rickseiden wrote:In a nutshell, and
this is as detailed as I can get, you need to do the following:
- setup a static ip on your rpi
- setup a compatable static ip on your laptop
- use a crossover cable to connect the two together directly
- SSH from your laptop to your rpi using the static ip address you setup in step 1.
A lot of network equipment nowadays is autosensing so crossover cable might not be needed.
You have a few other options, many of which could get you into trouble if you are not careful
1. Setup your laptop as a DHCP server, so that when you plug one device into the other, your laptop will give an IP address to the PI, this way the PI can also use the laptop for internet access. (You also could do this vice versa, having the Rpi give out ip address's via dhcp, probably wont play nice on your home network though, and internet sharing will be an issue. Also not easy to setup, and will require a second network adapter) tl;dr many operating systems have "internet connection sharing" which will setup this all for you
2. You could leave the default configuration for eth0 and setup a 802.11q tagging, (VLAN), and also configure the QTAG on your laptop, that way, also long as you dont plug into a switch that supports 802.11q tagging you will be able to use a static up on both devices to communicate regardless of what the Ip configuration is for both devices. (I did this at work for a while)
