myself and if so how do NOT expose it?
thanks
joe
hortimech
Re: windows 10 network mapping
Sat Oct 13, 2018 12:45 pm
I take it you have a part of your smb.conf that starts '[homes]', is so, remove it along with the lines associated with it.
If unsure post your smb.conf
LTolledo
Sat Oct 13, 2018 12:55 pm
set
browsable = no
in your smb.conf
Some people be like:
DirkS
Sat Oct 13, 2018 4:23 pm
set
browsable = no
in your smb.conf
Indeed. And it needs to go into the [homes] section.
hortimech
Sat Oct 13, 2018 6:56 pm
Well yes, you could that, but it is probably just papering over the problem, hiding it doesn't mean it isn't there. Most rpi's have a user called rpi, so you can navigate to the users home directory with the UNC. So if you don't want your home directory to be available via Samba, do not share it.
DirkS
Sat Oct 13, 2018 8:20 pm
Again acting as a 'clarifier': this means you have to remove / deactivate the [homes] section
LTolledo
Sat Oct 13, 2018 10:10 pm
if you dont want your RPi visible in any way in the network... then run these set of commands
sudo apt remove --purge samba samba-common-bin
sudo apt clean
sudo apt autoremove
DirkS
Sat Oct 13, 2018 10:27 pm
sudo apt clean
sudo apt autoremove
OP is just 'complaining' about the visibility of the 'pi' directory, not any of the other shares,
approxdec
Sat Oct 13, 2018 11:22 pm
thank you everyone for your replies.
i need to work through each to make sure i get it.
and sorry i did not reply earlier - my post took quite a while
before it was visible to me.
hortimech
Sun Oct 14, 2018 8:47 am
sudo apt clean
sudo apt autoremove
You forgot Avahi, nfs etc
hortimech
Sun Oct 14, 2018 8:49 am
I said basically that in my first post in this thread.
Who is online
Users browsing this forum: No registered users and 50 guests
