geekinchief
SSH over USB with Raspberry Pi 3B?
Thu Sep 27, 2018 7:16 pm
I want to control my headless Raspberry Pi 3B via a USB cable connection to my PC. I know how to do this (and it works really well) for the Pi Zero W, but following the same instructions for the 3B doesn't work.
Re: SSH over USB with Raspberry Pi 3B?
Thu Sep 27, 2018 7:30 pm
USB requires a Host / Client relationship.
The RPi Zero can run in either Host or Client (on the go / gadget mode)
https://blog.gbaman.info/?p=791
The RPi 3B can like your PC can only be a USB Host, therefore what you wish to achieve is not feasible....
....unless you use a USBNET Cable:
https://www.raspberrypi.org/forums/view ... 6&t=131042
The information is out there....you just have to let it in.
My other Linux machines are a ChromeBox & Intel CoreDuo Desktop
sajeevank
Mon Jul 15, 2019 9:14 am
Shall You share the steps required for communicating Raspberry Pi 3 B+ with an Ubuntu Laptop, through SSH, with USBNET cable?
I think USBNET cable need to be connected to one of the USB Host ports of Raspberry Pi 3 B+(not in USB slave port). Right?
drgeoff
Mon Jul 15, 2019 9:29 am
Neither RPi3B nor RPi3B+ has a USB slave port. Only host ports.
Mon Jul 15, 2019 12:05 pm
removed as unhelpful response.....
Last edited by fruitoftheloom on Mon Jul 15, 2019 12:47 pm, edited 2 times in total.
thagrol
Mon Jul 15, 2019 12:12 pm
Correct. But a "UBSNET" cable (i.e. one designed to connect two USB hosts via a fake ethernet link) should make that a moot point.
Unfortunately I don't have one so can help directly.
If the "USBNET" cable present to each end as an ethernet devicve it should be just a matter of configuring the interfaces apropriately.
All advice given is based on my experience. it worked for me, it may not work for you.
All GPIO pin numbers are BCM numbers.
