Damo_C
4G Hat
Mon Oct 08, 2018 10:59 pm
I've got a Pi model 3 B, and I've purchased the following 4G hat, however I'm unsure how to actually establish an internet connection through it.. so hoping for a little assistance, or peoples suggestions.
2G/3G/4G GSM GPRS GNSS SIM GPS Extension Board for Raspberry Pi 2 3B B+ ZeroW GM
I can query the card using minicom -D /dev/ttyS0 and see that its got signal, query the carrier etc. However I'm unsure how to go about setting it up as either a modem or other network device to access the internet.
I've also tried using the USB port (not the one labelled UART), and I get a wwan0 adapter, however it only get a self-assigned IP. Upon connecting it to my Windows computer through the same USB port, I get several devices install, one of which is a network adapter but it shows that the cable is 'unplugged' - I haven't really tried anything further through Windows as this stage.
What I would like to achieve is have the Pi connected to the internet via the 4G hat, and be able to query the GPS part of the card to get the location - I'm not fussed if thats just by command line. I'd like to have it connected via the GPIO pins, but not fussed if it also needs to be connected via USB as well (the manual didn't seem to show how it should be connected unless I missed something?)
here is a link to the manual: Waveshare Wiki
plugwash
Re: 4G Hat
Tue Oct 09, 2018 1:59 am
A quick search for "SIM7600 linux" found https://techship.com/faq/how-to-use-sim ... -over-usb/ which looks like it may be helpful.
Damo_C
Re: 4G Hat
Wed Oct 10, 2018 1:05 am
Cheers - thanks for that.. I hadn't seen that one..
I have gotten it working, possibly a little easier than what those instructions said, probably not 100% ideal but it works.
I've got it connected via the GPIO pins + the USB connection..
On boot I've got a script running which initialises the card via the GPIO. The 4G modem then appears as a "mobile broadband" connection in Network manager.
I've started work on the GPS chip, which is enabled with minicom -D /dev/ttyS0 and then the command AT+CGPS =1 then running minicom -D /dev/ttyUSB1 you can see the GPS data scrolling through. I'm just looking at my options now to see how (if) I can go about getting the latitude + longitude from the GPS in terminal.
Damo_C
Re: 4G Hat
Sat Oct 13, 2018 5:17 am
Update on my last post.. it wasn't 100% working. I had been able to see the mobile broadband device, it was reading the provider from the sim card, and was showing signal strength however it would fail immediately when I tried to connect.
I've gone through and followed the instructions from the link and another page which said how to pull the IP info, and manually assign it to the wwan0 interface, however it doesn't give me a connection to the internet. I've got two sim cards with different providers, and I've checked the APNs as well..
I did read an article that said it could be a driver issue, but the only driver for linux I've found has Chinese installation instructions.
jmfalcon
Re: 4G Hat
Tue Oct 23, 2018 1:23 pm
Hello Damo_C
I am at the moment starting my IoT project, using the same both devices as you: Raspberry Pi 3B+, plus the SIM7600 4G HAT (which I did not receive yet). Great that your project is also running almost simultaneously, in order to share support between us.
Up to this moment, I would like to ask you about the tool https://techship.com/faq/how-to-use-sim ... -over-usb/ you implemented.
Did you get it to implement it 100% ?
I do not understand which advantage this offers, over my original idea: just sending AT commands to the HAT device through UART (RPi GPIOs). Could you please roughly describe it to me?
Thanks in advance.
Lsureal83
Re: 4G Hat
Wed Jan 09, 2019 12:10 pm
was there any progress with this. Were you able to use the sim7600 as a modem through USB connection on the pi and if so how did you achive this I am having simular issues with.
Thanks.
MyLittlePony
Re: 4G Hat
Sun Feb 10, 2019 8:26 pm
Hi
Am having similar issues with the SIM 7600.
Have worked through the Waveshare manual, the files seem to deploy ok
Concerning minicom, all it says is "Starting up" ....... then nothing
Any help with commands to interrogate the hat appreciated
vulcan25
Re: 4G Hat
Mon Feb 11, 2019 11:58 pm
A word of advice for anyone in the UK thinking of buying this. I found a very similar one branded 'Waveshare' on Amazon that looks identical to the one in this ebay link, and has a 4 star review with a comment:
Unfortunately I did not properly check the specifications and information about the LTE types. This device uses LTE M which isn't the standard 4G/LTE network. It will fall back to 2G, but some networks - such as 3 in the UK won't support this and therefore this device is incompatible with them.
dobova86
Re: 4G Hat
Fri Feb 22, 2019 3:45 pm
I'm going to test Waveshare board and 4G (Vodafone network) ...
