guscrown
Overlay for TSC2007 Touch controller
Wed Oct 03, 2018 10:04 pm
I'm having issues creating an overlay for the TSC2007 chip (for now I'm testing with the TSC2007EVM board), this is what I have:
/dts-v1/;
/plugin/;
        compatible = "brcm,bcm2835", "brcm,bcm2708", "brcm,bcm2709";
        [email protected] {
                target = <&gpio>;
                __overlay__ {
                        tsc2007_pins: tsc2007_pins {
                                brcm,pins = <25>;
                                brcm,function = <0>; /* in */
                                /*brcm,pull = <2 0>; / * pullup none */
        [email protected] {
                target = <&i2c1>;
                __overlay__ {
            #address-cells = <1>;
                        #size-cells = <0>;
                        status = "okay";
              tsc2007: [email protected] {
                            	#size-cells = <0>;
                                compatible = "ti,tsc2007";
                                reg = <0x48>;
                		interrupt-parent = <&gpio25>;
                		interrupts = <0x0 0x2>;
                		gpios = <&gpio25 0 0>;
                		ti,x-plate-ohms = <180>;
        __overrides__ {
                irq_pin = <&tsc2007>, "irq-gpio:4",
                          <&tsc2007_pins>, "brcm,pins:0";
I am basing this on a functional overlay I have for the STMPE610 and other threads I found in this forum. And also using the reference example here: https://www.kernel.org/doc/Documentatio ... sc2007.txt
It compiles fine, but when I tried to load it with
sudo dtoverlay tsc2007
I get the follow error:
[10028.373231] OF: resolver: overlay phandle fixup failed: -22
[10028.373242] create_overlay: Failed to resolve tree
Any ideas?
PhilE
Re: Overlay for TSC2007 Touch controller
Thu Oct 04, 2018 9:47 am
That's a good attempt, but you were misled by the GPIO and interrupt declarations in the example - "<&gpio4 0 0>". The "4" in "gpio4" is presumably GPIO controller number 4, rather than GPIO 4. The two integers after that are the index of the GPIO on that controller and the flags - 0 means active high.
The normal on-board GPIOs on BCM2835 are controlled by the node called "gpio", and the index is the number of the GPIO, which gives you a "gpios" property of:
                		gpios = <&gpio 25 0>;
Applying similar logic to the interrupt-parent and interrupts properties, fixing up the irq_pin declaration, and removing the unnecessary #address-cells and #size-cells from inside the [email protected] node results in:
/dts-v1/;
/plugin/;
        compatible = "brcm,bcm2835";
        [email protected] {
                target = <&gpio>;
                __overlay__ {
                                brcm,pins = <25>;
        [email protected] {
                target = <&i2c1>;
                __overlay__ {
                        #size-cells = <0>;
                        status = "okay";
                                reg = <0x48>;
                		interrupt-parent = <&gpio>;
                		interrupts = <25 0x2>; /* falling edge */
        __overrides__ {
                irq_pin = <&tsc2007>, "interrupts:0",
                          <&tsc2007>, "gpios:4",
Your next problem is likely to be that the stock Raspbian kernels don't include the tsc2007 module. You will need to add "CONFIG_TOUCHSCREEN_TXC2007=m" to your kernel configuration if you are building your own kernel, and/or open an Issue at https://github.com/raspberrypi/linux/issues asking for it to be made a standard module.
guscrown
Thu Oct 04, 2018 7:43 pm
/dts-v1/;
/plugin/;
        [email protected] {
                target = <&gpio>;
                __overlay__ {
                                brcm,pins = <25>;
        [email protected] {
                target = <&i2c1>;
                __overlay__ {
                        #size-cells = <0>;
                        status = "okay";
                                reg = <0x48>;
        __overrides__ {
This worked. I had to go research how to build my own Kernel but managed to do it. The fixes to the dts file also worked.
I did
sudo evtest
And I can see the touchscreen as /dev/input/event3 and I can see the touch events. However, no activity is being triggered on the cursor itself.
I checked under xinput and it's not listed there. Do I have to create some kind of udev rule for it?
guscrown
Thu Oct 04, 2018 8:15 pm
lsmod
Shows the tsc2007 module being loaded, but it shows "0" for
Used by
guscrown
Thu Oct 04, 2018 9:11 pm
Alright, making some progress. I went and added the following to an xorg conf file:
Section "InputClass"
   Identifier "TSC2007 touchscreen class"
   MatchProduct "TSC2007 Touchscreen"
   MatchDevicePath "/dev/input/event*"
   Driver "evdev"
EndSection
Now it's being picked up by X. Screen is mirrored and rotated. Now I need to figure that out.
Thu Oct 04, 2018 9:22 pm
There may be a device tree entry for that particular TS driver to do flips etc. I can never remember where DT docuemnation is stored, but you coudl checkthe driver itself to see if it reads any DT entries for flips/swaps.
Failing that, there are X conf entries for flips, there are a number of forum posts about it, but again, I don;t remember exactly what to do. Soz!
Please direct all questions to the forum, I do not do support via PM.
Return to “Device Tree”
Who is online
