krisk
Help With Simple Hello World Program in Bare Metal ASM
Mon Oct 08, 2018 7:10 am
I've been following a tutorial on how to setup the GPIO and UART peripherals and output hello world on my Pi, but I am unable to get it to work.
The tutorial is: https://www.youtube.com/watch?v=4RrMoa5PS_M&t=165s
My Pi is: Zero W Version 1.1
My code is:
	/* Store PIO-controller & UART-controller base-addresses. */
	ldr r0, =0x20200000	/* r0 = 0x20200000 */
	ldr r1, =0x20201000	/* r1 = 0x20201000 */
	/* Disable UART. */
	mov r2, #0		/* r2 = 0 */
	str r2, [r1, #0x30]	/* [20201030] = 0x0 */
	/* Setup GPIO pins (GGPUD). */
	str r2, [r0, #0x94]	/* [20200094] = 0x0 */
	/* Pause for 0x400000 loops. */
	ldr r3, =0x400000	/* r3 = 0x400000 */
l1:
	sub r3, r3, #1		/* r3 = r3 - 1 */
	cmp r3, #0		/* if r1 != 0x0 */
	bne l1
	/* Setup GPIO pins (GGPUDCLK0). */
	mov r2, #0xC000		/* r2 = 0xC000 */
	str r2, [r0, #0x98]	/* [20200098] = 0xC000 */
l2:
	bne l2
	mov r2, #0x0		/* r2 = 0x0 */
	str r2, [r0, #0x98]	/* [20200098] = 0x0 */
	/* Config UART Inturrupt Clear Register (ICR). */
	ldr r2, =0x7FF		/* r2 = 0x7FF */
	str r2, [r1, #0x44]	/* [20201044] = 0x7FF */
	/* Set UART Baud rate (IBRD)/(FBRD). */
	mov r2, #1		/* r2 = 1 */
	str r2, [r1, #0x24]	/* [20201024] = 0x1 */
	mov r2, #40		/* r2 = 40 */
	str r2, [r1, #0x28]	/* [20201028] = 40 */
	/* Set UART Line Control Register (LCRH). */
	mov r2, #70			/* r2 = 70 */
	str r2, [r1, #0x2c]	/* [2020102c] = 70 */
	/* Set UART Inturrupt Set Mask Clear (IMSC) register. */
	ldr r2, =0x7F2		/* r2 = 0x7f2 */
	str r2, [r1, #0x38]	/* [20201038] = 0x7f2 */
	/* Set UART control-register. */
	ldr r2, =0x301		/* r2 = 0x301 */
	str r2, [r1, #0x30]	/* [20201030] = 0x301 */
	/* Output "Hello world!" to the UART Data Register. */
	mov r2, #0x48		/* r2 = 'H' (hex) */
	str r2, [r1]		/* [20201000] = 'H' (hex) */
	mov r2, #0x65		/* r2 = 'e' (hex) */
	str r2, [r1]		/* [20201000] = 'e' (hex) */
	mov r2, #0x6c		/* r2 = 'l' (hex) */
	str r2, [r1]		/* [20201000] = 'l' (hex) */
	mov r2, #0x6F		/* r2 = 'o' (hex) */
	str r2, [r1]		/* [20201000] = 'o' (hex) */
	mov r2, #0x20		/* r2 = ' ' (hex) */
	str r2, [r1]		/* [20201000] = ' ' (hex) */
	mov r2, #0x77		/* r2 = 'w' (hex) */
	mov r2, #0x72		/* r2 = 'r' (hex) */
	str r2, [r1]		/* [20201000] = 'r' (hex) */
	mov r2, #0x64		/* r2 = 'd' (hex) */
	str r2, [r1]		/* [20201000] = 'd' (hex) */
	mov r2, #0x21		/* r2 = '!' (hex) */
	str r2, [r1]		/* [20201000] = '!' (hex) */
Does anybody know where I've gone wrong with this?
Thanks in advance.
LdB
Re: Help With Simple Hello World Program in Bare Metal ASM
Mon Oct 08, 2018 3:37 pm
The video is for a different model the Pi1 you would need to adjust the peripheral address 0x20000000 vs 0x3F000000.
Goto the resources in the sticky threads and start there.
dwelch67
Mon Oct 08, 2018 6:09 pm
its a pi-zero so 0x20xxxxxx is correct yes?
Mon Oct 08, 2018 6:32 pm
The Pi Zero uses the same SoC as the Pi1, so the address should be the same.
LdB
Tue Oct 09, 2018 2:55 am
Okay but isn't the address given the PL011 uart which will be going to the Wifi on the PiZeroW.
I suspect the 16550 uart (0x20215040) will be the one acting as the kernel output.
I use a few lines of assembler code to autodetect all this rubbish to avoid having to think about it but I was messing around with uart on models a few weeks ago and that is what I remember. So I will preface the above statement with I still think your address is wrong but for a different reason.
Anyhow look it up to be sure.