Be aware that SIM7600E has "-H" and "-T" chip. DON'T buy "-T" chip, it is for China.
Example chip for Europe:
Vincent14
Re: 4G Hat
Sun Mar 10, 2019 10:41 pm
Did anyone have any success with this kit?
aford88
Re: 4G Hat
Sat Mar 30, 2019 4:43 pm
Any updates on this? Trying to get it working at the moment - SMS, phone calls and GPS are all working - I just can't get the 4g connection established.
mkrzysztofowicz
Re: 4G Hat
Mon Apr 01, 2019 11:55 pm
I've spent the whole evening today and couldn't get it to even see the network.
@aford88 - could you share with me what exactly did you do to get it to work with SMS and phone calls? I got the GPS part working OK.
Thanks!
mkrzysztofowicz
Re: 4G Hat
Wed Apr 03, 2019 11:35 am
OK, I've got this working fully now!
For those of you who are still struggling, here's the required steps:
1. Install required software
pi:~$ sudo apt-get update && sudo apt-get install libqmi-utils udhcpc
2. This one is important - when you reboot the pi, the SIM7600 module's cellular radio is OFF and needs to be turned ON before you can see the mobile network. One way is to use a script which pulls the GPIO pin 4 LOW for a second or two (as per this post: https://lb.raspberrypi.org/forums/viewt ... 1#p1368015), but a more elegant way I think is to use the newly installed qmi utils:
pi:~$ sudo qmicli -d /dev/cdc-wdm0 --dms-set-operating-mode='online'
Note, you can verify if your radio needs to be turned on by using the following commands:
qmicli -d /dev/cdc-wdm0 --dms-get-operating-mode
qmicli -d /dev/cdc-wdm0 --nas-get-signal-strength
qmicli -d /dev/cdc-wdm0 --nas-get-home-network
If the first command shows in its output 'Low Power' or anything other than 'online' it means your radio is off and needs to be turned on.
The last of those commands should return the LTE network ID if your device successfully connected.
3. Reconfigure the network interface for raw-ip protocol
The qmi-wwan kernel driver creates the wwan0 network interface for you when it detects the SIM7600 module connected to your Raspberry Pi. By default that interface is set to 802-3 protocol, however it seems the correct protocol should be raw-ip. The qmi-network script tries to set that up for you, but it will most likely fail. To make the change, do the following:
pi:~$ sudo qmicli -d /dev/cdc-wdm0 -w		# this confirms the name of the network interface, typically wwan0
pi:~$ sudo ip link set wwan0 down		# change the wwan0 to the one returned above if different
pi:~$ echo 'Y' | sudo tee /sys/class/net/wwan0/qmi/raw_ip
pi:~$ sudo ip link set wwan0 up
4. Connect to the mobile network.
After having done all the above, when trying to use qmicli to connect, I was getting the following error: error: "couldn't start network: QMI protocol error (64): '(null)'. .
There have apparently been some changes to qmi utils in Stretch and most of the documentation I saw over the last days is almost correct but missing one vital detail - you need to add ip-type=4 to other parameters for qmicli -d /dev/cdc-wdm0 --wds-start-network= as below.
pi:~$ qmicli -p -d /dev/cdc-wdm0 --device-open-net='net-raw-ip|net-no-qos-header' --wds-start-network="apn='YOUR_APN',username='YOUR_USERNAME',password='YOUR_PASSWORD',ip-type=4" --client-no-release-cid
[/dev/cdc-wdm0] Network started
	Packet data handle: '2264328160'
[/dev/cdc-wdm0] Client ID not released:
	Service: 'wds'
	    CID: '20'
5. Finally, configure the IP address and the default route with udhcpc:
pi:~$ sudo udhcpc -i wwan0
udhcpc (v1.22.1) started
No resolv.conf for interface wwan0.udhcpc
Sending discover...
