I am working on a project in which I have to play 5 mp3 songs in a sequence one after another. Each song has a duration of 10s. For that purpose, I am using pygame library. All is working fine but I have to add one for future in this application that is I want to start and pause these mp3 songs on pressing this BIG Button that is connected through one of the serial port of Raspberry Pi. I am a beginner level and don't know how to do this. Kindly! help me. Your help will be appreciated
import time
import random
import RPi.GPIO as GPIO
import pygame
pygame.mixer.init()
# setting a current mode
GPIO.setmode(GPIO.BCM)
#removing the warings
GPIO.setwarnings(False)
#creating a list (array) with the number of GPIO's that we use
pins = [16,20,21]
#setting the mode for all pins so all will be switched on
GPIO.setup(pins, GPIO.OUT)
GPIO.output(16, GPIO.HIGH)
GPIO.output(20, GPIO.HIGH)
GPIO.output(21, GPIO.HIGH)
temp = ''
def song():
if (select == 'a'):
#1............................................................
pygame.mixer.music.load("Shinsuke-Nakamura.mp3")
pygame.mixer.music.play()
time.sleep(0.2)
GPIO.output(16, GPIO.LOW)
time.sleep(10)
#pygame.mixer.music.stop()
temp = 'a'
return temp
if (select == 'b'):
#2............................................................
pygame.mixer.music.load("John-Cena.mp3")
time.sleep(0.2)
GPIO.output(20, GPIO.LOW)
time.sleep(10)
temp = 'b'
return temp
if (select == 'c'):
#3............................................................
pygame.mixer.music.load("Brock-Lesnar.mp3")
time.sleep(0.2)
GPIO.output(21, GPIO.LOW)
time.sleep(10)
temp = 'c'
return temp
if (select == 'd'):
#4............................................................
pygame.mixer.music.load("Gold-Berg.mp3")
time.sleep(0.2)
time.sleep(10)
temp = 'd'
return temp
if (select == 'e'):
#5............................................................
pygame.mixer.music.load("Randy-Orton.mp3")
time.sleep(0.2)
time.sleep(10)
temp = 'e'
return temp
if (select == 'f'):
#6............................................................
pygame.mixer.music.load("Braun-Strowman.mp3")
time.sleep(0.2)
time.sleep(10)
temp = 'f'
return temp
if (select == 'g'):
#7............................................................
pygame.mixer.music.load("The-UnderTaker.mp3")
time.sleep(0.2)
time.sleep(10)
temp = 'g'
return temp
if (select == 'h'):
#8............................................................
pygame.mixer.music.load("The-Kane.mp3")
time.sleep(0.2)
time.sleep(10)
temp = 'h'
return temp
if (select == 'i'):
#9............................................................
pygame.mixer.music.load("Triple-H.mp3")
time.sleep(0.2)
time.sleep(10)
temp = 'i'
return temp
if (select == 'j'):
#10...........................................................
pygame.mixer.music.load("The-Shield.mp3")
time.sleep(0.2)
time.sleep(10)
temp = 'j'
return temp
try:
while 1:
select = random.choice('abcdefghij')
if (temp != select):
temp = song()
else:
print('repeat')
except KeyboardInterrupt:
GPIO.cleanup() # clean up GPIO on CTRL+C exit
GPIO.cleanup() # clean up GPIO on normal exit
