soydepr
under voltage detected [solved]
Wed Oct 10, 2018 8:20 pm
have a pi attached to monitor with no keyboard.
I see lines saying under voltage detected (0x000050000000)
what is this, dying?
Imperf3kt
Re: under voltage detected
Wed Oct 10, 2018 8:23 pm
No, it simply means your power supply is inadequate.
You need one that supplies 5v at about 2Amps or more (2.5 for a Pi3b+)
Don't trust the labelling too much on phone chargers, it isn't uncommon for them to be less than truthful.
55:55:44:44:4C
52:4C:52:42:41
soydepr
Wed Oct 10, 2018 8:27 pm
care recommend one
drgeoff
Wed Oct 10, 2018 8:38 pm
care recommend one
The official RPi one is highly recommended.
soydepr
link please
Imperf3kt
Wed Oct 10, 2018 8:46 pm
Where do you live (country is enough) , would help us give you a link of any use.
You could also look on the main suite, it has links to all the Raspberry Pi products.
55:55:44:44:4C
52:4C:52:42:41
soydepr
Wed Oct 10, 2018 8:48 pm
U.S main suite ?
LTolledo
Wed Oct 10, 2018 9:48 pm
Get a proper Power Supply Unit (not just any phone charger nor your PC/Mac's USB port!)
If RPi3B or RPi3B+ : use 5v 2.5A and up, cable must be 18AWG or at least 1.0mmsq
if RPi2B : use 5v 2.0A and up, cable must be 18AWG or at least 1.0mmsq
if RPi1B+, RPiZ/W : use 5v 1.5A and up, cable must be 20AWG or at least 0.75mmsq
if RPiA+ : use 5v 1.0A and up, cable must be 20AWG or at least 0.75mmsq
5v must not go below 4.9v nor beyond 5.15v
Some people be like:
davidcoton
Wed Oct 10, 2018 9:57 pm
That's a bit cautious. The Pi spec allows 4V75-5V25 at the microUSB socket. Those limits should be maintained from Pi shutdown to full load.
Signature retired
LTolledo
Wed Oct 10, 2018 10:06 pm
Better safe than sorry and regret later.....
Wed Oct 10, 2018 10:23 pm
The happiest Pi I have is run from a 5v supply that can deliver 4 amps.
But this supply can be tweaked up and down a bit by winding a trim pot.
Turns out the Pi is happiest when the supply is outputting 5.3 volts or so.
It amazing how much voltage can be lost through short lengths of cheap skinny USB cables.
Imperf3kt
Wed Oct 10, 2018 11:13 pm
I'm more inclined to blame the connections on the ends of those cables.
I once bought the cheapest, crappiest cable I could find and plugged it into a known good 5A source. Naturally it failed to deliver enough current to even sit idle at the Raspbian desktop.
But, as soon as I lopped off the microUSB connector and applied power to the GPIO header, there was no more undervolt detected.
Make of that what you will.
55:55:44:44:4C
52:4C:52:42:41
soydepr
Thu Oct 11, 2018 1:51 am
stange the one I have came with the PI as a kit
W. H. Heydt
I'm skeptical about that particular set of requirements. I tested a Pi0+3.5" display (GPIO mounted) and the whole thing drew less than 250mA, and most of the time it ran at about 185mA. The B+ is, IIRC, spec'd for and polyfused at 1.1A, so a 1.5A PSU is mild overkill. An A+ should run on more like 500mA, even under load. The Pi0, Pi0W, and A+ all lack the rather power hungry LAN chip, and with only one USB port really don't need enough power to output more than 500mA, max. and probably a good deal less in most cases.
The main thing, though, is that the Pi0 and Pi0W should not be lumped in with the B+. They have a lot more in common with the A+.
Imperf3kt
Thu Oct 11, 2018 2:10 am
Most kit resellers package their own PSU, not the official PSU.
Does it have an attached cable, or do you plug in a usb cable?
If you plug in a usb cable, then it might be the cable and not the PSU
55:55:44:44:4C
52:4C:52:42:41
HawaiianPi
Fri Oct 12, 2018 10:36 pm
soydepr wrote:
Thu Oct 11, 2018 11:42 pm
attached!!!
https://www.amazon.com/CanaKit-Raspberr ... berry+pi+3
The Canakit PSU is okay (I've had one), but the official Raspberry Pi Universal Power Supply is better. I've seen the Canakit PSU dip a little below 5V under load, but not enough to cause a low voltage warning (at least mine didn't).
What else do you have connected to your pi that is drawing power?
Are you using the case from the kit?
Anything else connected between the PSU and Pi (power switch, etc.)?
soydepr
Sat Oct 13, 2018 11:01 am
yes using the case .
only thing connected is a hdmi monitor, nothing else, no keyboard no mouse
HawaiianPi
Sat Oct 13, 2018 11:26 am
Sounds like your power supply is not outputting what it is supposed to. With nothing but HDMI connected the Canakit PSU should work fine. I used mine on my Pi3B with an external USB hard drive. Try contacting Canakit to see about a replacement.
Sat Oct 13, 2018 11:50 am
Never had issues with Official PSU:
https://www.raspberrypi.org/products/ra ... er-supply/
Retired disgracefully.....
......to a more gentile life !
ebolisa
Wed Mar 06, 2019 9:41 am
Sorry for resurrecting this post but I've a doubt...
I'm running a B+ with updated debian stretch plugged in the extension board seen here: https://www.kubii.es/tarjetas-de-extens ... 13346.html
The 5V is fed via pins 2 & 4 as per the extension's board design (so, not through the USB connector).
The PS used is a 5V 3A as shown here: https://www.meanwell.co.uk/dr-30-5.html
However, I'm still getting the following messages
Under-voltage detected! (0x00050005) / Voltage normalised (0x00000000)
So, I'm suspecting that the Pi's voltage sensing is done within the USB circuitry otherwise, I cannot understand the message.
Any help/ideas is appreciated.
TIA
I know that I know nothing
Brandon92
Wed Mar 06, 2019 9:48 am
Did you measure the output voltage of that power supply. Because you have the option to adjust the output voltage. And are you using as a wire?
ebolisa
Wed Mar 06, 2019 9:57 am
The input voltage at the extension board is 5.2V and less than 1A.
I'm using 1.5 mm wires to feed the extension boad if it's what you mean by
Wed Mar 06, 2019 10:43 am
TIA
In future, rather than ressurecting an old thread, just start a new one.
ebolisa
Wed Mar 06, 2019 10:54 am
Will do but I thought to follow through for being the same subject.