Sending select for 10.65.52.178...
Lease of 10.65.52.178 obtained, lease time 7200
cat: /run/resolvconf/lock/pid: No such file or directory
/sbin/resolvconf: 733: kill: Illegal number:
clearing stale lock pid
Too few arguments.
Too few arguments.
As you can see, this spits out a number of errors, but they relate to configuration of DNS servers in your resolv.conf file, but otherwise this works and I can now get the connection via the mobile network:
pi:~ $ ip a s wwan0
3: wwan0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000
    link/none
    inet 10.65.52.178/30 scope global wwan0
       valid_lft forever preferred_lft forever
pi:~ $ ip r s
default via 10.65.52.177 dev wwan0
10.65.52.176/30 dev wwan0 proto kernel scope link src 10.65.52.178
192.168.100.0/24 dev eth0 proto kernel scope link src 192.168.100.5 metric 202
pi:~ $ ping -4 www.google.com
PING www.google.com (74.125.193.147) 56(84) bytes of data.
64 bytes from ig-in-f147.1e100.net (74.125.193.147): icmp_seq=1 ttl=50 time=732 ms
64 bytes from ig-in-f147.1e100.net (74.125.193.147): icmp_seq=2 ttl=50 time=79.4 ms
64 bytes from ig-in-f147.1e100.net (74.125.193.147): icmp_seq=3 ttl=50 time=80.3 ms
64 bytes from ig-in-f147.1e100.net (74.125.193.147): icmp_seq=4 ttl=50 time=79.4 ms
^C
--- www.google.com ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3002ms
rtt min/avg/max/mdev = 79.447/242.945/732.530/282.662 ms
You can take a look at this article: http://www.embeddedpi.com/documentation ... face-setup for a way to tidy things up a bit. It refers to a different 3G/4G modem (Sierra Wireless) but the way they set interfaces up and everything else still applies.
Good luck!
aford88
Re: 4G Hat
Wed Apr 24, 2019 8:16 pm
@mkrzysztofowicz - this is awesome, thanks!!
Works for me on the UK's EE network with the following details: apn: everywhere username: eesecure password: secure
smokeyjoe123
Re: 4G Hat
Thu Apr 25, 2019 11:19 am
@mkrzysztofowicz Thanks for your detailed post. How does you connection work ? Do you still go through the serial port or do you connect a usb cable from the pi to the USb port on the HAT ? /dev/cdc-wdm0 does not exist but I assume its because I am not going through the serial port.
mkrzysztofowicz
Re: 4G Hat
Mon Apr 29, 2019 12:45 pm
@smokeyjoe123
My setup uses the serial port only for control (i.e. sending the AT commands). The actual data connection goes via the USB port on the HAT. Make sure you have the jumpers (A/B/C) set correctly - I think, from memory. they are both set to A on my HAT. Also, make sure you use the correct USB port - on my HAT I use the micro USB port on the opposite edge of the HAT than the 40-pin header (i.e. NOT the one labeled USB TO UART).
