fromJPN
how can I disable zeroconf ?
Thu Oct 11, 2018 4:28 am
Hello.
I am stuck with this problem. Help me. :(
A system is 2017-07-05 raspbian-jessie-lite.
It works on raspberry pi zero w.
1) I connected two raspi with WiFi in ad-hoc mode.
2) Two raspi set static IP. The setting is as follows.
# vi /etc/network/interfaces
    source-directory /etc/network/interfaces.d
    auto lo
    iface lo inet loopback
    #iface eth0 inet dhcp
    auto wlan0
    allow-hotplug wlan0
        iface wlan0 inet static
        address 192.168.44.63
        netmask 255.255.255.0
        wireless-channel 3         # channel number can be any number
        wireless-mode ad-hoc
        wireless-essid myname
        wireless-key 1234567890    # 10 or 26 digits as hex
3) The two raspi's were able to connect successfully! The ping command also succeeds.
4) But there is a problem.
5) In addition to the 192.168.44.63 I set, another 169.254.32.159 is automatically allocated for the IP address.
6) On the screen immediately after startup, it is displayed as follows.
    My IP address is 192.168.44.63   169.254.32.159
7) In the investigation command, it is displayed as follows.
# netstat -rn
Kernel IP routing table
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
169.254.0.0     0.0.0.0         255.255.0.0     U         0 0          0 wlan0
192.168.44.0    0.0.0.0         255.255.255.0   U         0 0          0 wlan0
8) When I examine it, this is a function called "zeroconf", it seems to be a function to assign an IP address in a network environment NO DHCP server.
9) In other Linux, zeroconf function seems to can disable with "NOZEROCONF = yes" etc, but related information could not be found about raspi.
10) I have execute the next command, but the phenomenon that 169.254.32.159 was automatically allocated was not improved.
# systemctl disable avahi-daemon
# systemctl stop avahi-daemon
Please tell me how can I disable zeroconf function on raspi. :|
epoch1970
Re: how can I disable zeroconf ?
Thu Oct 11, 2018 11:58 am
First Jessie is dead, you're more or less on your own if you're still using it.
The ipv4 "link-local" (aka zeroconf, bonjour, APIPA) address is probably generated by dhcpcd
Try adding "noipv4ll" in dhcpcd.conf. See "man dhcpcd.conf"
In addition, if you have an avahi-daemon scriptlet in /etc/network/if-up.d/, make sure to set AVAHI_DAEMON_DETECT_LOCAL=0 in /etc/default/avahi-daemon.
The scriptlet calls /usr/lib/avahi/avahi-daemon-check-dns.sh, which restarts avahi-daemon if it is not running. It does it old school via /etc/init.d/ and does not care if the service was disabled via systemd.
In general having multiple IP addresses per interface is not considered a problem. mDNS is often useful.
fromJPN
Fri Oct 12, 2018 7:06 am
To epoch 1970
Thank you very much for your answers and advice.
It worked ! !
Jessie, she works very well. :D