When I have all that connected as above, I see in dmesg that the USB connection is detected (in fact, 5 USB devices are now visible):
[Tue Apr 16 12:22:00 2019] usbcore: registered new interface driver usbserial
[Tue Apr 16 12:22:00 2019] usbcore: registered new interface driver usbserial_generic
[Tue Apr 16 12:22:00 2019] usbserial: USB Serial support registered for generic
[Tue Apr 16 12:22:00 2019] usbcore: registered new interface driver cdc_wdm
[Tue Apr 16 12:22:00 2019] usbcore: registered new interface driver option
[Tue Apr 16 12:22:00 2019] usbserial: USB Serial support registered for GSM modem (1-port)
[Tue Apr 16 12:22:00 2019] option 1-1.2:1.0: GSM modem (1-port) converter detected
[Tue Apr 16 12:22:00 2019] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
[Tue Apr 16 12:22:00 2019] option 1-1.2:1.1: GSM modem (1-port) converter detected
[Tue Apr 16 12:22:00 2019] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
[Tue Apr 16 12:22:00 2019] option 1-1.2:1.2: GSM modem (1-port) converter detected
[Tue Apr 16 12:22:00 2019] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
[Tue Apr 16 12:22:00 2019] option 1-1.2:1.3: GSM modem (1-port) converter detected
[Tue Apr 16 12:22:00 2019] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB3
[Tue Apr 16 12:22:00 2019] option 1-1.2:1.4: GSM modem (1-port) converter detected
[Tue Apr 16 12:22:00 2019] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB4
[Tue Apr 16 12:22:00 2019] qmi_wwan 1-1.2:1.5: cdc-wdm0: USB WDM device
[Tue Apr 16 12:22:00 2019] qmi_wwan 1-1.2:1.5 wwan0: register 'qmi_wwan' at usb-3f980000.usb-1.2, WWAN/QMI device, 06:2e:a8:00:b1:b8
[Tue Apr 16 12:22:00 2019] usbcore: registered new interface driver qmi_wwan
As you can tell, one of those is the qmi_wwan device, which creates the wwan0 interface, as below:
pi:~ $ ifconfig wwan0
wwan0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST>  mtu 1500
        inet X.X.X.X  netmask 255.255.255.248  destination X.X.X.X
        inet6 fe80::X:X:X:X:X:X  prefixlen 64  scopeid 0x20<link>
        unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 1000  (UNSPEC)
        RX packets 65467  bytes 28590388 (27.2 MiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 82425  bytes 12802817 (12.2 MiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
smokeyjoe123
Re: 4G Hat
Mon Apr 29, 2019 12:51 pm
Thanks Mate I got it working.
openevo
Re: 4G Hat
Tue May 14, 2019 10:17 am
@mkrzysztofowicz
Brilliant!! Got my setup working 100%.
szabofrigocargo1
Re: 4G Hat
Thu May 16, 2019 8:33 pm
Hy Guys,
For those who using waveshare Sim7600EH modul I have a couple of remarks:
I would like to ask you to confirm my remarks.
1. This Waveshare modul is faulty if you use data communication in 2G network because the power supply of it. If you send and receive data through 2G network please measure voltage on the leg of Vbat Simcom chip via oscilloscope. According to the SimCom recommendation the voltage drop is should not be more than 300mV, but on this modul you an experience bigger voltage drop then 300mV, that is why the chip is keep restarting sometimes. We tried every input what can be used for powering, but the fault remains the same.(Rapsberry Pi used with its own original power supply 2,5 A) On LTE network this fault does not come up.
2. Let’s open 2 Terminals using Rapsberry Pi with display what is connected by HDMI Cable, not LAN cable through SSH:
Terminal 1: (ALT+F1) We bring up the AT port of GSM device, and use the following commands:
sudo screen /dev/ttyUSB2
Thereafter in this port we type in the below:
AT+CGPSNMES=2
AT+CGPS=1
IMPORTANT we do not close this port.
Terminal 2:(ALT+F2) In separated window we bring up the GPS Port of GSM device:
sudo screen /dev/ttyUSB1
In this port we can see the live NMEA datas.
Thereafter we go back to Terminal 1 and we use the next command:
AT+CFUN=1,1
After using the AT+CFUN=1,1 command the Rapsberry Pi get frozen. It does not cause fully system freezing it looks like 3 of the cores stop. In the Syslog file the fault is not logged/visible.
If we close the Terminal2 before use the AT+CFUN=1,1 command we experience the same issue randomly BUT if Terminal's is not closed it get frozen every single time.
So far I was only able to take 2 screenshots of the faults. After reboot it did not appeared in Syslog.(2 picture attached).
In the future when we have the use the final, fully working device we will need to restart the GSM moduls sometimes. In our tests it proved that if we close all the ports in the Python software (close the PYserial connection), however the Raspberry Pi still get frozen.
The easiest way to reproduce the fault that if we open the 2 Terminals and use AT+CFUN=1,1 command. According to this we deduce that the fault is not related to the PYserial.
Very important remarks:
- If we reach the Rapsberry Pi through SSH and LAN network (e.g.: Putty) the Fault NEVER EXPERIENCED. We can open any port, use AT+CFUN=1,1 command the Pi does not freeze.
- If we type dwc_otg.speed=1 command to the /boot/cmdline.txt file the Fault NEVER EXPERIENCED.
Our opinion:
It could be some kind of kernel fault. Before the freeze the USB disconnect messages do not appear in Syslog file.
Thanks you for reading my message! Would you be able to help me please?
DerMeister123
Re: 4G Hat
Mon May 27, 2019 7:05 am
My HAT is connected same as yours. Commands via pins but connection via USB. I cant seem to get my Pi to get internet via the usb wwan0. It definitely has internet, tested this by plunging it into my pc. I am doing config via VNC, I have no screen. When my wifi and lan are disconnected VNC wont come back online (VNC connected via account not IP) so I assume the pi is not getting internet. See screenshot. Not sure what else to so. Whent through the whole setup twice. Any help would be much appreciated.
DerMeister123
Re: 4G Hat
Mon May 27, 2019 2:47 pm
OK, got it working by reloading Rasbian and used steps provided by mkrzysztofowicz only. Thanks
kikusin
Re: 4G Hat
Fri Jun 21, 2019 12:36 pm
Hi everyone!
New here and fighting with SIM7600 as well.
Thanks for all the info in the thread. It was very useful but I got stuck in the very very last step.
I get everything ok and start the network:
pi@raspberrypi:~ $ sudo qmicli -p  -d /dev/cdc-wdm0 --device-open-"net=net-raw-ip|net-no-qos-header" --wds-start-network="apn='internet', ip-type=4" --client-no-release-cid
	Packet data handle: '2263292848'
	Service: 'wds'
	    CID: '20'
And connected to the serial I can get an IP:
AT+CPSI?
+CPSI: LTE,Online,214-04,0xB799,120324198,31,EUTRAN-BAND3,1675,4,4,-90,-937,-656
OK
AT+CREG?
+CREG: 0,1
OK
AT+IPADDR
+IPADDR: 10.224.160.74
OK
But I am totally unable to get an IP by udhcpc:
wwan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet6 fe80::8aa6:f469:d9f8:fc8e  prefixlen 64  scopeid 0x20<link>
        ether c6:8f:78:e3:5c:44  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 51  bytes 12170 (11.8 KiB)
pi@raspberrypi:~ $ sudo udhcpc -i wwan0
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
I really do not know what else to try, but I am pretty sure it has to be a very stupid thing.
Any ideas?
Thanks a lot!
fanfette
Re: 4G Hat
Wed Jun 26, 2019 12:52 pm
Hi guys !
when I try to start network I get an error:
error: couldn't start network: QMI protocol error (14): 'CallFailed'
sudo qmicli -p  -d /dev/cdc-wdm0 --device-open-"net=net-raw-ip|net-no-qos-header" --wds-start-network="apn='orange',username='orange',password='orange' --client-no-release-cid
call end reason (3): generic-no-service
verbose call end reason (3,2500): [cm] (null)
	Service: 'wds'
	    CID: '20'
I'm completely desperate ! I don't know 'How' and 'Where' I can find the solution.
Can someone help me ?
kikusin
Re: 4G Hat
Wed Jun 26, 2019 4:15 pm
Be sure you followed step 2) of main post:
2. This one is important - when you reboot the pi, the SIM7600 module's cellular radio is OFF and needs to be turned ON before you can see the mobile network. One way is to use a script which pulls the GPIO pin 4 LOW for a second or two (as per this post: viewt ... 1#p1368015),
If you do not success doing this, the hat may stay in low power status.
You can check this status by console with:
AT+CPSI?
AT+CREG?
fanfette
Re: 4G Hat
Thu Jun 27, 2019 2:50 pm
Thanks @kikusin for your reply
Cellular radio seems to be ON, I can see in my network manager :
wwan0: Associated with
wwan0: configured 169.###.##.88/16
for that I execute an sh script (like descibe in your post) on each reboot.
I'm not exactly sure about what I change in my configuration but now I get this message :
error: couldn't start network: QMI protocol error (26): 'NoEffect'
sudo qmicli -p  -d /dev/cdc-wdm0 --device-open-"net=net-raw-ip|net-no-qos-header" --wds-start-network="apn=orange,username=orange,password=orange,ip-type=4" --client-no-release-cid
	Service: 'wds'
	    CID: '23'
with more details (--verbose)
[27 juin 2019, 16:48:38] [Debug] [/dev/cdc-wdm0] Opening device with flags 'net-raw-ip, net-no-qos-header, proxy'...
[27 juin 2019, 16:48:38] [Debug] [/dev/cdc-wdm0] Sent message...
<<<<<< RAW:
<<<<<< length = 28
<<<<<< data = 01:1B:00:00:00:00:00:01:00:FF:10:00:01:0D:00:2F:64:65:76:2F:63:64:63:2D:77:64:6D:30
[27 juin 2019, 16:48:38] [Debug] [/dev/cdc-wdm0] Sent message (translated)...
<<<<<< QMUX:
<<<<<< length = 27
<<<<<< flags = 0x00
<<<<<< service = "ctl"
<<<<<< client = 0
<<<<<< QMI:
<<<<<< flags = "none"
<<<<<< transaction = 1
<<<<<< tlv_length = 16
<<<<<< message = "Internal Proxy Open" (0xFF00)
<<<<<< TLV:
<<<<<< type = "Device Path" (0x01)
<<<<<< length = 13
<<<<<< value = 2F:64:65:76:2F:63:64:63:2D:77:64:6D:30
<<<<<< translated = /dev/cdc-wdm0
[27 juin 2019, 16:48:38] [Debug] [/dev/cdc-wdm0] Received message...
>>>>>> RAW:
>>>>>> length = 19
>>>>>> data = 01:12:00:00:00:00:01:01:00:FF:07:00:02:04:00:00:00:00:00
[27 juin 2019, 16:48:38] [Debug] [/dev/cdc-wdm0] Received message (translated)...
>>>>>> QMUX:
>>>>>> length = 18
>>>>>> flags = 0x00
>>>>>> service = "ctl"
>>>>>> client = 0
>>>>>> QMI:
>>>>>> flags = "response"
>>>>>> transaction = 1
>>>>>> tlv_length = 7
>>>>>> TLV:
>>>>>> type = "Result" (0x02)
>>>>>> length = 4
>>>>>> value = 00:00:00:00
>>>>>> translated = SUCCESS
[27 juin 2019, 16:48:38] [Debug] [/dev/cdc-wdm0] Setting network port data format...
<<<<<< RAW:
<<<<<< length = 21
<<<<<< data = 01:14:00:00:00:00:00:02:26:00:09:00:10:02:00:02:00:01:01:00:00
<<<<<< QMUX:
<<<<<< length = 20
<<<<<< flags = 0x00
<<<<<< client = 0
<<<<<< QMI:
<<<<<< transaction = 2
<<<<<< tlv_length = 9
<<<<<< message = "Set Data Format" (0x0026)
<<<<<< TLV:
<<<<<< type = "Protocol" (0x10)
<<<<<< length = 2
<<<<<< value = 02:00
<<<<<< translated = raw-ip
<<<<<< TLV:
<<<<<< type = "Format" (0x01)
<<<<<< length = 1
<<<<<< value = 00
<<<<<< translated = absent
>>>>>> RAW:
>>>>>> length = 28
>>>>>> data = 01:1B:00:80:00:00:01:02:26:00:10:00:02:04:00:00:00:00:00:12:01:00:00:10:02:00:02:00
>>>>>> QMUX:
>>>>>> length = 27
>>>>>> flags = 0x80
>>>>>> service = "ctl"
>>>>>> client = 0
>>>>>> QMI:
>>>>>> flags = "response"
>>>>>> transaction = 2
>>>>>> tlv_length = 16
>>>>>> TLV:
>>>>>> length = 4
>>>>>> value = 00:00:00:00
>>>>>> TLV:
>>>>>> type = 0x12
>>>>>> length = 1
>>>>>> value = 00
>>>>>> TLV:
>>>>>> length = 2
>>>>>> value = 02:00
>>>>>> translated = raw-ip
[27 juin 2019, 16:48:38] [Debug] [/dev/cdc-wdm0] Network port data format operation finished
[27 juin 2019, 16:48:38] [Debug] QMI Device at '/dev/cdc-wdm0' ready
[27 juin 2019, 16:48:38] [Debug] [/dev/cdc-wdm0] Assuming service 'wds' is supported...
[27 juin 2019, 16:48:38] [Debug] [/dev/cdc-wdm0] Allocating new client ID...
<<<<<< RAW:
<<<<<< length = 16
<<<<<< data = 01:0F:00:00:00:00:00:03:22:00:04:00:01:01:00:01
<<<<<< QMUX:
<<<<<< length = 15
<<<<<< flags = 0x00
<<<<<< client = 0
<<<<<< QMI:
<<<<<< transaction = 3
<<<<<< tlv_length = 4
<<<<<< message = "Allocate CID" (0x0022)
<<<<<< TLV:
<<<<<< type = "Service" (0x01)
<<<<<< length = 1
<<<<<< value = 01
<<<<<< translated = wds
>>>>>> RAW:
>>>>>> length = 24
>>>>>> data = 01:17:00:80:00:00:01:03:22:00:0C:00:02:04:00:00:00:00:00:01:02:00:01:18
>>>>>> QMUX:
>>>>>> length = 23
>>>>>> flags = 0x80
>>>>>> service = "ctl"
>>>>>> client = 0
>>>>>> QMI:
>>>>>> flags = "response"
>>>>>> transaction = 3
>>>>>> tlv_length = 12
>>>>>> TLV:
>>>>>> length = 4
>>>>>> value = 00:00:00:00
>>>>>> TLV:
>>>>>> type = "Allocation Info" (0x01)
>>>>>> length = 2
>>>>>> value = 01:18
>>>>>> translated = [ service = 'wds' cid = '24' ]
[27 juin 2019, 16:48:38] [Debug] [/dev/cdc-wdm0] Registered 'wds' (version unknown) client with ID '24'
[27 juin 2019, 16:48:38] [Debug] Network start parameters set (apn: 'orange', 3gpp_profile: '0', 3gpp2_profile: '0', auth: 'unspecified', username: 'orange', password: 'orange', autoconnect: 'unspecified')
[27 juin 2019, 16:48:38] [Debug] Asynchronously starting network...
<<<<<< RAW:
<<<<<< length = 44
<<<<<< data = 01:2B:00:00:01:18:00:01:00:20:00:1F:00:19:01:00:04:18:06:00:6F:72:61:6E:67:65:17:06:00:6F:72:61:6E:67:65:14:06:00:6F:72:61:6E:67:65
<<<<<< QMUX:
<<<<<< length = 43
<<<<<< flags = 0x00
<<<<<< service = "wds"
<<<<<< client = 24
<<<<<< QMI:
<<<<<< tlv_length = 31
<<<<<< message = "Start Network" (0x0020)
<<<<<< TLV:
<<<<<< type = "IP Family Preference" (0x19)
<<<<<< length = 1
<<<<<< value = 04
<<<<<< translated = ipv4
<<<<<< TLV:
<<<<<< type = "Password" (0x18)
<<<<<< length = 6
<<<<<< value = 6F:72:61:6E:67:65
<<<<<< translated = orange
<<<<<< TLV:
<<<<<< type = "Username" (0x17)
<<<<<< length = 6
<<<<<< TLV:
<<<<<< type = "APN" (0x14)
<<<<<< length = 6
>>>>>> RAW:
>>>>>> length = 27
>>>>>> data = 01:1A:00:80:01:18:02:01:00:20:00:0E:00:02:04:00:01:00:1A:00:01:04:00:00:00:00:00
>>>>>> QMUX:
>>>>>> length = 26
>>>>>> flags = 0x80
>>>>>> service = "wds"
>>>>>> client = 24
>>>>>> QMI:
>>>>>> flags = "response"
>>>>>> transaction = 1
>>>>>> tlv_length = 14
>>>>>> TLV:
>>>>>> length = 4
>>>>>> value = 01:00:1A:00
>>>>>> translated = FAILURE: NoEffect
>>>>>> TLV:
>>>>>> type = "Packet Data Handle" (0x01)
>>>>>> length = 4
>>>>>> value = 00:00:00:00
>>>>>> translated = 0
Service: 'wds'
CID: '24'
[27 juin 2019, 16:48:38] [Debug] [/dev/cdc-wdm0] Releasing 'wds' client with flags 'none'...
[27 juin 2019, 16:48:38] [Debug] [/dev/cdc-wdm0] Unregistered 'wds' client with ID '24'
[27 juin 2019, 16:48:38] [Debug] Client released
I'm not sure it's a good news... :)
A big thanks to take time to help me !
